This is a discussion on Maxidot question? within the Octavia II forums, part of the Skoda Model Discussion Area category; There is an option in settings for Conv. Mode allowing settings for Off, Driver and All, what does this do?? ...
| Not Worried Join Date: May 2004 Location: Caernarfon
| Maxidot question? There is an option in settings for Conv. Mode allowing settings for Off, Driver and All, what does this do?? it seems to make no difference on any setting. ![]()
__________________ Cluck, Cluck, Gibber, Gibber, my old mans a mushroom etc.......... |
| Briskodian Join Date: Mar 2004 Location: North Wales
| Re: Maxidot question? at a guess might it be for use with different keys?
__________________ ON ORDER: OctyII VRS CR 2.0Tdi Estate - Race Blue - upgrade pack - Maxidot - Sunset - Rear park - Active headrests - Curtains - MFD2 & Bluetooth Kit from the old one ![]() Skoda Octavia II 2.0 tdi L&K Estate - Xenons - Sunroof - Sensors - 17" Pegasus - Island Green - MFD2 - OEM Bluetooth Kit - Colour coded grille flickr Photos |
| Re: Maxidot question? How do you mean?? O and i have looked in the manual and it barely covers the Maxidot?
| Re: Maxidot question? its for the central convienience system, it works like this. On, holding the lock button on the remote down after locking or unlocking the car opens / closes all windows depending on wether you were locking/unlocking the car. Drivers - as above but for the drivers window only Off - exactly as it says, holding the remote lock/unlock button does nothing.
| | #5 | |
| Re: Maxidot question? Quote:
__________________ Cluck, Cluck, Gibber, Gibber, my old mans a mushroom etc.......... | |
| Briskodian Join Date: Mar 2007
| Re: Maxidot question? I do not have maxidot but is this to do with the unlocking/locking settings of the doors. i.e. with driver only the drivers door opens when you press the fob button- you then need to press the unlock button again to open all the doors. All could be one press unlocks all the doors but no idea what off would be. My other guess would be something to do with the antihijack facility. |
| | #7 | |
Is there no specific manual for maxidot out there?
| Oops! :( Join Date: Aug 2006 Location: The 2nd biggest city in the whole of England.
| Re: Maxidot question? I copied out a leaflet I had with my car in another thread http://www.briskoda.net/forums/new-o...hlight=maxidot Hope this helps. |
| The Following User Says Thank You to apd007 For This Useful Post: | ianwilly (30-05-2007) |
| | #9 | |
| Go Gadget Octy! Join Date: Apr 2007
Check your manual folder. There's an additional info booklet of changes since the manual, and it's covered in there. Only found mine when someone else mentioned it. | |
| | #10 |
| Re: Maxidot question? It appears that Conv.Mode is for the windows to open/close on door lock/unlock, bit it still does it when the option is switched off?? Weird huh!
| | #11 |
| Skoda-da-da-da Join Date: Aug 2006 Location: Manchester, Northampton
| Re: Maxidot question? Is that the same with both keys?
__________________ ![]() Skoda Octavia II Laurin & Klement 2.0TDi - 18" Zenith Alloys, Milotec Bumper Grill |
| | #12 |
| Re: Maxidot question? Was not aware that they were different as they look identical, will try though!
| | #13 |
| Briskodian Join Date: Apr 2007
| Re: Maxidot question? I'm sure this is the option that determines whether just the drivers door unlocks on one remote press, or if all doors open on first press. Just changed my setting yesterday, it was the top one on the list. |
