This is a discussion on Mercedes Alloys within the Octavia II forums, part of the Skoda Model Discussion Area category; Im thinking of getting a set of mercedes alloys and just want to check they will fit the Octavia 2. ...
| Briskodian Join Date: Oct 2003 Location: Scotland
| Mercedes Alloys Im thinking of getting a set of mercedes (fitting 205 x 55 x 16s to the rims) Rim Width: 7.5J Stud Diameter: 112 Offset: 35
__________________ Skoda 140BHP TDI ELEGANCE |
| Briskodian Join Date: Jan 2005 Location: United Arab Emirates
| Re: Mercedes Alloys The stud diameter is correct, and IIRC so is the offset, so I don't see why they wouldn't fit. Those rims look hot with low-profile tyres.
__________________ Milton Kyvernitis Private Government |
Images: 2 Thanks: 22
| Re: Mercedes Alloys PCD is correct however offset could be an issue. Octy 2 offset is usually around ET45+ on alloy wheels. Have tried Superb alloys on one and they stick out a mile (ET35).
| Re: Mercedes Alloys Also, check the centre bore, VAG cars run a 57.1mm centre bore if I remember correctly, and Merc is different, so you'd need a spigot ring, as you never mount a wheel with the weight on the bolts! ![]() |
| Aftermarket alloys jiggle at high speed | HellFire | Fabia I | 35 | 24-05-2005 18:24 |
| Octavia vRS alloys on my Fabia vRS... | HellFire | Fabia I | 21 | 06-03-2005 18:58 |
| Steering wobble after the new alloys | nagki | INTRODUCE YOURSELF! First time visitors, say hello here. | 15 | 05-01-2005 17:59 |
| Hakkinen tests Mercedes DTM | GAFF | Motorsport Discussion | 2 | 18-11-2004 02:10 |
