MP3 AUX in buzzing noise?
This is a discussion on MP3 AUX in buzzing noise? within the Octavia II forums, part of the Skoda Model Discussion Area category; Does anyones MP3 jack socket buzz badly when you just put in the stereo lead? Mine does and did on ...
Old 31-03-2008, 21:10   #1
A16NS V's Avatar
Does anyones MP3 jack socket buzz badly when you just put in the stereo lead? Mine does and did on an 08 Octavia at my local dealer when I went to check it with them.
I know the first thing to check is the cable which is why I checked all 6 of mine! They work in other domestic equipment with no problems but there is quite a buzz when you put the cable in, almost like there is a bad earth connection. I would have thought as there is no electrical connections then the jack lead is purely an extention of the wire to the radio but puzzlingly as soon as my Ipod is connected it stops?
I Realise this is trivial and livable but making bad buzzing feedback noises sounds bad to me and could be doing potential harm only for it to fail later.
The local dealer checked my firmware on the Stream MP3 but said my coding is newer than the latest update. They have ordered the official Skoda MP3 lead as that should cure it
A16NS V is offline
Old 31-03-2008, 21:11   #2
jamesmckelvie's Avatar
Re: MP3 AUX in buzzing noise?
yep I noticed the buzzing, but once inserted its fine.
1.9 TDI Elegance - Cappuccino Beige
Plenty enough power and torque for the economy offered
jamesmckelvie is offline
Old 31-03-2008, 21:23   #3
2.0 FSI Sport.
smstext's Avatar
its normally when either the left or right touches the earth via your skin as your body contains small amount of electrical current and is a conductor.
smstext is offline
Old 31-03-2008, 21:54   #4
A16NS V's Avatar
That's the sound it makes but I'm not touching the end.
A16NS V is offline
Old 31-03-2008, 22:33   #5
Skoda-da-da-da
vimto2000's Avatar
I had this in mine if it wasn't plugged into my iPod. I wouldn't worry about really as seems to be quite common!
Skoda Octavia II Laurin & Klement 2.0TDi - 18" Zenith Alloys, Milotec Bumper Grill
vimto2000 is offline
Old 31-03-2008, 22:37   #6
A16NS V's Avatar
Thanks The Skoda 'official' lead comes in 12inch or 1.5mtr lengths so I plumbed for the shorter one
We'll see on Wednesday if that does any better!
A16NS V is offline
Old 29-04-2008, 22:53   #7
Jules59's Avatar
A16NS V
Well, did the Skoda cable work better or not ?
Ive tried a long high quality cable I use for inputting analogue music into my PC and buzzes like mad ! So was wondering if the Skoda cable was somehow better.
Anyone else got any advice on this matter ?
Jules
Jules59 is offline
Old 29-04-2008, 23:12   #8
dstev2000's Avatar
I opted for a fairly expensive shielded AUX cable and I noticed an improved sound quality and better volume over the cheap boggo effort.
Golden rule:
Never scrimp on interconnects!!
Could it be the unplugged lead picking up noise from it's surroundings and sending it to the head unit? this can't happen so much if plugged in to a device. Cars are pretty 'noisy' places when it comes to audio systems and interference.
A shielded cable is always a better option if possible as it reduce the amount of noise induced into it when unplugged and when in use.
If you still get hum when plugged in at both ends that could be a noise filter/ground loop problem.
Xenons can cause big problems with noise as well, the high voltage/high frequency ballasts do not make good friends with audio equipment.
I get a feint humming when my ipod is charging from the lighter socket and that is most likely ground loop thanks to my charger and the HU being earthed in different places and is pretty much unavoidable.
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
Old 30-04-2008, 00:43   #9
dan_the_v8man's Avatar
its perfectly normal
57 Mk2 2.0TFSI vRS Estate in Race Blue, Code Red Stage 1 Remap, Code Red Intake, Code Red Engine Cover and Forge Blowoff Spacer
dan_the_v8man is offline
Similar Threads
MP3 Aux in for Fabia Bobbyg Fabia I 19 04-09-2007 07:15
Buzzing noise Octy vRS SCVRS Maintenance & Performance 3 20-06-2007 17:20
Unusual buzzing noise at when ignition key is turned Pete Fabia I 15 11-04-2006 21:09
buzzing noise when accellerator pressed? crunch Fabia I 3 07-04-2006 13:32
'buzzing' noise in dash baldyman Octavia II 15 13-03-2006 01:26
