This is a discussion on My brakes are being gay. within the Octavia II forums, part of the Skoda Model Discussion Area category; They've started to squeal a bit, and it's a bit embarrassing having a vRS come to a stop while squealing ...
| Weak Effort. Join Date: Feb 2007 Location: Blandford, Dorset
| My brakes are being gay. They've started to squeal a bit, and it's a bit embarrassing having a vRS come to a stop while squealing away ![]() So, question is, what are the most common causes of squeaky/squealy brakes? And, should i just get a Dealer to sort it out, whatever the problem?
__________________ MY07 Octavia vRS TDi Hatch - Black Magic - Replacement Engine, Replacement Gearbox, Replacement DPF - Colour Coded Grille Surround, De-Tangoed F&R Indicators, 'vRS' Etched Tax Disc Holder, 2nd Rear Fog, Anti-Hijack, Leaving/Coming Home Lights, Michelin PS2 Tyres - RR Proven 177.9 bhp / 289 lb/ft www.vauxhallownersnetwork.co.uk - South Central Regional Organiser www.freewebs.com/holebrookfarmlivery/index.htm - Horse Livery & Grazing in North Dorset |
| Briskodian Join Date: Aug 2006 Location: Herts
| Re: My brakes are being gay. Couple of possibilities as squeely brakes are often a sign of under use, easy to check yourself. 1. A piece of grit or small stone has got lodged between pad and disc; have a look for any tell-tale grooves on the disc. Try a firm application whilst going backwards to clear it, or 2. General build up of dust, road salt/dirt, rust etc.; find some open road with no traffic behind you and, having warmed the brakes first, apply the brakes firmly from speed (60mph plus) a couple of times - this will get the pads nice and warm and clean the surface of the disc. ![]() After this; any problems best to try your dealer.
__________________ Mine - '07 Octavia vRS TDI, Superchips BlueFin (210bhp/293lbft) 'Winter wheels' 7.5J x 17" Audi S-line, Ultrac Sessantas 225/45 17, xenons, rear parking sensor, heated seats (driver's Recaro Style full leather), climate/jumbo etc., Koni FSDs, Neuspeed Rear ARB & Short-Shifter, K&N induction kit, RallyFlapZ - Colin McRae memorial decals. Wife's - '08 Roomster Scout 1.6 Tiptronic, Cruise, parking sensors Son's - '02 Fabia 1.4mpi, vRS 16" alloys, Michelin Pilot Exalto 2 195/45 16, vRS front bumper, Koni Sport shocks. |
| The Following User Says Thank You to bahnstormer vrs For This Useful Post: | MidVRS (07-02-2008) |
| Briskodian Join Date: Aug 2005 Location: Back in the Green
| Re: My brakes are being gay. Be prepared for a barrage of replies. ![]() Crap and dust in the caliper, grit in the pad rubbing on the disc and maybe the rear of the pads need a good greasin'
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() |
| | #4 | |
| Briskodian Join Date: Jan 2008 Location: Offaly, Ireland
| Re: My brakes are being gay. Quote:
__________________ Race Blue Octavia vRS TDi Hit me at 40mph and theres an 80% chance I'll die. Hit me at 30mph and theres an 80% chance I'll live. However, if I stopped playing in the middle of the road I probably wouldn't get hit at all. | |
| The Following User Says Thank You to MidVRS For This Useful Post: | Babs (07-02-2008) |
| Briskodian Join Date: Aug 2006 Location: Liverpool
| Re: My brakes are being gay. Maybe your discs are bent? Or maybe you've minced your pads by using them too much? Brakes are always causing problems... one minute they're working and then POOF... they're gone! ![]() I'll get me coat
__________________ I was just a figment of your imagination! After nearly two years and a hell of a lot of fun, I'm off - all the best to everybody; this is Robbo signing off! |
| | #6 | |
![]() ![]() Took me a while to realise ALL of them were puns... ![]() Cheers all, i might whip the wheels off and have a quick looksie at the weekend... Otherwise, work can pay for it (ie go to dealers...)
__________________ MY07 Octavia vRS TDi Hatch - Black Magic - Replacement Engine, Replacement Gearbox, Replacement DPF - Colour Coded Grille Surround, De-Tangoed F&R Indicators, 'vRS' Etched Tax Disc Holder, 2nd Rear Fog, Anti-Hijack, Leaving/Coming Home Lights, Michelin PS2 Tyres - RR Proven 177.9 bhp / 289 lb/ft www.vauxhallownersnetwork.co.uk - South Central Regional Organiser www.freewebs.com/holebrookfarmlivery/index.htm - Horse Livery & Grazing in North Dorset | |
| Re: My brakes are being gay. Give them a good hard almost but not quite stop from 70/80 on the a31 etc with nobody behind you. Also might be worth taking the pads off firing brake claener over the disk/calliper and making sure there isn't a lip and the pads are not breaking down. Of course you should be able to take it to your local dealer and them fix it, but yours is wasteover, so I'm not sure I would bother.
| Briskodian Join Date: Jul 2006 Location: Glasgow
| Re: My brakes are being gay. use KY to lubricate the sliders... |
| Too Fast! Join Date: Jan 2006 Location: West Yorkshire
| Re: My brakes are being gay. WD40 on the pads, that will work. Only joking ![]()
__________________ Current car: Black MKII Octavia vRS Combi Previous: Black MKI Octavia vRS Combi Black Fabia Elegance 100 BHP |
| | #10 | |
| Briskodian Join Date: Apr 2006 Location: South London
And your car probably won't do 70/80 backwards...
__________________ It doesn't make any difference who you vote for. The Government always get in.... | |
| | #11 |
| Re: My brakes are being gay. Where - Wareham industrial park ![]()
| | #12 |
| Re: My brakes are being gay. Bit of a fooking trek that! ![]() I take it you actually mean Holton Heath? Warehams industrial park's a bit small... ![]()
| | #13 |
| Briskodian Join Date: Dec 2004 Location: Off The Wagon
| Re: My brakes are being gay. Hmm Gay breaks that's a new one on me. maybe it's the cowboy / sailor/ motorbike cop / construction worker outfits that you wear when driving the car?... |
| | #14 |
| | #15 |
| Briskodian Join Date: Jun 2005 Location: south east
| Re: My brakes are being gay. You sure he didn't mean goy brakes? Check if they're eating bacon butties. |
| | #16 |
| Re: My brakes are being gay. Just give them a few high speed runs and hammer the brakes, but release before you stop ![]()
| | #17 | |
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. | |
| | #18 |
| Re: My brakes are being gay. So with a variety of advice, some sensible and some not, given; have you got anything sorted out?
| | #19 |
| Re: My brakes are being gay. Some performance pads will squal a little regardless - almost like a ringing noise, its simply a characteristic of the pad. I do however find most brakes squeal due to lack of cleaning and greasing when they are replaced. ![]()
| | #20 | |
If so what did you change on yours to fit the 312mm brakes at the front? TIA
| | #21 | |
| | #22 |
| Re: My brakes are being gay. I'll check ETKA to confirm things mate. I've changed the pads (although not necessary), the disks are 25mm items from a V6 Superb/A4/A6, and the caliper carriers also. The calipers themselves are identical. So if you need replacement disks and pads anyway, this mod can be done for £100 ![]()
| I think I've got a gay cat! | philc | Off Topic and Chit Chat | 28 | 20-06-2007 20:02 |
| The Gay test | philc | Off Topic and Chit Chat | 5 | 07-12-2004 22:08 |
| How gay am i? | redbaron | Off Topic and Chit Chat | 86 | 08-07-2004 11:01 |
| Is Your Skoda Gay? | funkyjutel | Off Topic and Chit Chat | 2 | 12-01-2004 22:15 |
| Is Your Skoda Gay?? | funkyjutel | Off Topic and Chit Chat | 20 | 29-11-2002 01:53 |
