This is a discussion on new octavia glow plugs within the Octavia II forums, part of the Skoda Model Discussion Area category; anyone know which glow plugs fit new octavia.....bosch or other type....any number referance would be great...
| Briskodian Join Date: Aug 2005 Location: ireland
Members Car: octavia combi elegance '05 Thanks: 2
| new octavia glow plugs anyone know which glow plugs fit new octavia.....bosch or other type....any number referance would be great |
| Re: new octavia glow plugs Depends on which engine, give is a few more details to go on. |
| Re: new octavia glow plugs 1.9 tdi new octavia.....i want to buy alternatives because i'm not happy with my local skoda dealer...so i'll fit them myself....thanks |
| Re: new octavia glow plugs Whats the problem? There are a few other issues that could be effecting the system. |
| Re: new octavia glow plugs test glow plug one and two with my little meter and there not working .so i just need to replace them........so i just need the bosch ...champion ..or other reference so i can get them online or my local motor factors |
| Re: new octavia glow plugs I guess three and four were then by the same test? Got to be carefull as the latter plugs dont work on 12v when testing them and they are activated individually by a glow plug control unit which are not very reliable. All the plugs I have seen for the 1.9 (105) TDi are Bosch. They will also log a fault code if they are not working. |
Members Car: '97R BMW 328i Saloon Thanks: 679
| Re: new octavia glow plugs What makes you think they are not working?
| Re: new octavia glow plugs testing on vag com showed up faults on 1 and 2 plugs and then tested with a little meter thingy should not working properly.... so which ones do i get??? |
| Briskodian Join Date: Oct 2007
Members Car: fabia 1.9TDi (100bhp) Thanks: 81
| Re: new octavia glow plugs Bosch Number: 0 250 402 001 OE Number: N 105 916 03 Rated Voltage: 5 V But I'd double check with your local parts supplier first to make sure they're the right ones! |
| | #10 |
| Re: new octavia glow plugs thanks.....once i had the number ..i goggled it and that number seems to be right and also n10591602 seems also to come up..but i'll check with my local factors thanks.. |
| | #11 |
| Re: new octavia glow plugs No worries. One word of note - spoke to a mechanic who regularly changes glow plugs on Mercs. Sometimes they can seize, and then break on removal. This means they have to be drilled out of the head which is very time consuming! Might be better to get it done at a garage as opposed to diy. When fitting the new ones, make sure to use mounting grease (made by Beru) to facilitate future removal. |
| | #12 |
| Re: new octavia glow plugs champion ch700 also fit...i g these at my local factors...so far so good |
| Glow Plugs (again) | FIBAMAN | Octavia I | 1 | 31-08-2007 09:12 |
| Glow Plugs | FAB19TDI | Fabia I | 2 | 12-01-2007 22:25 |
| These the right glow plugs? anyone? | devonutopia | Maintenance & Performance | 1 | 12-01-2005 09:18 |
| Glow plugs | MGreen | INTRODUCE YOURSELF! First time visitors, say hello here. | 6 | 14-11-2004 18:16 |
| PD Diesel does it have glow plugs ? | Chavyboy | General Car Chat | 3 | 21-04-2004 17:19 |
