39,391 Members 1,486,982 Posts
New turbo needed, at 18,000
This is a discussion on New turbo needed, at 18,000 within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi all. My 140 diesel is having a new turbo fitted at 18,000 miles, under warranty. Bit surprised ! Dealer ...
Old 08-08-2008, 23:51   #1
Members Car:
Question New turbo needed, at 18,000
Hi all.
Bit surprised ! Dealer spot on, no problem (I hope), car back next week.
Just wondered how common a problem this is, please ?
Everyone's jealous because the voices only speak to me?
Zactor is offline
Old 09-08-2008, 00:03   #2
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
Re: New turbo needed, at 18,000
Try searching for PD140 turbo, you'll see it's not at all uncommon.
Stu
VRStu is offline
The Following User Says Thank You to VRStu For This Useful Post:
Zactor (09-08-2008)
Old 09-08-2008, 00:11   #3
Members Car:
Cheers Stu.
Off to do the search.
Zactor is offline
Old 09-08-2008, 00:25   #4
Members Car:
Can see from the other posts that I'm not alone.
Cheers.
Zactor is offline
Old 09-08-2008, 08:09   #5
BrDa's Avatar
You have MY '06 or?
What is symptom when turbo was gone?
BrDa is offline
Old 09-08-2008, 08:38   #6
Members Car: Octy MkII vRS TDi
Turbo failures seem to plague quite a few marques these days, all the VAG group have models that have them and as I remember, so do Nissan.
Obviously it could be a manufacturing fault within the turbo or an ancilliary like the boost sensor telling the turbo the wrong information etc.
I would though, with your new turbo adhere to the start up and switch off procedure to prolong the life of it.
Basically, when starting up let the car idle or drive steadily (off boost) for a while so that the oil gets chance to circulate around the moving bits of the turbo.
Likewise, when switching off, particularily after a fast drive, idle for a while so that the turbine inside the turbo has chance to stop. As you switch the engine off the oil pump stops and so the turbo will lose its oil supply. If its still spinning, that will cause wear.
As I live in an estate that has a 20 then a 30 zone for about a mile before I hit a NSL etc, I tend to idle for a few moments and then use the slow roads off boost to let the oil circulate. On the way back, I make sure I back off the gas as I get close to my destination.
Steve
My Car - 2007 Octavia vRS TDI in Diamond Silver-Cruise Control-Parking Sensors-Light Assisit/Auto Wipers-Bluetooth-Jumbo Pack
For Work - 2004 Landrover Freelander TD4 Commercial - Owned and run by me
Something for Weekend - My Bed
Tomo1971 is offline
Old 09-08-2008, 08:39   #7
Dr Zoidberg's Avatar
Mine had a very loud whistling noise and a lack of power (also an 06)
Alex
www.drzoidberg.co.uk
Dr Zoidberg is offline
Old 09-08-2008, 09:08   #8
Txt Spk Police
VRStu's Avatar
I don't think they like the long life servicing system so if you want to prolong the life of your turbo I'd consider going back to fixed intervals or doing an interim oil change.
SEAT have ditched the idea of variable on the deisels.
Stu
VRStu is offline
Old 09-08-2008, 10:40   #9
Members Car: Vectra 1.8VVT SRi
Well said VRStu. 20k is turbo suicide.
2008 Vauxhall Vectra SRi 1.8VVT, 140hp of pure tarmac ripping power.
Vectra owner and driver by night, Octavia driver by day...
_ZS_ is offline
Old 09-08-2008, 12:31   #10
I thought doing an interim oil change while on the variable played havoc with the system?
Steve
Tomo1971 is offline
Old 09-08-2008, 14:24   #11
Txt Spk Police
VRStu's Avatar
Steve
It 'may' confuse the oil quality sensor a little, probably meaning that actually you'll get to the maximum amount of miles per variable service however IMHO a risk worth taking to save your turbo, especially if your car is a 'keeper'.
I am on 10k intervals with my car. My last one was on variable but I did an interim change.
Stu
VRStu is offline
Old 09-08-2008, 14:29   #12
Members Car:
I think some (not all) VAG TDI turbos are being replaced when all they need is their turbo vanes freed up. IIRC the VNT turbos need to be given a bit of stick from time to time to keep the vanes/actuators moving freely.
As I heard it, if a TDI is driven quite gently and below 1,800 rpm all the time the moveable vanes can gum up, then when you do plant your foot it goes into overbooost as the vanes can't move to a more appropriate angle as the revs build up, so to protect itself from damage the engine goes into limp mode and records an error message.
This could be used by an unscrupulous service person as justification for a complete replacement turbo (rather than just freeing up the vanes, which is much cheaper than a new turbo). If the manufacturer (eg Skoda, VW) is paying for a warranty claim then the customer is unlikely to ask any questions.
Sprint Yellow 2008 Octavia II RS Wagon 2.0TFSI manual (Xenons)
White 2006 VW Transporter LWB van 2.5 TDI manual (camper)
gregozedobe is offline
Old 09-08-2008, 16:11   #13
sworrall's Avatar
so it would be ok to do a change at say 9 - 10k and stay on variable? Might consider doing this or get it switched to fixed after the warranty is up in october. Would you just need a new filter and plug as well as the oil?
2008 OctyII VRS Estate CR 2.0Tdi
Race Blue - 18" Zeniths - Sunset Glass - Maxidot - Dual Zone - Cruise - Jumbo Box/Rear Elec - Rear park - Active headrests - Curtain Airbags - MFD2 & OEM Bluetooth
my flickr Photos
sworrall is offline
Old 09-08-2008, 16:23   #14
Members Car: MK 2 Octavia
I have done exactly as you have suggested, filter and plug only £8 from dealers.
tezza72uk is offline
The Following User Says Thank You to tezza72uk For This Useful Post:
sworrall (09-08-2008)
Old 09-08-2008, 16:30   #15
Txt Spk Police
VRStu's Avatar
Yep that's it, new filter and plug along with about 4.5 litres (I would think) of PD oil.
Going to cost you circa £50 I should imagine.
Stu
VRStu is offline
Old 09-08-2008, 16:51   #16
sworrall's Avatar
heres a really dumbass question then as i guess its not in the manual. which side is the plug on and do you need to remove the undertray to get to it ta
my flickr Photos
sworrall is offline
Old 09-08-2008, 17:08   #17
Txt Spk Police
VRStu's Avatar
Should be very obvious when you remove the undertray.
Stu
VRStu is offline
Old 09-08-2008, 19:00   #18
sworrall's Avatar
cheers ears
while im asking are their any pics up as to why you can locate axel stands? never come across any on here
my flickr Photos
sworrall is offline
Old 09-08-2008, 19:04   #19
Txt Spk Police
VRStu's Avatar
Under the mounting for the console bushes.
Stu
VRStu is offline
sworrall (10-08-2008)
Old 09-08-2008, 19:48   #20
BRISKODA Staff
mannyo's Avatar
My turbo, which is original has just under 60K miles under its belt (2005,55 PD140) and the car has just had its 3rd variable service. Considering mine used to be a rental car before I got it, it seems to be ok especially because it must have had a hard life to start with.
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 09-08-2008, 23:01   #21
cheers ears
You can use a trolley jack with a rubber pad to lift on the offside front cill in the position marked with an arrow indentation seen when you open the drivers door. The under tray then needs to be removed, 11 torx headed screws. The sump plug is located at the rear of the sump and requires 30NM of torque when replacing it. To remove the filter cap you will have to remove the engine top plastic cover where the oil filler is, this is fixed by three pull off fixings, two at the front and one on the near side rear and then pulling the assembly forward from a rubber mount left rear. To remove the filter cap you will need a 32mm socket. The filter is a cartridge type and comes witha new 'o' ring for the cap. Replacing the cap will need a torque setting of 25NM firstly, and then a further 5NM. I bought 9 litres of Castrol Edge for £52 inclusive from ebay, and the filter + sump plug was £8 from a dealer. Hope this helps.
Old 10-08-2008, 08:56   #22
little jack's Avatar
I took my Octy 2 in for service. 55,000miles and it also needs a new turbo. 1.5 months before the warranty runs out. I'm very happy Obviously. other than that just an o/s/f wheel bearing and thats it. Reliable as usual.
When the flag drops the bullsh*t stops
little jack is offline
Old 10-08-2008, 23:36   #23
Members Car:
Mine is an 07 model Scout.
Was just whistley at first but got worse in recent weeks and now sounds like quiet police siren as mentioned in some of the other threads.
Care for it pretty well, always been partciularly careful not to switch it straight off after a run.
This is my 5th turbo-ed motor (3rd diesel one) never had any problems before.
Still, fingers crossed all goes well this week, very impressed by prompt attention from dealer so far.
Can I elect to change to fixed service intervals whilst it's under warranty?
Thanks for all the replies.
Zactor is offline
