39,394 Members 1,487,076 Posts
Nokia Hansfree Help
This is a discussion on Nokia Hansfree Help within the Octavia II forums, part of the Skoda Model Discussion Area category; Hello Group, this is my first post . I am on Octavia No3. The first was a 52 plate vRS, ...
Old 17-02-2007, 13:44   #1
Members Car: 2006 L&K 2.0TDi
Nokia Hansfree Help
Hello Group, this is my first post . I am on Octavia No3. The first was a 52 plate vRS, nice but on my 150 mile round trip each day to work my fuel bills were just to high , then came the new 53 plate 1.9 TDi L&K a quality car and now I have a new 56 plate 2.0 TDi L&K.
Enough of that, down to the question. I hope someone can help
I have just purchased a Nokia hands-free kit from eBay. I have bench tested it and it works ok as far as I can tell. But I am sure the tele-mute lead is wrong, the guy said it was Vdub but I am not so sure because it looks noting like the one I see on the net.
How does the radio come out ? I found the 4 screws the radio moves but gets stuck. Do I need to remove the front trim. If so how?
Thanks in advance
Mike
mikemc is offline
Old 17-02-2007, 14:32   #2
Re: Nokia Hansfree Help
Hi Me again. Just been reading some previous threads. Still none the wiser as to how to remove the trim and get the radio out. But one of the threads mentions that you do not need an extra loom to fit the phone just cut the nokia speaker leads off and wire them to the radio, then wire the mute lead.
Is this correct? If so it will save loads of money.
mikemc is offline
Old 17-02-2007, 20:02   #3
go green
mdk1's Avatar
Members Car: Roomy 3 & Fabia
Try VRStu website for info on radio removal,
Octavia-vrs.com
Mike.
Mine Skoda Roomster 3 TDI in matallic Anthracite Grey MK**LJK
Swmbo's Skoda Fabia 2.0I Elegance in Dark matallic Blue MK**LJK
mdk1 is offline
Old 17-02-2007, 21:14   #4
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
The Octy II uses CANBUS to switch the radio on and therefore doesn't have a switched live as we know it. The easiest way is to tap into the back of the fuse box using a proper terminal and fuse it up a the phone (In the phone position) My Phone is wired like this and the control unit is also hidden under there.
Stu
VRStu is online now
Old 17-02-2007, 21:32   #5
Thanks mike & Stu
Finally got it out. You have to be a bit forceful to get the front trim off. Open the ash tray and reach up then pull. After that with a stiff blade you can pop the clips one by one. The radio is jus 4 screws in each corner.
I was right the Nokia kit had an ISO telemute loom. It did not fit. Our local car audio shop sold a converter. It sort of works. Only the front speakers mute for the phone the rear keep blazing. The head unit does not say PHONE either. Tomorrow I will put it all back, I need to re-couple the cdplayer, reversing sensors etc.
I think I will get the proper telemute cable @£40 unless anyone can confirm and tell me how to wire it up without one
mikemc is offline
Old 17-02-2007, 23:16   #6
Txt Spk Police
VRStu's Avatar
Mine works perfectly without a fandango lead.
Like I said, you need a switched 12v supply, preferably from the fuse panel.
Have a look on my website under MFD2 install and you'll see the pinouts for the stream. You need to buy a plug to go into your qualock connector and the correct pre terminated cable.
Tel + is the speaker +ve
Tel - is the speaker -ve
Tel mute does what it says on the tin.
I'll see if I dig the numbers out for you.
Stu
VRStu is online now
Old 18-02-2007, 11:35   #7
Txt Spk Police
VRStu's Avatar
The plug is 12 Pin Green 3B7 035 447 B £3.76
The wires for it are 000 979 010 £1.29 Each. They come with 2 terminals per wire so you only need one if your dealer will allow you to order one but they are supposed to be in packs of 6.
I can't remember the number for the one in the fuse box off the top of my head, it is on here if you search or i'll post it up if I find it.
Stu
VRStu is online now
Old 18-02-2007, 12:05   #8
Stu, craking web site . I want an MFD display like that. Off to ebay now.
You are absolutely right i just was not thinking right yesterday. I can see it now it looks so simple. Radio has a built in telemute.
I just need to get the blue plug to go into the quadlock.
If you can find a part number it would be great. I will trawl RS for one, they must have it as it looks fairly standard.
Thanks
Mike
mikemc is offline
Old 18-02-2007, 12:08   #9
Thanks for info Stu, You post crossed with mine
mikemc is offline
Old 18-02-2007, 18:12   #10
Txt Spk Police
VRStu's Avatar
Mike I don't think you'll find the connectors at RS, they are pretty hard to come buy and in small quantities the ones from Skoda are fine.
The fuse box one will simply pop into the spare slot on the fuseway labled for the phone (Once you've released the catch of course). It will have the wire attatched as per the ones for the green plug.
It'll cost you much less than £10 and you'll be all sorted and connected just they way Skoda would do it.
I now have my phone connected to the MFD2 - works fine as well.
Stu
VRStu is online now
Old 23-02-2007, 18:47   #11
Hi Got it fitted this afternoon.
Stu was absolutely correct. YOU DO NOT NEED A SPECIAL CABLE.
I found that the idc connector from a pc had the same pin pitch. So I cut one down to 12 way then soldered the three wires to it. Power went to fuse.
Sorted.
Does any one now what the blue wire from the main 4 pin power plug does on a Nokia kit
Thanks
Mike
mikemc is offline
Old 23-02-2007, 19:11   #12
Txt Spk Police
VRStu's Avatar
The blue is your switched live or ignition sensing wire and the red a permanent live.
If you are mid call it will remain connected even if you switch the ignition off until you end the call.
Stu
VRStu is online now
Old 23-02-2007, 22:54   #13
great thanks
mikemc is offline
Old 24-02-2007, 17:56   #14
swing's Avatar
Members Car:
How easy is it to access this area - is the panel below the steering wheel simply held on with a couple of screws, or is it more complicated than that...?
I'm looking to possibly hide some wiring behind this panel, so am interested to know what's involved in taking the panel off (before I start...)
swing is offline
Old 24-02-2007, 18:20   #15
Txt Spk Police
VRStu's Avatar
Remove the headlight switch by pushing in and turning the kn0b to release the latches.
Pull off the silver trims either side of the steering wheel and undo the screws.
Stu
VRStu is online now
Old 24-02-2007, 21:08   #16
swing's Avatar
Members Car:
Sounds simple enough, thanks.
swing is offline
Old 24-02-2007, 23:46   #17
sworrall's Avatar
i did a search of this for my own benefit for when i get a handsfree kit for my m3100.
i think its this part number for the fusebox - 000 979 227
from thread - http://www.briskoda.net/forums/new-o...se+part+number
2008 OctyII VRS Estate CR 2.0Tdi
Race Blue - 18" Zeniths - Sunset Glass - Maxidot - Dual Zone - Cruise - Jumbo Box/Rear Elec - Rear park - Active headrests - Curtain Airbags - MFD2 & OEM Bluetooth
my flickr Photos
sworrall is online now
