39,391 Members 1,486,901 Posts
The notchy gear box on my mark II Octavia vRS
This is a discussion on The notchy gear box on my mark II Octavia vRS within the Octavia II forums, part of the Skoda Model Discussion Area category; I have noticed that the gear box on my new car is more notchy and cumbersome than I first thought. ...
Old 10-07-2006, 14:11   #1
Members Car:
Unhappy The notchy gear box on my mark II Octavia vRS
I have noticed that the gear box on my new car is more notchy and cumbersome than I first thought. It hasn't changed much since I bought it but I'm sure that when I had a test drive, the gear box was much better and quite slick.
Sometimes I have to really force it into gear. 1st and 2nd are usually fine but I struggle with 5th and 6th in particular which makes it difficult to manage speed control on motorways if you have to go from 40 - 70+ every so often. If the car is in neutral (which it is when coasting) and I want a quick change to 6th gear, I have to perform the gear maneuver quickly if I want to ensure it doesn't get stuck.
Have any of you experienced a similar problem with the vRS gear box or is it something I should have checked?
orinj is offline
Old 10-07-2006, 15:58   #2
mello in yello
postmanpat's Avatar
Members Car: fabia vRS/ octavia vRS
Re: The notchy gear box on my mark II Octavia vRS
Gear box is slightly notchy and occasionely reverse and first require a double clutch but 5th and 6th have caused no probs, do find changing smoothly into 2nd very hard at higher acceleration causing SWMBO to shout at me for treating her baby rough
Originally Posted by Emily-Elizabeth
Sperm donership: It is not like giving blood, it is tossing away...............
Postmanpats car Fabia vRS Zennons, ESP, autochanger, 3rd headrest, heated seats, cruise control
SWMBO Octy Mk2 vS maxidot, duel zone wotsit, cruise, parking sensors, 18" alloys
postmanpat is online now
Old 10-07-2006, 16:16   #3
Hardcore
Basil's Avatar
Members Car: Fabia vRS
I had a slight problem with 1st and 2nd - complained to the dealer and they adjusted it nice and slick.
I believe that the adjustment instructions on dieselgeek.com apply pretty well to the standard setup but I may be wrong (I often am.....)
Since yours is new, why not ask the dealer to take a look at the shifting - a new car shouldn't be anything but fairly smooth.
HTH
Cheers
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 10-07-2006, 17:05   #4
MrkyMrk's Avatar
Members Car: 06 Octavia vRS
Is coasting in neutral at motorway speeds a good idea? Does that have any adverse effect on the drivetrain in any way?
Mark
MrkyMrk is offline
Old 10-07-2006, 19:38   #5
GAFF's Avatar
Members Car: Octavia II vRS
Mines a little notchy but nothing to worry about.
GAFF is offline
Old 11-07-2006, 08:43   #6
Organist's Avatar
Mine was very notchy from 2-3. This has now gone away after 2500 miles.
Organist is offline
Old 11-07-2006, 11:39   #7
Members Car:
I've booked my car in for a check up in two weeks so they will take a look at it. I may just be a little fussy over it but there's no harm in having it looked at.
Thanks guys.
orinj is offline
Old 11-07-2006, 22:51   #8
dstev2000's Avatar
5th and 6th were fairly notchy initially to the point of scrunching 5th alot but all is well after 2200 miles. (Probably worn those horrid tooth things off the cogs ).
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
