This is a discussion on o2 4x4 diesel tank volume within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi! I have a (fairly) new O2 4x4 1.9 TDI. It should have a 60l gas tank, however whenever I ...
| Briskodian | o2 4x4 diesel tank volume Hi! I have a (fairly) new O2 4x4 1.9 TDI. It should have a 60l gas tank, however whenever I fill it up I'm never able to get more than 52l in it (and the computer says that I have enough diesel for 20 km - so it should be empty). Where could the problem be (I talked to the dealer, and he suggested a different kind of filling up procedure - I should not put the nozzle in as far as possible, but just to the first notch - but there was no difference). Any suggestions - the difference is almost 8l, which is too much to be acceptable... LetoII |
| Briskodian Join Date: Aug 2005 Location: Back in the Green
Members Car: 2 Octavia II's, an L&K combi and a vRS hatch. Thanks: 48
| Re: o2 4x4 diesel tank volume The range calculation has quite a big margin for error built into it, I had a Mk1 Octavia TDI and I was able to do at least 30 miles AFTER the computer said my range was down to zero. If you add that to your 20 miles that obviously gives you 50 overall. Take a ballpark figure of 40-50mpg that means there is AT LEAST 5-6 litres left when you fill up. I don't think you have a problem to be honest. I have never ever been able to fill any of my 3 Skoda's fuel tanks to the figure quoted in the book.
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() |
| Re: o2 4x4 diesel tank volume I thought the tank was 55L.
| Briskodian Join Date: Jun 2007 Location: South/Middle/then Up a bit
Members Car: Scout TDI Thanks: 9
| Re: o2 4x4 diesel tank volume I'm sure that when you are empty (maxidot displays '0' miles left in tank) that you still have at least 10-15 miles left in the tank similar to a reserve part of the tank, but even if I am correct it should still be nowehere an 8l difference.
__________________ Think_Outside_The_Box |
| Re: o2 4x4 diesel tank volume blimey whats this the thread of the quick posters!
| Re: o2 4x4 diesel tank volume IIRC the 4x4's have bigger tanks, I got proved wrong on this once before on here ![]() As it's an '02 I suspect it's a MkI, either that or a very early pre production MkII mule ![]() And to clarify- the 'reserve' part of the tank is when the fuel light comes on.
| Briskodian | Re: o2 4x4 diesel tank volume - the computer shows 20 km left, and I do around 6.1 l/100km (I have quite a few hills in the daily commute), and if there are 8 liters left in the tank, than I should be able to do 130 km with the fuel left (more than a 100 km difference is too much). - the o2 is not for the year (its failry new - 2007) o2 is for octavia 2 (so Mk2) - i did not expect to fill it up with 60l, but I should be able to use more than 86% of the tank and I expect the computer to be fairly accurate (with a up 30 km safety, but not 100). Tnx, Leto |
| Briskodian Join Date: Aug 2006 Location: Herts
Members Car: Octavia vRS TDI - Koni FSDs & RallyFlapz Thanks: 46
| Re: o2 4x4 diesel tank volume Correct according to the brochure/handbook. I routinely take my range down to 25/30 miles (I once went to 5 miles but haven't got the nerve to do so again) and then refuel with 50 - 52 litres. Straight forward and no problem.
__________________ Mine - '07 Octavia vRS TDI, Superchips BlueFin (210bhp/293lbft) 'Winter wheels' 7.5J x 17" Audi S-line, Ultrac Sessantas 225/45 17, xenons, rear parking sensor, heated seats (driver's Recaro Style full leather), climate/jumbo etc., Koni FSDs, Neuspeed Rear ARB & Short-Shifter, K&N induction kit, RallyFlapZ - Colin McRae memorial decals. Wife's - '08 Roomster Scout 1.6 Tiptronic, Cruise, parking sensors Son's - '02 Fabia 1.4mpi, vRS 16" alloys, Michelin Pilot Exalto 2 195/45 16, vRS front bumper, Koni Sport shocks. |
| | #9 | |
| Briskodian | Re: o2 4x4 diesel tank volume Quote:
Leto | |
| | #10 |
| Re: o2 4x4 diesel tank volume Do you mean the 4x4 has a 55L or 60L tank?
| | #11 |
| Re: o2 4x4 diesel tank volume The Scout has a 60l tank & as it is similar to the standard 4x4 I would have thought the same. Although it says different here........? attached is the techs for Scout
__________________ Think_Outside_The_Box Last edited by wilkopilko; 11-07-2008 at 16:31. |
| | #12 |
| Briskodian | Re: o2 4x4 diesel tank volume That is the problem I face..... The spec say my 4x4 has a 60L tank, but it behaves like it has a 55l tank.... could it be that the computer was programmed wrong? (and it thinks it has a 55l tank?) Tnx, Leto |
| | #13 |
Members Car: '97R BMW 328i Saloon Thanks: 679
| Re: o2 4x4 diesel tank volume I doubt it. Remember, 60l is the whole capacity, including any sump it may have etc... If you can get 52l in it with still some range, then that sounds perfectly normal.
| | #14 |
| Briskodian Join Date: Nov 2007
Members Car: Octy 1.9TD PD 4x4 Estate Thanks: 41
| Re: o2 4x4 diesel tank volume Hi Our 07 Octy 4x4 Amb has a 60lt tank, and warning light should come on when only 8 lts left in tank, followed by a beeping sound so they say. |
| | #15 |
| Briskodian Join Date: Oct 2003 Location: South East England
Members Car: White Octavia vRS Thanks: 6
| Re: o2 4x4 diesel tank volume Not sure if it applies to the Octy, but the Fabia has a device to prevent overfilling (a button in the filler neck) which if pressed, will release more volume. Do a search in the Fabia section.
__________________ Phil Thomas Then: Red Fabia vRS: Not quite standard .Now: White Octavia vRS: Eibachs/FSDs - Milotec B pillars - Neuspeed shifter (thanx Stu!). |
| | #16 | |
How much can you put in the tank when this happens... When my warning light comes on I can put only about 48L in the tank... Leto | |
| | #17 | |
Leto | |
| | #18 |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 200
| Re: o2 4x4 diesel tank volume If it's a diesel: do a search for "summer ventectomy" - you'll effectively have a noticeably bigger tank.... (I'm not making this up!) HTH Bas
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| | #19 |
| Briskodian Join Date: Apr 2006 Location: North Notts
Members Car: Mini 35LE, Audi A6 Avanr Thanks: 0
| Re: o2 4x4 diesel tank volume Hi, I know its off-topic but would you recommend this model? I am looking at an ad right now for an 05-plate 4x4 1.9 with 42k on for £11,000. Was set on a 2.0TDI but the budget won't stretch right now but I need a new car soon. Need to tow my caravan (1372kg max) so got to be a 4x4 for weight reasons unless anyone knows different.
__________________ Mine: '95 Audi A6 - Still going like the proverbial Swiss watch. Hers: '01 Peugeot 306 - Won't be much left to fall off soon. |
| Best Way Of Flushing The Diesel Tank?? | brian1.9diesel | Favorit, Felicia, Fun and Forman | 6 | 16-02-2007 21:25 |
| Fungal Growth in Diesel Tank ! | Td-eye | Fabia I | 9 | 06-11-2006 14:59 |
| Wash/wiper tank volume | orinj | Octavia II | 3 | 16-09-2006 12:37 |
| Diesel Fuel Tank | Toneboy | Octavia II | 17 | 30-05-2006 17:10 |
| New record - 10 european countries on one tank of diesel | RallyInfo | General Car Chat | 6 | 03-04-2005 01:11 |
