This is a discussion on Oct II vRS Aerial within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi there! What should I do with my Aerial whilst going through a car wash? I tried to remove it, ...
| Briskodian Join Date: Apr 2007
Members Car: 2007 Octavia vRS-TDi Thanks: 0
| Oct II vRS Aerial Hi there! What should I do with my Aerial whilst going through a car wash? I tried to remove it, but it wouldn't come off, just made it move up and down. Cheers, jsstevo |
| | #2 | |
| go green Join Date: Jan 2005 Location: Rochester, Kent
Members Car: Roomy 3 & Fabia Thanks: 163
| Re: Oct II vRS Aerial Quote:
| Briskodian Join Date: Jan 2006 Location: West Yorkshire
Members Car: MK11 Octavia vRS Thanks: 169
__________________ Current car: Black MKII Octavia vRS Combi Previous: Black MKI Octavia vRS Combi Black Fabia Elegance 100 BHP |
| Re: Oct II vRS Aerial Car wash??????? Are you mad? |
| Briskodian | Re: Oct II vRS Aerial There isn't a hosepipe ban anymore you know. ![]() |
| Briskodian Join Date: Aug 2005 Location: Back in the Green
Members Car: 2 Octavia II's, an L&K combi and a vRS hatch. Thanks: 48
| Re: Oct II vRS Aerial A car wash??? Never used one since my white van man days Unscrew the aerial and push if down so it's flat against the roof and tighten it back up to keep it in that position. It stops the ch@v pikey's from nicking it!
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() |
| Briskodian Join Date: May 2006 Location: Cork City
Members Car: Octavia II vRS Thanks: 1
| Re: Oct II vRS Aerial car wash will destroy the paint....loads here will agree! |
| Briskodian | Re: Oct II vRS Aerial And use 2 buckets. One to rinse the sponge/wash mitt out after you have rubbed it over the paint |
| | #9 | |
| Briskodian Join Date: Jul 2006 Location: Portugal
Members Car: Octavia 2.0 TDi Sport 2006 Thanks: 3
I washed my Octy only once in automatic car wash. I unscrewed antenna and laid it back, as it doesn't come out. When I got out, antenna was broken, holding together only by rubber surrounding. Now I have to change it, but still haven't because I only listen CD and never the radio. To change it, I have to brake the safety ball inside antenna support, so the whip will go out. After that I can screw simple VAG antenna in but it will never be theft free again. Or, I can go to dealer to change whole the assembly. So, if you go to automatic car wash, lay antenna back and stick it with adhesive tape to the back glass, that's the only way. By the way, other guys are right about destroying the paint.
__________________ Octavia 2006 2.0 TDI Sport (equal to L&K in UK) - 17' wheels, Sport suspension, Xenons, Audience with Sound System, Bluetooth, Front & Back Parking Sensors - - VAG COM - | |
| | #11 |
| Briskodian Join Date: Jan 2007 Location: Leverkusen Germany
Members Car: OctaviaČ vRS TDI estate Thanks: 5
| Re: Oct II vRS Aerial Unscrew the antenna, push it in and than pull it out (whilst holding the antennabase to the roof --> danger of denting the roof!). When it doesn't come out the first time, try it again. It worked with mine, took it out and grinded the anti-theft ring away. So I can always remove the aerial before getting the car washed.
__________________ Silver 2006 vRS-TDI estate, mostly std, just a couple of mild changes. Roofrack, alarm, heated rearseats, VW RNS 510 + CD-changer, sunsafe + Climair sonniboys, cruisecontrol, , HillHold, interior superflux leds, original SonyEricsson FSE with K810i, BBS RD394 16" winterwheels, polished BBS VZ033 (CH) 18" summerwheels. |
| | #12 |
| Re: Oct II vRS Aerial UPDATE!!! I few Polish guys have set up a hand car wash near my house so they cleaned it for me. 3 guys spending 20 minutes on it for a Fiver! Included washing, waxing, drying, tyre treatment and all seals cleaned. |
| | #13 |
| Re: Oct II vRS Aerial My brother had his Astra SRI washed at one of those polish places and they scratched the f**k out of it. Some are good, some are bad. At least car washes are consistently cr@p.
| | #14 |
| Briskodian Join Date: Apr 2007 Location: croydon, surrey
Members Car: Octavia mkII 2008 1.9 tdi elegance Thanks: 0
| Re: Oct II vRS Aerial the mistake you guys are making, other than using an auto car wash in the first place, is to leave the aerial in situ- do not unscrew it or loosen it, leave it in upright position, its very flexible and will bend with the brush going over it. Dont worry it wont break, well not in my case anyway, have often used auto washes due to needing to keep car clean so often for my job as a taxi. Never had problem whilst leaving the aerial up on any of the cars that I have had since 2001. Just be brave and leave it up - your more likely to do damage if you unsrew/loosen the aerial.
__________________ |
| | #15 | |
| Briskodian Join Date: Mar 2003 Location: Midlands
Members Car: Audi A3 Thanks: 9
