This is a discussion on Octavia 2 audience bad FM receive within the Octavia II forums, part of the Skoda Model Discussion Area category; Hello! I have in my Octavia radio Audience. I am very disappointed because It's bad receive of FM stations. What ...
| Briskodian | Octavia 2 audience bad FM receive Hello! I have in my Octavia radio Audience. I am very disappointed because It's bad receive of FM stations. ![]() What can I do that radio will have better receive? Bye Trdonja |
| | #2 | |
| Briskodian Join Date: Jul 2005 Location: Northern Ireland
Members Car: MkV Golf 1.9 TDI Thanks: 0
| Re: Octavia 2 audience bad FM receive Quote:
__________________ Johnny "Americans have different ways of saying things. They say "elevator", we say "lift" ... they say "President", we say "stupid psychopathic git." | |
| Briskodian | Re: Octavia 2 audience bad FM receive I already had my car at my dealer. He replaced my radio with new one and the situation was the same. Is possible that I have bad antenna? Trdonja |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 200
| Re: Octavia 2 audience bad FM receive Very likely - I believe the antenna is powered (active). It gets a 12Volt supply from the original Skoda radio. The antenna has a signal booster built in to its base. If the built-in antenna booster is not working you would get poor FM reception and almost no AM reception. If you have the original Skoda radio your dealer would need to check the antenna wiring perhaps replace the antenna. Hope this helps you, Bas
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| Briskodian | Re: Octavia 2 audience bad FM receive Problem with receive is only when I am driving around. When I stop the car radio receive pretty good. I also compare my radio with radio in Golf 5. Radio in Golf receive very good also when I am driving around. Any solutions? Thank you. Bye Trdonja |
| | #6 | |
| Ding, dong Join Date: Sep 2003 Location: in the doghouse
Images: 4 Thanks: 4
| Re: Octavia 2 audience bad FM receive Press and hold the menu button when in FM and you will see infomation about the station, including signal strength. You may need an FM booster
__________________ Jeff: Ambitious, but rubbish Quote:
