This is a discussion on Octavia II rear lights within the Octavia II forums, part of the Skoda Model Discussion Area category; I noticed yesterday that the side light element (5w) of both the stop and rear fog lights is not working ...
| Briskodian Join Date: Feb 2008
Members Car: Octavia 2.0 d/ Felicia 1.3 Thanks: 3
| Octavia II rear lights I noticed yesterday that the side light element (5w) of both the stop and rear fog lights is not working on its own when the side lights are turned on. Instead the (21w) element is glowing and gets brighter when either the stop or rear fog is turned on. Could this be a bad connection somewhere? The LH fog does not work at all but the RH does. Both sides show the same problem. |
| Briskodian | Re: Octavia II rear lights Does a bulb warning light come on on the dash ?? As I understand from the handbook, if the tail lamp fails, it uses the brake light albeit at a lower voltage to keep the rear of your car safe! Obviously when you brake it ups the voltage, to show braking.
__________________ Octy II 2.0 (?Turbo?)DI Plus some RWD stuff.Next trip from Scunthorpe & Doncaster http://briskoda.net/midlands-skoda-m...26-oct/125071/ |
| The Following User Says Thank You to gcr31463 For This Useful Post: | 3whinfield (12-05-2008) |
| Briskodian | Re: Octavia II rear lights oh & there's only a rear fog on the driver's side |
Members Car: '97R BMW 328i Saloon Thanks: 679
| Re: Octavia II rear lights Yep, its the car being clever and substituting for a blown bulb. ![]()
| The Following User Says Thank You to Tom_vRS For This Useful Post: | 3whinfield (12-05-2008) |
| Briskodian Join Date: Jul 2005 Location: Northern Ireland
Members Car: MkV Golf 1.9 TDI Thanks: 0
| Re: Octavia II rear lights That's right. There's one on the other side too but it needs to be programmed to operate. 1 offside foglight is sufficient to comply with UK legislation. With regard to faulty lamps, as already pointed out in the previous posts, a failed sidelight is automatically compensated for by using a brake lamp with reduced output. My understanding is that once the backup lamp 'so to speak' fails, the dashboard lamp fail warning light comes on. John
__________________ Johnny "Americans have different ways of saying things. They say "elevator", we say "lift" ... they say "President", we say "stupid psychopathic git." |
| The Following User Says Thank You to Johnnyc For This Useful Post: | 3whinfield (12-05-2008) |
| Re: Octavia II rear lights Thanks guys but unfortunately I have checked the bulbs and they are all intact. Also no dash warning lamp. Is it possible to get a wiring diagram so I can follow it through. Johnny C how can I programme the second fog light to work? Andy |
| Briskodian Join Date: Jul 2006 Location: Portugal
Members Car: Octavia 2.0 TDi Sport 2006 Thanks: 3
| Re: Octavia II rear lights See if connector is fully pluged in. Once I've had the same problem on Avensis just after picking it up new from the dealer. Arrived home and found that plug was not fully inserted. It was pluged but not all the way in. Just pushed it till it clicked and everything started working fine. Worth to check.
__________________ Octavia 2006 2.0 TDI Sport (equal to L&K in UK) - 17' wheels, Sport suspension, Xenons, Audience with Sound System, Bluetooth, Front & Back Parking Sensors - - VAG COM - |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 11
| Re: Octavia II rear lights the other fog can be enabled with vag com/ |
| Octavia Rear Courtesy Lights | Foxy | Octavia I | 12 | 10-02-2007 17:14 |
| New Octavia rear lights | skidude | Styling and Car Care | 1 | 17-11-2005 16:34 |
| Can octavia 2 rear lights fit octavia 1 | cacorat | Octavia I | 2 | 21-09-2005 11:47 |
| Octavia rear lights | monkeychild | Styling and Car Care | 8 | 14-04-2004 23:10 |
