Octavia Security
This is a discussion on Octavia Security within the Octavia II forums, part of the Skoda Model Discussion Area category; We have a 55 plate Elegance with the 140 bhp and DSG BOX.Happened to be talking about alarms on our ...
Old 04-02-2008, 12:50   #1
Post Octavia Security
We have a 55 plate Elegance with the 140 bhp and DSG BOX.Happened to be talking about alarms on our cars with others and what they have. One of the things spoken about was interior sensors for movement etc and i realized that ours has none apart from the central locking.I left a window open and set the alarm and afterwards put my arm through the open window and nothing happened, so if someone broke the window they would get away with anything left in the car . I would have thought that Skoda would have auto closing of windows when locking the car and other deterant features otherwise all we have is bog standard locking. Any thought / comments on this.
fortyfirs is offline
Old 04-02-2008, 13:01   #2
Default Re: Octavia Security
I'm sure you did this but got to ask! Did you wait something like 30 seconds, maybe a minute after you set the alarm before putting your arm through the open window? Sometimes the interior sensing waits before setting.
2007 Octavia Hatchback, 2.0TDI DSG L&K in Black Magic.
runboy is offline
Old 04-02-2008, 13:03   #3
Chris.G's Avatar
I have the interior monitoring and auto closing of windows (if you keep your finger on the lock button on key fob). My Octy is by no means top spec.
I thought all Octys came with these features What model do you have? oops just re read that first post, you have an Elegance. You should therefore have all of the above.
Check the B pillar for a small switch located under the upper seatbelt mounting. This is the switch for turning off interior monitoring.
Chris.G is offline
Old 04-02-2008, 13:28   #4
Thats a cracking post. I had forgotten about that button. Well done
Ray_Green is offline
Old 04-02-2008, 14:13   #5
The interior sensors are located where the sunglasses holder is on the roof lining. I locked myself in the car to test it when I first got the car and they didn't work. The dealer repaired it under warranty by installing what they called a new 'sonic sensor unit'. The switch on the drivers 'B' pillar disables the interior sensing if you leave kids/pets in the car.
tomo2001 is offline
Old 04-02-2008, 18:42   #6
dstev2000's Avatar
I deadlocked my apprentice in mine and it went mad after 20 seconds or so, the alarm siren is a bit limp wristed IMO.
Also (IIRC), pressing the lock button on the fob TWICE will do the same as pressing the B pillar button, disabling the interior monitoring and deadlocks.
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
Old 04-02-2008, 22:06   #7
Go Gadget Octy!
Also check you only press the lock button ONCE
Unlike many other marques, pressing twice DISABLES the interior sensors and deadlocks!
Lick the window of life
Why not join the Briskoda Last.fm group?
gadgetman is offline
Old 04-02-2008, 23:31   #8
2.0 FSI Sport.
smstext's Avatar
Exactly what i thought when i first read the post and beaten to it!!
smstext is offline
Old 05-02-2008, 17:44   #9
dstev2000's Avatar
You can both bugger off, I got there miles before you two
SWMBO's: MY08
vRS TDI - Standard
Old 06-02-2008, 19:13   #10
Thanks Guys for info .First i retried the window open and held the top locking key pressed in for a few seconds and hey presto the window came up and closed, so thats out of the way , however when it came to that switch on the pillar it showed red so i clicked it and with window open and alarm on it still failed to activate with my arm waving all around the spectacle case sensor , so i suppose i will have to take it to dealer and see whether the sensor is working or not .Will let you know results .Cheers.
Old 07-02-2008, 12:13   #11
GAFF's Avatar
Mine also wasn't working and was replaced, the replacement gave some intermittant faults with the alarm going off for no reason so it was replaced again (AFAIK theres a newer version of the unit as the garage were aware of it the minute I mentioned it).
GAFF is offline
Old 10-02-2008, 19:22   #12
phiL&K's Avatar
Does the above present a fault code in VAG COM?
Daily car - Octy2 L&K estate - Black Magic
Other Car - Mk1 Audi TT Coupe V6 3.2 Manual
Past Cars - Octy 1 L&K estate, Octy 1 Elegance, Audi TT 1.8 225 coupe,A3 170pd Quattro Sport
VAG-COM Hex-USB. Gotta tweak!!
phiL&K is offline
Old 10-02-2008, 21:28   #13
ECUless
fordfan's Avatar
I scanned one the other day where it said that the interior sensors were faulty, tested as above and the alarm did not go off.
fordfan is offline
Old 13-02-2008, 10:57   #14
Today i went back to dealer to have the interior sensor rectified but after about an hour the workshop said it could be a wiring fault and they would require it for further investigation, so it goes back tomorrow as today i have other commitments. Will let you know what happens.
Old 13-02-2008, 18:18   #15
Does It Really Matter. No-one Round Our Way Takes Any Notice Of Alarms, Wonder If I'd Be Just As Good With A Flashing Led As My Mate Did In His Car Ages Ago
Burnsey
1.9 tdi Octy II elegance estate
(gone but not forgotten... 2.5v6tdi Superb, MkI Octy 1.6)
Burnsey is offline
Old 14-02-2008, 08:34   #16
In reply to Burnsey the answer is yes ,one reason is that the warranty ends this October and i would like to get most things done by then .
Old 14-02-2008, 19:48   #17
Just an update regarding interior motion sensor not working. It was found that on the fault finder it had several faults which it seemed mislead the fitter but fitting another sensor has cured the problem, am happy bunny again .
Old 14-02-2008, 20:50   #18
The security on them must be good. The Cutns had to burgle my house whilst we were in to get the keys to my vRS in order to steal it. And my wife'sA3. Got them back though within the hour. BiB were pretty good
Steve
From Tavia vRS 230bhp to Impreza WRX STi Version V Type R to Clio 182 Cup and now a vRS TDi Octy II in Lightning McQueen Red
Steve vRS is offline
Old 14-02-2008, 22:30   #19
GAFF's Avatar
Was this at me? Is so I'm not sure as I don't have VagCom to check ....sorry about the delay in posting
GAFF is offline
Old 05-05-2008, 14:08   #20
bajanpete's Avatar
hi, i have somewhat the same problem, the 2004 octy ambiente estate i drive has central locking and the remote works, but when i lock or unlock the car, the indicators don't flash. the car deadlocks, and the red light in the driver's door blinks but the indicators don't flash. why is that?
bajanpete is offline
The Following User Says Thank You to bajanpete For This Useful Post:
wega3k (06-05-2008)
