39,394 Members 1,487,197 Posts
octavia vrs diesal compaired 2petrol vrs
This is a discussion on octavia vrs diesal compaired 2petrol vrs within the Octavia II forums, part of the Skoda Model Discussion Area category; going 2 change my octy vrs petrol mk 2 for the diesal vrs in jan i need some advice' is ...
Old 27-06-2007, 19:57   #1
Members Car: rs, soon to be new rs
going 2 change my octy vrs petrol mk 2 for the diesal vrs in jan i need some advice' is it worth it or would it be a let down thanks 4 ur input
conor----
Conor M is offline
Old 27-06-2007, 20:03   #2
Ex-Moddy
Makefish's Avatar
Members Car: Golf PD105
Re: octavia vrs diesal compaired 2petrol vrs
I suppose it depends on what you are looking for in a car, if fuel economy is an issue then of course the diesel will make more sense but I have seen the petrol version make an average of 39.4mpg iirc on a long run which is pretty impressive. My choice would be and is the petrol 2.0T FSI, a cracking engine but owners with the diesel are just as happy
Note: Thread moved to a more appropriate forum.
Superchips Bluefin only £390 @ JKM
http://www.jkm.org.uk/performance/bluefinxmas2008.htm
Makefish is offline
Old 27-06-2007, 20:09   #3
Steve vRS's Avatar
Members Car: Tavia vRS TDi
Surely any saving in MPG would be more than countered by the deprecation loss?
The TDi is a good cruiser and motorway car but I bet the petrol engine is a bit more exciting to cane.
Steve
From Tavia vRS 230bhp to Impreza WRX STi Version V Type R to Clio 182 Cup and now a vRS TDi Octy II in Lightning McQueen Red
Steve vRS is offline
Old 28-06-2007, 07:37   #4
bahnstormer vrs's Avatar
conor----
If you are thinking of changing what factors are pushing YOU to the vRS TDI?
For me, as I considered both before buying a TDI, they were (not that I had a vRS TFSI first mind you), in no particluar order;-
1. Lower CO2 emissions to give lower Company Car Tax - saved £850pa
2. Better Fuel Consumption by about 10mpg - I do 20,000 mile pa at my own expense
3. Lower Insurance by 3 groups, meant I could get my 19 year old son covered as an occaisional driver (insurers would not cover him in a TFSI) - Lucky b*****.
4. Lower depreciation
5. I sort of just LOVE diesels anyway. The vRS TDI gives you a tsunami of torque and a growl like a Grizzly Bear on heat on full throttle.
On the down side;
1. The handling of the TDI is not quite as sharp on turn in with a touch more understeer due to the heavier engine
2. The rev range is narrower (2,000 to 4,500rpm as opposed to 2,000 to 6,000+ rpm), but as the 6 speed Gearbox is fantastically good to change gear, with the ratios being close and neatly spread this is not a real issue, and
3. It is a few tenths slower 0-60 and a couple of mpg light on Vmax; but the in gear times are a gnat's apart so in the real world it makes no difference.
Other than that - to look at they are both EXACTLY the same so who else but you will know the difference (and don't anyone give me the "you sound like a tractor as you drive past a bus queue" routine - I couldn't give a monkey's about that).
bahnstormer vrs is offline
Old 28-06-2007, 07:40   #5
Steve
Don't get this!
The TDI has better fuel consumption by around 10mpg AND lower depreciation; so WIN WIN, surely.
Old 28-06-2007, 07:52   #6
welsh vrs's Avatar
Members Car:
All the above reasons Tax, Ins, Mpg etc. Slightly down on performance but still a great car.
Was Mk1 Black Magic Octy vRS...
Now Mk2 Sprint Yellow Octy vRS TDi...
welsh vrs is offline
Old 28-06-2007, 08:38   #7
Members Car:
I was reading somewhere that to make a diesel "pay" so to speak, you should be driving around the 20,000 miles a year mark. Don't know how this relates to the VRS.
Certainly for the last couple of years Diesel has been more expensive at the pumps than unleaded. Just my luck, when I go back to a petrol car, diesel is suddenly cheaper at my local garage....
Wild Rover is offline
Old 28-06-2007, 08:43   #8
Off beat thought;
Evo magazine did a road test/economy run with a Toyota Prius Hybrid vs. a FIAT Panda 100hp and. apart from the fact they had a darn sight more fun in the Panda, they calculated that it would take something like 200 - 250,000 miles for the Prius to make itself 'pay'.
Back to the thread;
Would a vRS owner care whether their car 'pays' or not?
Old 28-06-2007, 08:44   #9
FocusZtec's Avatar
The main reason for me not going for the diesel over the petrol was the DPF fault on the 170TDI engine - I dont always get a chance to do the 50 miles or whatever is recommended, a lot of my driving is unfortunatly in traffic. I also only cover around 7,000 miles a year and my insurance is very cheap hence the petrol model for me.
I have driven the VRS TDI however and been VERY impressed.
Lee
http://img.photobucket.com/albums/v610/FocusZtec/neiloctypipersignature.jpg
Thanks to JKM:
REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!!
FocusZtec is offline
Old 28-06-2007, 09:04   #10
Torque is cheap
exFiesta's Avatar
The DPF fault could well be a large factor as it was for FocusZtec, depending on what your normal driving routine is.
I'm a little concerned (I've ordered the TDI), but we'll see (my driving distances vary massively during hockey season/not). I'm sure I wont mind making a few extra long trips to keep the DPF in order.
SWMBO:
Fabia Elegance 1.9TD
New: Race Blue Octavia II vRS TDi Estate, Cruise, Curtains, Rain, Jumbo, Rear Electrics, Dual Zone Aircon, 18" Rims, Maxi-Dot, Sunset
Old: Silver Octavia I vRS
exFiesta is offline
Old 28-06-2007, 09:25   #11
VRS195's Avatar
Diesel servicing should be cheaper in theory, as they can go almost 50% further between services if set to VARIABLE.
Also if you want a wider rev band get it chipped, you will get another useful 500+ rpm at the backend of the band ("rev limit" pushed up to 4.75/5k).
Doesn't sound much, but bear in mind the standard band is realistically 2k-4.25k, you are adding 22% flexibility.
You should also technically sneak something off the frontend of the band aswell as chipped output will reach standard output (340NM@2,000) about 200 rpm earlier as well) - giving 31% increase in flexibility.
see here:
http://www.superchips.co.uk/curves/vag20tdi170.pdf
I think the Panda stats of 250,000 miles were mostly down to the fact that:
a) they cost about the same to actually run (fuel/tax/servicing etc)
b) the Prius is TWICE as expensive (and 50% heavier!! - not good for the environment) at £16-20k vs Panda's £8-10k price.
Black Pearl vRS 204PD COMBI
Factory Options: ALL (bar the front parking sensors and anti-whiplash head restraints!)
VRS195 is offline
Old 28-06-2007, 09:45   #12
Members Car:
When I was choosing between the 2 last November I spent an afternoon alternating between my local Skoda dealers diesel demonstrator and a used petrol version they had. Ignoring the fuel economy and I still prefered the diesel. I drove both on all sorts of roads and unless you thrashed the petrol the diesel was much faster.
In addition I preferred the handling and feel of the steering on the diesel, the roads were dry but the extra weight made the front end feel a lot more positive with much better turn in.
Each to their own and all that, but I'd suggest finding a good dealer who will let you do what I did before making a decision.
badgersport is offline
Old 28-06-2007, 10:49   #13
Members Car:
Hi,
As a relatively high mileage driver 23,000 since September, mostly motorway miles I can confirm my car averages about 43 to the gallon, it now needs new tyres, and it required a service at 18,000 miles which cost £193.00. And yes it is a vRS TDi, I did have a problem with the DPF, but that was sorted within a couple of weeks.
The thing I really like is not having to change gear on the motorway, 6th is fine for almost all occasions, the thing I dislike is 18" wheels, it makes the ride harsh, but then I am comparing it to a Superb or vRS MK1.
Its my own car, I probably paid over the odds as I had the first one in the UK, but am I happy with it, well yes, but I would like a few more MPG, which I can get if I stick to 60-65 on the motorway, but who wants to be a middle lane hugger.
Cheers,
Dwain
Racing Blue Vrs TDi, Silver BMW K1200R
dibbley is offline
The Following User Says Thank You to dibbley For This Useful Post:
bahnstormer vrs (28-06-2007)
Old 28-06-2007, 11:56   #14
Originally Posted by dibbley View Post
Hi,
Cheers,
Dwain
I'm up to 5,000 miles now and not had a squeak out of the DPF. I do a 25 mile each way commute including M'way AND like using full throttle when appropriate (mainly a long uphill slip road each morning) which will probably help.
Harsh, jittery ride is down to the shocks not, IMHO, whether you have 17 or 18 inch wheels. Cured by fitting Koni FSDs.
Old 28-06-2007, 13:10   #15
Steve vRS's Avatar
Originally Posted by bahnstormer vrs View Post
Don't get this!
I meant that the amount you would have already lost on the petrol car changing to a TDi would not compensate for the better mpg of the diesel.
Steve
The Following User Says Thank You to Steve vRS For This Useful Post:
Old 28-06-2007, 13:29   #16
Steve
Ah; got it!! Quite right too.
What you are suggesting means; why does one not just keep the TFSI vRS?
Old 28-06-2007, 14:17   #17
Steve vRS's Avatar
Lemon entry my dear Watson!!
Steve
Old 28-06-2007, 18:08   #18
cheers for all the feedback i think i will have 2 get a diesal for a feiw hours and give it a lash local dealer says next one in is july i will check it out . my gut feeling is go for the diesal vrs . thanks again. conor.
Conor M is offline
Old 29-06-2007, 19:47   #19
I had the same mind battle when I bought my Leon FR. I went for diesel. Chipped it. Love it. In buying the VRS (due in next week) I drove the TDi but bought the petrol version as although the TDi is very flexible and loads of torque, you can't beat the extra revs of the petrol engines and the added "go faster" noises compared against the diesel. I'll be keeping the Leon though as I now do 35k a year commuting to work (which wasn't the case when I bought it).
PREVIOUS VW GROUP MOTORS :- 2001 Audi S3 (Revo, N75J, Samco Hoses, Forge DV006), Golf V5 (170bhp), MkII Golf GTi 8v.
CURRENT CARS :- Octavia VRs TFSi - 18", dual zone climate, coolbox/armrest, rear parking sensors. VRSTU Cruise, Maxidot and Bluetooth - need FSD's/Revo/Quickshift/Intake.
Leon FR TDi 150 (Revo, Allards clutch plate, 18" RS6's).
s3akr is offline
Old 31-07-2007, 20:10   #20
thanks again for the feedback drove the tdi 170 the other day very little between them,it seems heavier on the road but it goes like stink going 2 order one for jan just got 2 more dealers 2 go and see who gives best price;
Conor M is offline
Old 01-08-2007, 00:00   #21
Members Car:
Had my unmodified Octy vRS TDI for 7 months now and no real problems apart form a faulty allen nut which meant loosing oil engine oil. On the way back from a mountain climb in my native Scotland I 'accidentally' booted it into a rally jump on a bend. Not only did the Octy stay level but when it eventually met the tarmac executed a perfectly tight (on the right side of the road) turn. Think it might benefit from the better grade Shell fuel.
little_bey is offline
Old 01-08-2007, 17:27   #22
workman's Avatar
Members Car:
aaaa.....yes? is that not why skoda brought out the tdi-vrs, for company car drivers?
but surely that's one point of a 'sporty' petrol engine? if someone does not want to thrash (in my experience you don't need to thrash the t-fsi to make good progress) an engine, petrol, why buy a sporty car?
workman is offline
Old 02-08-2007, 12:37   #23
Aspman's Avatar
Members Car: Octavia VRS TFSI
I drove them both with a couple of days between them. There is remarkably little between the two cars. The petrol TFSI is very flexable with a lot of torque. It'll quite happily pull in 6th on the motorway (and that's with less than 1k on the clock).
Before I bought I sat down and worked out my costs. I'm a relatively average mileage driver 8-12k per year. For me the higher purchase cost of the diesel and the higher mpg canceled out to make both cars cost about the same over 3 years.
I didn't take depreciation into account because I intent to keep the car beyond 3yrs.
I did factor in insurance with the TFSI being higher but in the end the ins cost was about £300 lower than I expected. Benefit of the Skoda being a slightly lower risk (I assume) and me turning 30.
So with them both costing the same, I decided to have 200bhp and a better noise.
I've not found the 18" wheels too bad at all. Benefit of car sharing in my mates Ibiza with rock hard suspension and low profiles I suppose.
The TazZone Forums
Aspman is offline
Old 02-08-2007, 15:38   #24
jlwah's Avatar
I have a vRS TDi Estate on the 18" wheels and although I think it rides much better than the Leon FR Tdi on 17" wheels, I still think the VRS would benefit from more compliance in the suspension. IMHO it would improve ride and possibly handling (particularly on the UK's 'third world' roads we now have to endure).
How much are the Koni's and is the difference really noticeable?
(And before anyone asks why I didn't get an L&K instead, I probably would have if it came with the 170ps diesel engine option!)
jlwah is offline
Old 03-08-2007, 00:38   #25
Ex-Moddy
Makefish's Avatar
Koni FSD's are fantastic , around £350 iirc.
Makefish is offline
