This is a discussion on octy II 57 plate stalling at low speed / gear changes... within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi is it my imagination or does the octy II stall at low speed when changing up/down from neutral if ...
| Briskodian | octy II 57 plate stalling at low speed / gear changes... Hi is it my imagination or does the octy II stall at low speed when changing up/down from neutral if not revving the engine... I thought engine was sposed to be flexible and able to cope. My old ford focus could but may be its clutch was warn/higher I tend to find it stalls when moving from neutral, ie when cruising not in gear, when slowing down in traffic, etc.. but still always still faster than walking speed Diffciult to rev the engine while doing this? Now tell me I'm missing the point or a bad driver - rather that than have a problem with the car Thanks |
| Briskodian | Re: octy II 57 plate stalling at low speed / gear changes... does not happen with my octyII PD. in fact i never touch the accelerator pedal to pull in 1st or reverse even while going uphill. it does stall occasionally when i try to get past a speed hump in 2nd. it should never stall in neutral. something could be wrong. |
| octy II 57 plate stalling at low speed / gear changes... | chris pearson | Octavia II | 0 | 04-01-2008 00:50 |
| Fabia vRS 6 speed gear kn0b....will it fit Octy vRS?? | Steevie Wonder | Maintenance & Performance | 3 | 07-05-2007 20:57 |
| Felicia 1.6 Slxi - very low idle speed, stalling when hot | Clive618 | Favorit, Felicia, Fun and Forman | 9 | 21-11-2006 21:22 |
| Top gear at low speed? | gillywibble | General Car Chat | 16 | 08-09-2006 07:33 |
