This is a discussion on Octy Vrs fault code reset within the Octavia II forums, part of the Skoda Model Discussion Area category; i really sorry if this has been raised before i have a a quick scan through all the post and ...
| Briskodian Join Date: May 2007 Location: weston-Super-Mare
Members Car: A 03 Plate magic Black Skoda Octavia VRS Thanks: 1
| Octy Vrs fault code reset i really sorry if this has been raised before i have a a quick scan through all the post and not much came up. i have a fault on my Octy that is intermittent and the garage cant find anything wrong with it. can i clear the fault codes form the ecu so when it happens again it is the only thing registered on the ecu so the garage can fix it .
__________________ Cheers Moo ( catch you one the flip side ![]() Green intake system, center exhaust box removed, DE-lock kit, shark fin aerial, custom boost gauge install, color coded grill surround, custom amp and sub install, |
| Re: Octy Vrs fault code reset Yes you can, but they will only spot it if it records a fault or there is a short enough time between the fault occuring and the car getting to them. Remember if you clear fault codes (even if no codes are present) it will reset the readiness codes of the car and it will take two to three drive cycles for them to work themselves out again. |
| Briskodian Join Date: Jun 2006 Location: Newcastle upon Tyne
Members Car: Octy II VRs 200 Thanks: 10
| Re: Octy Vrs fault code reset Surely if the fault registered it should be the last thing on there anyway.
__________________ 06 Skoda Octavia VRs 200 bhp (Black) Coming soon: 58 Skoda Octavia VRs CR TDi (Candy White) Previous Cars: 04 Audi TT 3.2 V6 250 bhp (Black) 02 VW Golf V5 170 bhp (Black) |
| Briskodian Join Date: Aug 2006 Location: Watford
Members Car: Mondeo 2.2TDCI Thanks: 21
| Re: Octy Vrs fault code reset Whats the problem? Do you know anyone with Vag-com?
__________________ Octavia VRs ***SOLD*** The futures somkey! The futures diesel ![]() |
| Re: Octy Vrs fault code reset i don't know anyone with vag com but the garage reckon it is something to do with the secondary exhaust system ??????? but they have changed all the pipes and the exhaust pump!!!!! i was going to have a play myself see if i could sort it thats why i need to reset it get the garage to read the code then try and fix it lol its happened about 3 times i take it to the garage and then after about three days the light comes back on! i know i have a small leak from the boost gauge i fitted that i have rectified thats why i want to reset the codes. could someone explain more about theses readiness codes what to they do ????
| vRS TD Fault code help | mr.nik | Octavia II | 2 | 08-03-2008 13:21 |
| Power steering fault - fault code 01288 - is this the normal plastic sensor fault? | mgskoda | Diagnostics & VAG-COM | 6 | 05-11-2007 19:31 |
| octavia vrs fault code | millsyman22 | Octavia I | 0 | 10-10-2006 13:22 |
| fault code 17664 on octy tdi | nitrovrs | Octavia I | 2 | 16-08-2006 19:33 |
| D.I.Y. Error code reset - Where to get VAG-COM for PDA?? | sixman9 | Maintenance & Performance | 8 | 15-11-2004 14:56 |
