This is a discussion on Petrol gauge within the Octavia II forums, part of the Skoda Model Discussion Area category; Im posting this on behalf of my father-in-law. Its a 06 Octy Vrs with 6k on the the clock. The ...
| Briskodian | Petrol gauge Im posting this on behalf of my father-in-law. Its a 06 Octy Vrs with 6k on the the clock. The problem hes having is the petrol gauge sometimes wont work. It just sits on empty. Its done it 5 times now in a year. Can anybody suggest what the problem could be and whats involved in fixing, ie garage job or not Thanks in advance |
| Skoda-da-da-da Join Date: Aug 2006 Location: Manchester, Northampton
Members Car: L&K Thanks: 12
| Re: Petrol gauge Hi...That happens with our Pool car (1.9tdi Octy) Only tends to happen after being in stop start traffic for a period of time! If you flick the ignition on and off again, it sorts itself out. Was going to point it out at the next service. If anyone has any answers for this, might be interesting. Cheers |
| Briskodian Join Date: Aug 2006 Location: Herts
Members Car: Octavia vRS TDI - Koni FSDs & RallyFlapz Thanks: 46
| Re: Petrol gauge I know it is not a solution; but meanwhile you can use the 'Range' function on the Computer/MFD, so you know how much further you can go. I have found this to be very accurate. |
| | #4 | |
| Re: Petrol gauge Quote:
Not my car so not bothered, but would be interesting to know if it is a common problem. | |
| Re: Petrol gauge |
| Briskodian Join Date: May 2005 Location: Ethe, Belgium
Members Car: Octavia 2 Elegance, 1.9 tdi DSG Thanks: 1
| Re: Petrol gauge Not necessarily. In fact, I'd say that the range function is working properly. If the gauge is telling the trip computer there's no fuel in the car, then wouldn't you expect it to indicate "--" (since range = present consumption multiplied by fuel remaining)?
__________________ John Pritt Ethe, Belgium Octavia 2 Elegance, 1.9 tdi 105, DSG Last edited by johnpritt; 23-05-2007 at 12:16. Reason: my maths o-level was too long ago... |
| Re: Petrol gauge Like i said, its intermittent and only happens after stop start traffic. Not worth the effort till the next service. Like I said its a Pool car...which gets abused! I think a dodgy fuel gauge will be the last of its worries when it's 3 years are up. |
| Briskodian Join Date: Jan 2005 Location: South East Midlands
Members Car: Skoda Octavia Elegance 2.0 TDi DSG Thanks: 2
| Re: Petrol gauge Gotta be a warranty job: straight off to the dealer, I'd say! |
| Briskodian | Re: Petrol gauge I had this exact problem in the Leon but only after filling the petrol tank to the max. It would also go to zero and show -------. The first time I actually saw the fuel gauge go to zero and almost had a heart attack. Knowing that I had just refilled and seeing no massive pool next to the car, I knew it was a meausurement problem. Never got it fixed since it didn't happen that often and wasn't that bothered. David |
| | #10 |
| Briskodian Join Date: Feb 2007 Location: East Sussex and Sometimes North Yorks. and sometimes in between!
Members Car: Skoda Octavia VRS Thanks: 32
| Re: Petrol gauge Guy I work with has an Audi TT and has the same problem...
__________________ Octavia Mk 1 VRS, Black Magic |
| | #12 |
| Briskodian | Re: Petrol gauge I would suggest that it sounds like the tank sender unit or the wiring to it that is at fault.
| | #13 | |
| Go Gadget Octy! | Re: Petrol gauge Quote:
On my Mk 1 I had this happen a few times over 3 years. Put it down to a vaccum in the tank, or another think on the Mk1 was that when you opened the filler cap the range went to ---- and the fuel gauge went a little screwy for a moment. Accidentally knocked the release button once when on the motorway, didn't realise, and thought I had a hole in the tank!!! | |
| | #14 |
| Briskodian | Re: Petrol gauge My 2.0TDI does the same. The guage just drops to zero ans I loose the range indicator. My best guess is the sender unit. I was going to wait until the next service but it's getting more frequent so I think I'll be off to the dealer shortly! |
