Please help muting reverse parking beep!
This is a discussion on Please help muting reverse parking beep! within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi all, the beep is really boring to me, especially when I pray that my two babies keep sleeping... Do ...
Old 22-07-2008, 15:02   #1
Genoa1893's Avatar
Default Please help muting reverse parking beep!
Hi all,
Do you know where it is, so that I can definitely shut it off (or highly dampen it)?
Thank you,
Ste
'08 RaceBlue vRS TDI, 18" Zenith, Xenons, Rear park assist, Jumbo box, Maxidot, Bluetooth and phone cradle, Climatronic off tweak, Tweaked Tweeters, remapped by UK.
Genoa1893 is offline
Old 22-07-2008, 15:21   #2
eccleshill's Avatar
Default Re: Please help muting reverse parking beep!
You need this
eccleshill is offline
Old 22-07-2008, 15:47   #3
Genoa1893's Avatar
LOL!
At least two of them, indeed!
Ste
Old 22-07-2008, 16:08   #4
skodayouth's Avatar
Originally Posted by Genoa1893 View Post
Hi all,
Thank you,
The volume of the beep can be changed with VAG-COM, I have done this on my Fabia II
Skoda Octava II Estate 1.9DSG Elegance
Anthracite Grey
Skoda Fabia 3 1.6 Tiptronic
Storm Blue
skodayouth is offline
Old 22-07-2008, 16:18   #5
dan_the_v8man's Avatar
im sure you can turn it off with the stream headunit, in the settings theres an option to turn beep off, i believe that should have the desired effect as i have mine turned on and thats the only beep my car ever makes
57 Mk2 2.0TFSI vRS Estate in Race Blue, jumbo box, cruise control, dual zone climate, zenith 18", maxidot, xenon's, rear parking sensors, light assistance, sunset glass
dan_the_v8man is offline
Old 23-07-2008, 22:10   #6
Genoa1893's Avatar
Dan, thank you but even this evening I could not find the damned option by looking in the menu available on my stream MP3 hu.
Have you idea of its name? I tried to turn off PDC and BEEP and the damned parking beep kept boring me...
Ste
Old 24-07-2008, 00:16   #7
PDC volume in the Stream settings, turn it way down, 1 is almost silent.
Milk Inc's newest #1 fan
sebulbus is offline
Old 24-07-2008, 00:38   #8
I'd need to check the manual or when I'm next in the car but thought pdc volume was to decrease volume of radio when engaging reverse gear so you can concentrate better. Set this up when I got the car and haven't touched it. Guess you could always just park on an uphill section or a drive thru' space to avoid reverse gear altogether
It's all in the second or third screen after pressing the music note symbol then the > button once or twice.
Burnsey
1.9 tdi Octy II elegance estate
(gone but not forgotten... 2.5v6tdi Superb, MkI Octy 1.6)
Burnsey is offline
Old 24-07-2008, 08:52   #9
I believe that is the case.
wega3k is offline
Old 24-07-2008, 09:35   #10
Genoa1893's Avatar
I'm pretty sure I had turned it to "off" rather than turning to 1 (via the volume knob, I guess even if it seems I have only a ON/OFF option). Then I selected reverse gear and it was still here...
Anyway, today I will try again. Perhaps a "reboot" is needed ?
Ste
Old 24-07-2008, 22:03   #11
Genoa1893's Avatar
Angry Re: Please help muting reverse parking beep!
Just to repeat once more the beep stays.
The PDC controls radio volume not beep volume.
Anyone knows where is located the f....g buzzer? Sooner or later I'll get rid of it!
Ste
Old 24-07-2008, 23:46   #12
bosnjo's Avatar
As soon as you put into reverse, press "P" button. It is the button that you use to switch parking sensors on and off, on the bottom line of buttons, bellow AC:
http://img108.mytextgraphics.com/pho...-48xgq1w49.jpg
I was reversing today to my garage and remembered your problem, As soon as it started to beep, I pressed the button and it muted the "beep, beep", so I kept reversing and sound didn't come back. You have that button, don't you, if your car came with factory sensors. Also, I guess there is the way to dissable it via VagCom.
Octavia 2006 2.0 TDI Sport (equal to L&K in UK)
- 17' wheels, Sport suspension, Xenons, Audience with Sound System, Bluetooth, Front & Back Parking Sensors -
- VAG COM -
bosnjo is offline
Old 25-07-2008, 07:56   #13
bahnstormer vrs's Avatar
Whats the point of having Parking Sensors if they don't beep?
The beeper is AFAIK located somewhere in the rear three quarters, nearside I think, of the car behind the boot linings. Shouldn't be too difficult to locate it; put some tape over one of the senors, ignition on, select reverse, get the beeper and start listening.
Once located; wrap the beeper in some cotton wool with tape for security to muffle the beep. Job done?
Mine - '07 Octavia vRS TDI, 'Winter wheels' 7.5J x 17" Audi S-line, Vredestein Ultrac Sessantas 225/45 17, xenons, rear parking sensor, heated seats (driver's Recaro Style full leather), climate/jumbo etc., Koni FSDs, Neuspeed Rear ARB & Short-Shifter, K&N induction kit, RallyFlapZ - Colin McRae memorial decals.
Wife's - '08 Roomster Scout 1.6 Tiptronic, Cruise, parking sensors
Son's - '02 Fabia 1.4mpi, vRS 16" alloys, Michelin Pilot Exalto 2 195/45 16, vRS front bumper, Koni Sport shocks.
bahnstormer vrs is offline
Old 25-07-2008, 08:25   #14
Briskoda Staff
VRStu's Avatar
The initial beep is designed to give you an indication that the sensors are working. As has been said before the volume can be altered.
As for the button on the dash, that is only fitted if you have front sensors on the car.
Stu - Freedom Pimp
Stu's Car - 2007 Octavia vRS, Race Blue, Xenons, Columbus Navigation, Rear Parking Sensors, Maxi Dot, Light Assist, Jumbo Box, 18" Alloys, Stu's Cruise Control & OEM Integrated Bluetooth Telephone.
Something for Weekend - 2002 Lotus Elise RaceTech, Gunmetal, Radio, Carpet Mats.
VRStu is offline
Old 25-07-2008, 08:56   #15
Genoa1893's Avatar
Thank you all,
@Bosnjo and VRStu: I'm pretty sure I have not the "P" button, even if car was factory fitted with rear parking sensors (so VRStu is right, strange isn't it?). So, assuming Skoda saved on that button, would it be possible to try to remove the button and find a tab under it, remove and get the button magically muting the beep? (a-la climatronic off tweak?).
@bahnsormer_vrs: The car was standard factory fitted with them. I never used nor needed parking sensors (even if the beautiful painted bumpers worried me a bit). Besides they're set up at a threshold which is unreal for our "average" parkings. Not owning a VAG-COM I decided to physically look for the buzzer and dampen it. Thanks for the suggestion on its possible position.
Ste
Old 25-07-2008, 09:06   #16
Briskoda Staff
VRStu's Avatar
Wishful thinking I'm afraid.
Stu - Freedom Pimp
VRStu is offline
Old 25-07-2008, 09:52   #17
bosnjo's Avatar
Oh, didn't know that.
- VAG COM -
bosnjo is offline
