This is a discussion on 'Service Now' message at 5,000 miles?! within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi guys, Im after some advice on my MY08 Petrol VRS. When I picked the car up I was told ...
| Briskodian Join Date: Aug 2005 Location: North London
Members Car: Octy 4x4 1.8T Elegance Hatch Thanks: 29
| 'Service Now' message at 5,000 miles?! Hi guys, Im after some advice on my MY08 Petrol VRS. When I picked the car up I was told that it had been setup for fixed annual servicing. After taking advice from here I decided to ask the local dealer to change this setting to 'variable. When you held in the trip reset button and started the car; I always got the time until the next service was due, however it always seemed a very low number (around 8,500 miles when the car had only so far done 1,000!) I checked the remaining mileage just last weekend, thinking that it would adjust to the variable setting and give me a truer, higher reading. However, upon checking I get the message 'SERVICE NOW'. ![]() The car currently has 5k on the clock (5 months old); stating the obvious but surely it isnt really requiring a £200 trip to the dealer already?! Would I get any further indication if the car 'really' needed its first service. Any advice greatfully received. ![]() Lee
__________________ ![]() Thanks to JKM: REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!! |
| Briskodian Join Date: Aug 2006 Location: Liverpool
Members Car: Nothing :-( Thanks: 52
| Re: 'Service Now' message at 5,000 miles?! Same thing happened with mine... they "forgot" to reset the service indicators ![]() Take it in to your dealers and they'll sort it for you.
__________________ I was just a figment of your imagination! After nearly two years and a hell of a lot of fun, I'm off - all the best to everybody; this is Robbo signing off! |
| The Following User Says Thank You to robb06210 For This Useful Post: | FocusZtec (05-02-2008) |
| Ex-Moddy Join Date: Jul 2005 Location: Hampshire
Members Car: Golf PD105 Thanks: 187
| Re: 'Service Now' message at 5,000 miles?! Agreed, there is no way your car should need servicing after just 5,000miles. If you're on variable (all new cars leave the factory on this servicing schedule) expect a first service somewhere around the 15,000 mile mark, give or take a few thousand miles.
__________________ Superchips Bluefin only £390 @ JKM http://www.jkm.org.uk/performance/bluefinxmas2008.htm |
| The Following User Says Thank You to Makefish For This Useful Post: | FocusZtec (05-02-2008) |
| Re: 'Service Now' message at 5,000 miles?! Cheers guys. When I picked the car up - the dealers said they change the VRS to fixed (even though it still has the 'variable' factory oil in there still!) After seeking advice here I decided that was over the top and just guessing I'd say they do it so you see them sooner, therefore more income maybe? Local dealer disagreed and leave all their cars on variable as set from the factory. I'll drop my local dealer a call tomorrow. Cheers chaps. ![]()
| Briskodian Join Date: Jul 2006 Location: Portugal
Members Car: Octavia 2.0 TDi Sport 2006 Thanks: 3
| Re: 'Service Now' message at 5,000 miles?! I've had the same problem, but the fault was mine: I was looking at the trip computer the wrong way, the way you say: "Hold the button and then start the car...", and having "Service now" message. Now I use the other way and everything seems fine: 1) Fasten the seatbelt 2) Turn the ignition on (don't start the car) 3) Hold the trip/reset button untill message appears. Try it, it may work for you as it worked for me.
__________________ Octavia 2006 2.0 TDI Sport (equal to L&K in UK) - 17' wheels, Sport suspension, Xenons, Audience with Sound System, Bluetooth, Front & Back Parking Sensors - - VAG COM - |
| The Following User Says Thank You to bosnjo For This Useful Post: | FocusZtec (06-02-2008) |
| | #6 | |
| Re: 'Service Now' message at 5,000 miles?! Quote:
![]() Using this exact method displays that I have 5200 miles or 200 something days left. Not sure what i did wrong previously but I now feel more comfortable with that. ![]() Thanks (and sorry for the false alarm!) Lee
__________________ ![]() Thanks to JKM: REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!! | |
| Re: 'Service Now' message at 5,000 miles?! Happy to hear your problem was solved. And, don´t be sorry. Ivé done exactely the same mistake using trip computer and almost went to dealer to ask what was going on. It was this forum that adviced me to do a reading the other way and now it works fine. Then I've checked owner's manuals and there it says exactely the way this forum was saying. So, as a conclusion, I think I'm too samrt and don't need owner's manual. Lesson learned and now whenever there is doubt I forst look for the answer in manuals and just then, if there was no answer, I ask others or go to a dealer. I don't want to be ashamed by a dealer asking "Have you looked at the owner's manuals?".
| Briskodian Join Date: Dec 2005 Location: North Midlands
Members Car: Skoda Octavia 2.0 TDi L&K Thanks: 0
| Now I'm confused!! My Octavia II (2.0TDI L&K) is fast approaching 2 years old and 18,000 miles, and I've yet to see the "Service Now" indicator. I was wondering if it was actually working! But if you press the trip reset button as described don't you just reset the trip odometer? CJJE |
| Re: 'Service Now' message at 5,000 miles?! To answer my own question... OK so the answer is that you hold the button in to get the servicing information! Mine tells me I'll need my first service in 1300 miles or 38 days (that's 18500 miles and 2 years 2 weeks from new)! CJJE Blue Storm Octavia 2.0TDI L&K |
| | #10 |
| Briskodian | Re: 'Service Now' message at 5,000 miles?! Having looked at this Forum regardind next service on variable i followed the sequence and got 6500 miles to go which would make 15000 miles to that service, however what does the 13.5 mean at the side of the mileage?. |
| Service after 5,000 miles | hobnob | Octavia II | 4 | 16-09-2006 09:36 |
| cost of a 50,000 miles service?? | jamestay1 | Fabia I | 2 | 12-02-2006 10:52 |
| cost of a 50,000 miles service?? | jamestay1 | Fabia I | 1 | 11-02-2006 17:25 |
| 10,000 miles and no service indicator | neilwilliams | Fabia I | 18 | 06-04-2005 16:41 |
