This is a discussion on Should I have a washer fluid filter? within the Octavia II forums, part of the Skoda Model Discussion Area category; I've just got a octavia vrs, whilst topping up the washer fluid I noticed there was no mesh filter in ...
| Briskodian | Should I have a washer fluid filter? I've just got a octavia vrs, whilst topping up the washer fluid I noticed there was no mesh filter in the filler neck. My old fabia had one to stop grim getting in whilst topping up, should there be one? Thanks |
| Briskodian Join Date: Jan 2004 Location: Wirral, Merseyside
Members Car: Octavia Estate L&K, DSG. Honda Jazz SE Sport Thanks: 5
| Re: Should I have a washer fluid filter? Yes, there should be one. |
| Re: Should I have a washer fluid filter? Not on the Octavia 2 no. It takes so long to fil the bottle as it is due to the nature of the filler neck a filter would make it painfully slow so they didn't bother with it. However a regular filter will fit. |
| Briskodian | Re: Should I have a washer fluid filter? Cheers. I'll get the dealer to get me one then, I've got to speak to the dealer about the naff valet job anyway.(supaguard I dont remember asking for. Found half a packet of chewing gum a lighter and various polish/cleaner not removed properly). Thankfully the car makes up for the naff dealer! |
| Briskodian | Re: Should I have a washer fluid filter? Oh. I've got a vote for yes there should be and a vote for no there shouldn't. Reading the manual (p262) it mentions a filter in the washer container. Anyone else? |
| Re: Should I have a washer fluid filter? Well having PDi'd a lot of new Octavias and serviced a fair few I have never seen one fitted. |
| Re: Should I have a washer fluid filter? Sorry! I've just looked and there isn't one! I could have sworn I saw one on our new Octavia; must be remembering the one on the old Fabia or perhaps the brain cells are just wearing out! |
| Briskodian | Re: Should I have a washer fluid filter? Ah, cheers for the replies. Sorry for doubting you Lummox didnt realise your background. Thanks for looking bertj. |
| Briskodian Join Date: Aug 2005 Location: Back in the Green
Members Car: 2 Octavia II's, an L&K combi and a vRS hatch. Thanks: 48
| Re: Should I have a washer fluid filter? I can verify i've seen 2 Octavia II's that do NOT have filters on the washer bottle fillers. As Lummox says it's frustratingly slow filling it up as it is ![]()
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() |
| | #10 |
| Briskodian | Re: Should I have a washer fluid filter? Slighty off topic, should I of had a warning that the fluid was running low? My old fabia vrs would warn me. The first I knew I needed more fluid was when I ran out when I most needed it. |
| | #11 |
| Briskodian Join Date: Jun 2005 Location: Canterbury, Kent
| Re: Should I have a washer fluid filter? Yes, on the New Octavia (sounds a bit like New labour, doesn't it?) there should be a flashing warning on the Maxidot.... Oh, you do have a Maxidot, don't you...? |
| | #12 |
| Briskodian | Re: Should I have a washer fluid filter? No maxidot I'm afraid. |
| | #13 |
| Briskodian Join Date: May 2005 Location: Southampton, England
Members Car: Skoda Fabia VRS and Skoda Octavia II 1.9 Tdi Thanks: 9
| Re: Should I have a washer fluid filter? You should still have an audible warning and a light on the dasboard to indicate that your washer level is low. |
| | #14 |
| Briskodian Join Date: Aug 2006 Location: Herts
Members Car: Octavia vRS TDI - Koni FSDs & RallyFlapz Thanks: 46
| Re: Should I have a washer fluid filter? I've not got one. Can't see that having a filter will make any difference to how quickly I'll be able to refil the screenwash. Do I understand correctly, from earlier posts in this thread, that a filter from, say, a Fabia will fit my Octy? If so I'll go and get one. |
| | #15 |
| Briskodian Join Date: Dec 2003 Location: Middlesbrough
Members Car: New Octavia vRS Thanks: 0
| Re: Should I have a washer fluid filter? I can confirm that a Fabia filter will fit perfectly! |
| | #16 |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 11
| Re: Should I have a washer fluid filter? my 07 octovia doesnt have one, so i discovered last night. |
| | #17 |
| Re: Should I have a washer fluid filter? |
