This is a discussion on Signs of DMF wear? within the Octavia II forums, part of the Skoda Model Discussion Area category; What are the signs of this...? On my car under load when pulling away there's a rumble sound? and when ...
| Briskodian | Signs of DMF wear? What are the signs of this...? On my car under load when pulling away there's a rumble sound? and when in neutral there like a relaease bearing rumble sound which dissapears when i depress the clutch pedal? Is this a grumbling dmf? Cheers Dom |
| Not anymore Join Date: Oct 2007 Location: Bournemouth
Members Car: Octavia TDi 2006 Thanks: 107
| Re: Signs of DMF wear? Its quite possible DMF or clutch related.Common problems on these.
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon ![]() Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red Paul ![]() I only live for GTA IV |
| Briskodian | Re: Signs of DMF wear? Car is easy to stall, you can almost feel a bounce when going on and off the gears, a rubbing noise isn't all that common but I have had a bearing go sounding like that.
| Briskodian | Re: Signs of DMF wear? Dunno about bounce, but it's hard to get a smooth change of gear from 1st to 2nd...? It's like it has a some nanny state on the clutch pedal that won't release it when i want to? The BMW's have some sort of valve to protect the drivetrain, that controls the speed which the clutch is let out quickly, do these cars have a similar system? Cheers for the replies... |
| Briskodian | Re: Signs of DMF wear? No idea, but that sounds like the DMF is on it's way out if smooth gear changes are a problem.
| dmf | perrazi | Fabia I | 20 | 29-08-2008 10:10 |
| DMF Video. | Verr_Err_Ess! | Maintenance & Performance | 8 | 12-03-2008 22:46 |
| DMF Problem | guineapig | Octavia II | 8 | 11-03-2008 17:25 |
| DMF Headache | jonny boy | Fabia I | 9 | 25-05-2006 13:40 |
