This is a discussion on Single Mass Flywheel Conversion within the Octavia II forums, part of the Skoda Model Discussion Area category; Does anyone know of a single mass flywheel for the 2.0 TDI? I know devonmikeyboy was running one on his ...
| Does anyone know of a single mass flywheel for the 2.0 TDI? I know devonmikeyboy was running one on his slightly fettled 2.0 TDI. I heard skoda do an SMF kit for taxi's but is this for the 1.9 only or does anyone know if they do one for the 2.0? Thanks
| Briskodian Join Date: Mar 2008 Location: Sheffield
| why do the taxi's get special treatment?
__________________ 57 Mk2 2.0TFSI vRS Estate in Race Blue, jumbo box, cruise control, dual zone climate, zenith 18", maxidot, xenon's, rear parking sensors, light assistance, sunset glass |
| Not anymore Join Date: Oct 2007 Location: Bournemouth
| Because we drive the sh*t out of them ![]() ![]() ![]()
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon ![]() Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red Paul ![]() I only live for GTA IV |
| Because they go through DMF's at a rather fast rate as they are not really suited to that sort of driving. Oddly enough Taxi will probably know who told me about this too. The DMF seriously is a brain-dead bit of over engineering backed up by manufacturing down to cost.
| Hmm I have a spare SMF from a SDi, wonder how that would work? Not sure on sizes, will have to check.
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| | #6 | |
| Quote:
Will be having a chat with skoda, but I think I'm fairly certain yet another DMF is starting to fail on me. ![]() Oddly enough there was an Honest John article in the paper that was questioning if modern dervs are worth it now due to DMF and turbo issues they all seem to have.
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. | |
| hmm so whats the point in a dmf?
| It supposedly reduces vibration by damping the link between the crankshaft and the gearbox. However, if you boot it at very low revs (mechanically unsympathetic IMHO), you can mash the internals...
__________________ |
| had a dual mass flywheel on my focus tdci, all i know is the ecu used to cut the engine out at about 800rpm to protect the dmf, as a result it was the easiest car in the world to stall and went with one hell of a bang when it did stall
| | #10 |
| The focus did protect it's DMF on the 115 1.8 TDCI, but still one died on the fathers car. IIRC the ford garage said it was common on that engine. A DMF is IMHO bad because if you have always driven diesel using the low revs then you can't drive how you are used to driving. When I say from low revs I don't mean booting it from low, just using the torque to pull you around most places below 2k rpm and save fuel. After all that is the whole point of a derv, not having ot rev it hard to get around. The DMF has springs in it that compress every time you accelerate so they are eventually going to wear out anyway. They are obviously not, IMHO, strong enough for a high torque engine and hence the problems people are seeing in all brands of car. Basically IMHO, a heavier SMF would have damped the car just fine as would a small pre injection of fuel or a number of things which are simpler in design that a DMF. In all the cars I've ever drive we have never replaced a flywheel even on ones doing 150-250k miles. Sure both of those had a new clutch, but then the cars were been driven by 2 or 3 people and one or more of those were new drivers. It now looks like 80k is standard for a new clutch and flywheel. I've been through more than one of both and the car hasn't even hit 50k yet.
| | #11 |
| mines was the 1.8 100 tdci, does the vRS TFSi have a dmf then?
| | #12 |
| No idea on the petrol engines I'm affraid.
| | #13 |
| Yes it does. ![]() The clutch is 240mm on both vehicles, and I understand they have the same gearbox and flywheels too. However the TFSI isn't as agressive with the torque, so should be more durable. ![]() |
| | #14 |
| Is this a G60 Flywheel and clutch and am i reading that correctly that it is for a 2.0 TDI or should it read 2.0, tdi and 1.8t? Performance Cafe - VW & Audi Parts - Aftermarket & OEM Valeo do a kit but it doesn't mention the 2.0 ![]() Valeo Service UK and Eire (Unitedkingdom - EN) If so that seems a damn sight better than eating DMF's every 6 months ![]()
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. Last edited by cheezemonkhai; 12-05-2008 at 14:29. |
| | #15 |
| Briskodian Join Date: Aug 2008 Location: Sweden
| Will replace the DMF on my vRS TDI 2007 next Monday... The new flywheel/clutch kit is made by ZF Sachs; P/N 883089 000034 This is a complete kit with solid flywheel and organic clutch, just the releaser is missing Have done this DMF to SMF conversion on a Volvo V70 2.5T including the Sachs clutch, no problem except for a very heavy clutch pedal... The clutch designed for the 2.0 TDI will survive up to 530Nm of torque I will report more later, good news and eventually bad news Bye from Sweden |
| | #16 |
| Interesting that is thanks Spoke to SUK last week and asked them about a SMF for 1.9 but they no nothing about it and CZ don,t talk technical to public enqiuries.Mine is needed to be done soon as its juddering like crazy now and when you drive in 4th at 30mph or lower its juddering most of the time.
| | #17 |
| Give Kate at JKM a call. They told me they had a 1.9 DMF conversion, but that the 2.0 was in the works a good few months back now. On that note I'd be fairly confident if there is one available for the 1.9 they will be able to supply and fit it for a fair price.
| | #18 |
| Thanks mate
| | #19 |
| Briskodian Join Date: Jan 2008 Location: .ro
| I'd book it in before they'd have to tow me out of some busy junction.
__________________ Milk Inc's newest #1 fan |
| | #20 |
| Site Sponsor Join Date: Sep 2006 Location: Portsmouth
| Hi Guys, Yes SACHS Clutch kit and flywheel modules for both the 1.9 and 2.0 TDI engines are now both available. These kits replace the troublesome dual mass flywheel with a high quality billet steel one and a specific heavy duty clutch with torsion damper. The retail price on both kits is £864.91 plus VAT Fitting is £250 plus VAT You also need to allow a few extra pennies approx £20 or so for new bolts etc. Not fitted one as yet, but SACHS have had great feed back from customers who had them fitted direct by of SACHS during the testing period. Kind Regards Kate
__________________ The Premier VAG Servicing, Diagnostic & DYNO DYNAMICS ROLLING ROAD Tuning Centre VAG 2.0 TFSI Performance upgrade Specialists REVO | Superchips & Bluefin software | Emerald K3 ECU Specialists Visit the JKM website and Online Store at: www.jkm.org.uk |
