This is a discussion on Slight Judder at idle within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi folks Dunno if its just me but every so often when my car is sat at idle i get ...
| The Stig Join Date: Jan 2007 Location: Folkestone
Members Car: Race Blue vRS TFSI Hatch Thanks: 47
| Slight Judder at idle Hi folks Dunno if its just me but every so often when my car is sat at idle i get a slight judder and the rev counter needle moves ever so slightly. its as if the fuel isnt burning properly or something. its hard to explain it without you being sat in the car. This only happens once the car is warmed up and i only notice it when im sat at a set of traffic lights or in traffic etc. Its not the fuel as i use 100 octane fuel and ive tried 95, 97 and 98 octane an it still does the same. i even had the car doing 153mph (according to my tom tom) to see if it was just because it had been doing short jouneys and needed a good blast to clean the system out. But it still did it. Before anyway says that illegal i live in germany and its perfectly legal on the autobahn Is this normal as the car is only 3 months old and has covered 2800 miles. Everything else is fine with the car. no loss of power, acceleration or warning lights etc Cheers in advance Carl
__________________ "And when he gets to heaven to Saint Peter he will tell... One more Soldier reporting Sir... I've served my time in Hell"Mods done so far : Revo Stge 2, Forge Adjustable Spacer, Forge Diverter Valve, Miltek CBE, Evoms, Stu's Cruise , Autotech Fuel Pump, Xenons Upgrade, Koni FSD, Eibach Springs, Forge Short Shifter, VF Torque Arm Insert, NGK Iridium Plugs, Sachs Clutch & Flywheel, MFD3 Mods to come: KO4 Conv, LSD, Big Brakes |
| Briskodian | Re: Slight Judder at idle Mine does it as well and in addition from cold runs rough, almost as if it is off one pot - bought it back to the dealer to see if the ecu needed a reflash, they assured me they could not find any fault codes and that there was no new software availible. However I had both lambda probes replaced, it is now better from cold but still shudders when hot, so unfortunately I can offer you no solutions except to say you are not alone. |
| Re: Slight Judder at idle Ok Cheers at least i know im not the only one Carl
| Liberty City Join Date: Aug 2006 Location: Cardiff
Members Car: Octavia II 2.0 TDI DSG Elegence Thanks: 15
| Re: Slight Judder at idle I have this 'feature' too when the engine is cold.... |
