39,445 Members 1,489,346 Posts
Snap noises from dash - Modification to Centre Storage Area
This is a discussion on Snap noises from dash - Modification to Centre Storage Area within the Octavia II forums, part of the Skoda Model Discussion Area category; I’ve had an annoying Cracking/Snapping noise from the centre of the dash for ages. Very noticable on Cold days when ...
Old 18-01-2008, 06:53   #1
GAFF's Avatar
Members Car: Octavia II vRS
I’ve had an annoying Cracking/Snapping noise from the centre of the dash for ages. Very noticable on Cold days when the heating is put on. Also on undulating roads I was getting it the whole time. Pressing under the Centre Air Vents would simulate the problem and after removing the Centre Storage area for a few days there was silence.
Pic 1
Shows Hole after removal. To remove, Level under front of the Centre Vent with an up and out movement and pull vent out towards rear of car to remove. Don’t forget to disconnect the Hazard Light Switch, press on tab and remove (see Octavia-vRS.com - MFD2 Install Guide). See Pic 2 for the Storage/Vents assembly prior to modifying)
Pic 1
Pic 2
1a shows the bare Hard Dash Plastic under the top layer. Initially I thought this might be the cause of the problem, as the Storage Clip locators (Pic2) might have been rubbing off the Hard Plastic.
Pic1a
Pic 1b
Put some tape over the Hard Dash Plastic, and also around the 5 Clip Locators see Pic3 shown by Orange Arrows, 3 clips on the bottom and the ones on either side. Also see Pics 4 & 5.
I also put some tape shown by Red Arrows, as there was 2 pieces of plastic coming into contact.
Pic1b
Pic3
Pic4
Pic5
I found the problem was a little better but was still occurring. I removed the Storage Compartment again after a few weeks.
Pic 6
This time I took some tape and overlapped it on itself a few times, basically to make a “spacer or filler material”. I cut it into sections of approx. 10x20mm, doubled it up and squashed it into the positions shown by Yellow Arrows. Pic 6a shows a close up, along with other views in Pic 7 & 8
The whole Storage Assembly seems to be in 2 pieces if you like and the rub against each other.
Pic6
Pic6a
Pic7
Pic8
Pic9
I decided to tape the back of the Storage area to ensure it wasn’t rubbing off anything.
Pic9
Finally I gave any areas I thought might rub a good spraying with Hotls Rubber & Nylon Spray (just thought I’d try it).
The problem seems to have gone now having had it done a few weeks. There’s been a lot of cold morning so that’s a good thing. Pressing under the centre vents no longer makes that cracking noise.
GAFF is offline
Old 18-01-2008, 07:00   #2
GAFF's Avatar
Re: Snap noises from dash around Centre Storage Area
GAFF is offline
Old 18-01-2008, 07:04   #3
GAFF's Avatar
GAFF is offline
The Following User Says Thank You to GAFF For This Useful Post:
runboy (18-01-2008)
Old 18-01-2008, 11:51   #4
runboy's Avatar
Members Car: Octy II L&K 2.0TDI DSG
Re: Snap noises from dash - Modification to Centre Storage Area
Bloomin heck! Nice guide - not sure I'll need it but well done for sharing the info!
2007 Octavia Hatchback, 2.0TDI DSG L&K in Black Magic.
runboy is offline
Old 18-01-2008, 13:14   #5
pdhealy's Avatar
Members Car: Skoda Octavia vRS
You have way too much time on your hands Gaff.... when you're down this way in May, bring your hoover - my car needs a lot of TLC
PS: I have found on previous cars that single sided foam tape (or the woolly side of velcro) is best for stoping plastic on plastic creaks.
Dear Lord.. The gods have been good to me. For the first time in my life,
everything is absolutely perfect just the way it is. So here's the deal: You
freeze everything the way it is, and I won't ask for anything more. If that
is OK, please give me absolutely no sign. OK, deal.
pdhealy is online now
Old 18-01-2008, 19:26   #6
cheezemonkhai's Avatar
Members Car:
Thank you, you have no idea quite how irritating that squeaking over the bumps has been!
Think i might have a nice word with the dealer too
cheezemonkhai is offline
Old 18-01-2008, 22:20   #7
GAFF's Avatar
I do have an idea, hence the reason I got sick of it and done the above , tbh its made a massive difference.......I just need to get the rear seat release clips sorted
If anyone tries this please reply with your findings.
I do but feck it if it wasn't for things like this people would be waiting a long time to find resolution.
wrt hoover
GAFF is offline
Old 22-01-2008, 00:32   #8
pdhealy's Avatar
Well done Colm. I know how annoying a mystery rattle can be. I had one coming from my dash (so I thought). Took half of it out, then flicked the handbrake button by accident.....hey presto there was the rattle! It took me about 3 hours to find and repair a rattle that I put my thumb on everyday.
Similar Threads
Underseat Storage area??? WaveyDavey Fabia I 12 16-06-2008 22:58
Dash Top Storage inexeng Octavia II 0 06-01-2007 17:15
Centre dash and vents. vindaloo Styling and Car Care 13 31-05-2006 01:39
Center of the dash makeing noises L-Y-K Fabia I 4 28-02-2006 19:59
Cured cracking noises from dash davidi Octavia II 3 12-01-2006 10:04
