39,456 Members 1,489,942 Posts
Snow Chains for Octy Scout
This is a discussion on Snow Chains for Octy Scout within the Octavia II forums, part of the Skoda Model Discussion Area category; Driving to the French Alps in the not too distant future and need to carry a set of snow chains ...
Old 09-12-2007, 21:50   #1
Members Car: 1995 Misi FTO GPX
Driving to the French Alps in the not too distant future and need to carry a set of snow chains as I believe it is a legal requirement in some Ski resorts. Anyway, started looking into it and there are LOADS of options. Some I have found state that manufacturers requirements should be followed due to clearance issues and putting my hand over the back of the rear wheel did surprise me as to how little there is.
I did do a search but could not find anything specific to the Scout so, anyone already have snow chains for their scout or 4x4 and can drop me a brand and chain type/size?
Thanks in advance.
Mark
MarkyW is offline
Old 09-12-2007, 21:52   #2
Moderator
Bigw2069's Avatar
Members Car: Noddy Car
Re: Snow Chains for Octy Scout
what size of tyre does the scout come with?
Bigw2069 is offline
Old 09-12-2007, 21:55   #3
225/50/17 and I was looking at some self tensioning ones, like the RUD Easy2Go. They seem best value and easy fit and operation. Skoda accessories do not appear to list chains for 17" wheels as yet, 15s and 16s are in there though.
Mark
MarkyW is offline
Old 10-12-2007, 01:25   #4
patrol man's Avatar
Members Car: octavia scout 20tdi
by them in france all the stores in the area will stock them
patrol man is offline
Old 10-12-2007, 17:13   #5
irin's Avatar
Members Car:
I have the same dilema, and I am thinking to put back my 195/65 r 15 tyres and by the chains over in France because here in Ireland they are very expensive.
As far as I know they are compulsory during the winter for some roads time and if you are find without chains the fee is 180€ compare to 25€ the set (not to sure about them numbers)
Anyway there will be indicators on the roads where they are requaired.
Q:How about the winter tyres? Are this compulsory to?
irin is offline
Old 10-12-2007, 20:19   #6
Members Car: 4x4 Jabba Turbo estate
Snow tyres aren't compulsory, just the chains in certain (ski) resort regions. There are often blue signs up when approaching roads to resorts where you need them (if its snowing / has snowed hard)
Fabpreza is offline
Old 10-12-2007, 22:59   #7
The Rud Easy2Go are £64 delivered and self tensioning. Also appear VERY easy to fit so prepared to pay a little more than I would on the continent just to make sure I have a good set with me when I need them. Chains CAN be had for as littel as £30 a set here but uncoated so will possibly damage the wheels.....
Thanks for the replies though guys, seems not a lot of info available generally for the Scout.
Mark
MarkyW is offline
Old 15-12-2007, 00:12   #8
Members Car:
Talking Re: Snow Chains for Octy Scout
Brindley Chains. brindley-chains.co.uk
Always very helpful, just bought my 4th or 5th set from them, different cars over the years.
They had no record for Scout, e-mailed Brenta in Austria, got back to me later the same day.
Had what I needed in stock arrived in 48 hours, £60 all in and delivered.
Always had Brenta C, stock code XMR75 for the Scout.
Haven't test fitted but not expecting problems.
Very happy with company over the years.
Everyone's jealous because the voices only speak to me?
Zactor is offline
Old 23-12-2007, 02:15   #9
Ended up buying Autosocks after RUD (manufacturer) and several chain shops told me that this tyre size was out of bounds clearence-wise. Also, made easier as the French tourist board rpelied to my mail saying autosocks were now accepted as a viable alternative to chains.
The other regularly suggested alternative was to replace the wheels with 16s....
We will see how the 'socks cope with the French Alps in January.
Mark
MarkyW is offline
Old 24-12-2007, 07:50   #10
irin's Avatar
Members Car:
I am now in Italy and I got a Michelin snow chains set from Auchan shop for 69 euro , until now it was not the case to use them. I replace the wheels with 195/65r15 for this trip.
irin is offline
Old 24-12-2007, 23:04   #11
cc_7up's Avatar
Isn't the Scout 4 wheel drive and shouldn't that be ok with out chains?
cc_7up is offline
Old 24-12-2007, 23:05   #12
cc_7up's Avatar
Isn't the Scout 4 wheel drive and shouldn't that be ok to drive in snow?
cc_7up is offline
Old 25-12-2007, 00:04   #13
It IS 4wd, but local bylaws in some ski resorts require you to demonstrate control of the car and if that is not possible without chains then the nice French police CAN make you abandon your car.
We spoke with the French tourist board and normally you have to have traction assistance with metal parts (i.e. snow chains) but they have recently relaxed teh guidelines so that if you cannot get chains to fit your car then Autosocks are now acceptable.
Mark
MarkyW is offline
Old 25-12-2007, 22:51   #14
Members Car:
Mark
well, the mentioned tire dimension is not allowed with using snow chains by skoda...
if you really need snow chains you will have to change to 205/55/16 if you drive a
skoda scout 4x4 otherwise you can use 195/65/15. to be sure pls have a look at your
local skoda webpage...
you´ll may find infos here: http://www.skoda.de/download.php?id=100
mfg
sebalexs
sebalexs is offline
Old 28-12-2007, 00:11   #15
Members Car:
Reckon chains will be fine on the Scout, not likely to be a wheel arch clearance issue.
Have found 4X4 Octys very good in the snow in the past. No problems going, the chains really help with the stopping. Don't like the ABS in the snow, one of conditions where it doesn't always give the best result IMO.
Reckon tyres are the key and the chains sort of compensate for not having winter tyres.
Doesn't really snow in the UK anymore! We keep hoping though, please please please!
Zactor is offline
Similar Threads
Snow Chains JFWUK Maintenance & Performance 5 02-11-2008 12:11
snow chains on a roomster 3 alickswud Roomster 5 04-08-2007 16:03
Snow Chains for vRS standard wheels? sam_underhill Fabia I 5 20-01-2006 21:38
Octy vRS in snow jimnpaula Octavia I 1 02-03-2005 18:56
Snow Chains for Octavia vRS? P Octavia I 6 10-02-2005 22:48
