This is a discussion on Spare wheel: wrong size! within the Octavia II forums, part of the Skoda Model Discussion Area category; Came to swop my spare wheel for N/S front and discovered it is a 16in while all the 4 others ...
| Briskodian Join Date: Jun 2006 Location: Stafford
Members Car: 2005 Octavia Ambiente Thanks: 1
| Spare wheel: wrong size! Came to swop my spare wheel for N/S front and discovered it is a 16in while all the 4 others are 15in Anyone else found this? (Car is an 05 Abiente 1.6 FSI) |
| Re: Spare wheel: wrong size! Where did you buy the car? |
| Briskodian Join Date: Aug 2006 Location: Herts
Members Car: Octavia vRS TDI - Koni FSDs & RallyFlapz Thanks: 46
| Re: Spare wheel: wrong size! What size of tyres do you have on both the 16" 'spare' and your other four 15" wheels? They might be compatible for you to use the 16" spare as a temporary. If you have 17" or 18" wheels on higher spec cars you still get a 16" spare but with a compatible sized tyre. |
| Re: Spare wheel: wrong size! Lummox: Bought it locally from non-Skoda dealer but car was originally purchased in Cardiff from a Skoda dealer. Have had it serviced a few weeks ago at Cannock Skoda dealer but don't know if the spare should be inspected as part of the service. Bahnstormer: Surely a spare (except for those that are intended as space-savers) should be identical to those fitted originally. |
| Insecure Join Date: Sep 2004 Location: right on track........
Members Car: Volvo 2.4 T SE XC70 Auto running on LPG Thanks: 14
| Re: Spare wheel: wrong size! If it was a used car purchased from the dealer in Cardiff it may have had aftermarket/differant bigger wheels on and was put back onto 15" wheels so they could sell the others......Maybe??
__________________ I now own a Volvo 2.4T Automatic V70 XC 4 wheel drive, Estate, running on LPG......In a Lovely shade of Gold---THE BATTLE TANK "BRISKOLVO ".......THE UK'S ONLY MEMBER......." IT'S THE WAY FORWARD " |
| Re: Spare wheel: wrong size! It would be odd if a bigger spare would have been originally specified than what is on the car. Do you have 15" alloys or steels? If yes then are the OE spec wheels or an accessory? |
| | #7 | |
| Re: Spare wheel: wrong size! Quote:
What size wheel/tyre combos do you have and I can then tell you if you are safe to use the spare you have? | |
| Re: Spare wheel: wrong size! Spare is 205/55r16 91v Others 195/65R15 91H All are Bridgestone on steel wheels |
| Briskodian Join Date: Dec 2005 Location: Cruising the M65
Members Car: All Skodas Thanks: 16
| Re: Spare wheel: wrong size! Sounds like the car originally had the 17" optionally alloys fitted, which would come with the 16" spare, and someone has swapped them at sometime - probably the dealer.
__________________ ![]() Ants |
| | #10 |
| Re: Spare wheel: wrong size! I'd say at sometime its been swapped then or it didnt come with those 15's from the factory. |
| | #11 |
| Re: Spare wheel: wrong size! Could have had 16's from the factory maybe. More than likely though the spare wheel was either punctured or missing, they have swapped it out of another sales car and didnt realise that it was the wrong size. Or it just had the wrong one put in at the facotry and no one has noticed. |
| | #12 | |
__________________ I now own a Volvo 2.4T Automatic V70 XC 4 wheel drive, Estate, running on LPG......In a Lovely shade of Gold---THE BATTLE TANK "BRISKOLVO ".......THE UK'S ONLY MEMBER......." IT'S THE WAY FORWARD " | |
| | #13 |
| Re: Spare wheel: wrong size! According to the Skoda web site this Model should have 6.0J X 15" Alloys on. Perhaps the spare is wrong, Should be a 15" steel
| | #14 |
| Re: Spare wheel: wrong size! AG Morley: Pretty sure that alloys were only standard on Ambientes after April 2006 (there were several changes introduced at that time eg reversing sensors were dropped in favour of the alloys) Methinks I'll phone the dealer that supplied the car to see if their records can shed a light on the mystery ![]() |
| | #15 |
| Re: Spare wheel: wrong size! Thats right they had steels on originally and iirc a/c was an option. Alloys and a/c became standard in 2006. So you have 15" alloys atm? |
| | #16 |
| Re: Spare wheel: wrong size! Lummox: Steel wheels all round (first reg'd 01.03.05) |
| | #17 | |
1. Is your current 205/55 16 spare 'Safe' to use with your 195/65 15 other three wheels? Answer is - YES. Both sizes are used on the Octy and both have effectively the same 'rolling radius'. Clearly you should use care and moderate your speed, to say 60mph, until you can get your punctured 195/65 15 repaired/replaced. 2. Have you got the right wheels for your car? again (probably) YES. Whilst a 2007 spec 1.6FSi Ambient will have 205/60 15 tyres on Alloys, yours as a 2005 car may well have had Steel wheels as standard; so I'd suggest researching this a bit more before you leap to the conclusion of having been sold a 'pup' (which I'd be surprised about) by your dealer. OK? | |
| The Following User Says Thank You to bahnstormer vrs For This Useful Post: | abuelo (24-06-2007) |
| | #18 |
| Re: Spare wheel: wrong size! Have now checked with the dealer that supplied the car: there is no record of anything other than standard 15in wheels being fitted ![]() |
| | #19 |
| Re: Spare wheel: wrong size! Have now checked with Skoda UK who reckon that the 05 Ambiente was provided with a "get-you-home" undersized spare......... I don't think that this is true; can anyone confirm this please (I guess that the info will appear in a sales brochure for the model) ![]() Last edited by abuelo; 21-08-2007 at 18:56. |
| | #20 |
| Re: Spare wheel: wrong size! Having had no response to my post of 20/08, I am posting again in the hope that someone will be able to let me know if the Octavia Ambiente has ever been supplied with a "spacesaver" spare wheel. ![]() |
| | #21 |
| Re: Spare wheel: wrong size! Yeah maybe but.. 1. Unless its a propper space saver (looks like a 2CV wheel) the spare will not be bigger than the wheels allready fitted to the car 2. It will have to be marked as a temporary wheel (big yellow sticker). |
