This is a discussion on Squeaking Front Window within the Octavia II forums, part of the Skoda Model Discussion Area category; This is really starting to bug me now . First went in for 'the fix' a couple of months back ...
| Ex-Moddy Join Date: Jul 2005 Location: Hampshire
Members Car: Golf PD105 Thanks: 187
| Squeaking Front Window This is really starting to bug me now . First went in for 'the fix' a couple of months back (the fix being re-lubing the runners) but after a couple of weeks it came back again. Had it re-done during a service (at a different dealership) and sure enough the same thing happened again so this time a new regulator was ordered and fitted under warranty today and guess what .................................. it started squealing again when I got home!! This is really pi55ing me off now, anyone got any suggestions?
__________________ Superchips Bluefin only £390 @ JKM http://www.jkm.org.uk/performance/bluefinxmas2008.htm |
Members Car: Audi S3 Thanks: 145
| Re: Squeaking Front Window Lubricate the window seal with Silicone???
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Re: Squeaking Front Window Nope, that works for a limited time only then it returns. Been back AGAIN and still cant seem to cure it!!
| Briskodian | Re: Squeaking Front Window Argh, this drives me crazy as well. I narrowed it down to the brush at the base of the glass, the thing keeping moisture from going inside the door. I have yet to find something that will lube that and not smear the window.
__________________ Milk Inc's newest #1 fan |
| | #5 | |
| go green Join Date: Jan 2005 Location: Rochester, Kent
Members Car: Roomy 3 & Fabia Thanks: 166
| Re: Squeaking Front Window Quote:
| Briskodian Join Date: Jun 2006 Location: Newcastle upon Tyne
Members Car: Octy II VRs 200 Thanks: 10
| Re: Squeaking Front Window Can't say I put my windows down enough to notice if I have such a problem - it is winter you know ![]()
__________________ 06 Skoda Octavia VRs 200 bhp (Black) Coming soon: 58 Skoda Octavia VRs CR TDi (Candy White) Previous Cars: 04 Audi TT 3.2 V6 250 bhp (Black) 02 VW Golf V5 170 bhp (Black) |
| Briskodian | Re: Squeaking Front Window Steve are your window seals furry or plain rubber? If they are not the rubber ones with the furry top get these fitted. FWIW if you are out of warrenty I might be able to keep hold of my set which are due for replacement so you can have a FOC try. Also if you are doing silicon, try using the grease as per the cage mod rather than the spray as this lasts a lot longer. HTH EDIT: Ignore that I know you're under warrenty ![]()
| The Following User Says Thank You to cheezemonkhai For This Useful Post: | Makefish (13-02-2008) |
| Briskodian | Re: Squeaking Front Window I had a go at it today. With the window completely lowered I kept the rubber/furry seal at the base of the window pulled back a bit and lifted the window with the key fob button. When the window was completely up i noticed there was a lot of dirt on the bottom of the glass that's always below the seal, so I cleaned them with wet tissues on a plastic card. I then noticed there were two white plastic pieces that held the glass from underneath, so I flooded those with my trusty old WD40. There were two coresponding white pieces on the inside face of the glass (visible with window down) which I didn't lube because I don't want WD40 smeared on the inside + the smell of it. The result is it's not that noisy anymore, but not completely gone for now. I suspect it will get better as the WD40 has time to penetrate the mumified crap in there.
| The Following User Says Thank You to sebulbus For This Useful Post: | Makefish (13-02-2008) |
| Re: Squeaking Front Window Thanks for the offers of help and advice
| | #10 |
| Briskodian | Re: Squeaking Front Window Update: it worked so well the next morning that I didn't bother to lube them again. Seems its cured for the moment.
| Front window jammed open!!!! | duffbeer | Fabia I | 1 | 14-05-2007 21:36 |
| Squeaking from front | gavinvrs | Fabia I | 4 | 21-10-2006 13:10 |
| broken windscreen(front window) | dino21 | Fabia I | 4 | 26-07-2006 21:50 |
| Front electric window | T.Jack | Octavia I | 9 | 10-06-2006 17:15 |
| Severly squeaking front suspension on Octy vRS! | kennyhkw | Maintenance & Performance | 6 | 18-05-2004 07:43 |
