This is a discussion on Squeeky rattle from passenger side dashboard? within the Octavia II forums, part of the Skoda Model Discussion Area category; Has anyone experienced this? I've started to have a sort of squeeky rattle from the passenger side end of the ...
| Briskodian Join Date: Apr 2007 Location: Finland
Members Car: Skoda OCtavia II Combi Elegance 1.6FSI Thanks: 22
| Squeeky rattle from passenger side dashboard? Has anyone experienced this? I've started to have a sort of squeeky rattle from the passenger side end of the dashboard. It sounds like it's coming somewhere around the area where the A-pillar meets the dashboard. It sounds like a rubber against plastic kind of rattling sound. Any help fixing it would be nice, it's starting to drive me crazy. |
| Briskodian | Re: Squeeky rattle from passenger side dashboard? Anything glove box related? The passenger seatbelt metalwork on mine rattles against the b pillar which annoys the hell out of me. |
| Briskodian Join Date: Oct 2003 Location: South East England
Members Car: White Octavia vRS Thanks: 6
| Re: Squeeky rattle from passenger side dashboard? Raising the belt pivot up to its highest setting seems to cure this. Agree it's naff though...
__________________ Phil Thomas Then: Red Fabia vRS: Not quite standard .Now: White Octavia vRS: Eibachs/FSDs - Milotec B pillars - Neuspeed shifter (thanx Stu!). |
| Briskodian | Re: Squeeky rattle from passenger side dashboard? Yeah trouble is then the short female individual that normally sites in that seat sticks it back down again! ![]() |
Members Car: Octavia II vRS Thanks: 29
| Re: Squeeky rattle from passenger side dashboard? I had one, check the cover on the side of the dash, make sure all the clips are attached. One of mine popped off at some stage and got stuck. Also the mesh on the dash was known to cause problems.
__________________ GAFF ![]() Briskoda Ireland Events, Meets & Pictures.....Race Blue Octavia MkII vRS.....Old Octavia MkI vRS |
| The Following User Says Thank You to GAFF For This Useful Post: | downtime (28-03-2008) |
| | #6 | ||
| Re: Squeeky rattle from passenger side dashboard? Quote:
I don't think it's the mesh, it should make a more metallic rattling sound, shouldn't it? | ||
| Re: Squeeky rattle from passenger side dashboard? I'm intending to place a small self-adhesive foam pad on the b-pillar plastic panel where the seat belt clip is knocking against it.
| Re: Squeeky rattle from passenger side dashboard? Try closing the door with a cloth between door card and dash, I had issues in this area.
| | #9 | |
I had a self-adhesive foam pad between the dash end and door card, but that made it sound a lot worse. Maybe there was too little pressure to too small area? | |
| | #10 |
| Liberty City Join Date: Aug 2006 Location: Cardiff
Members Car: Octavia II 2.0 TDI DSG Elegence Thanks: 15
| Re: Squeeky rattle from passenger side dashboard? I have had exactly the same issue. The dealer originally replaced the heater mesh vents as this was a known issue. This did not resolve the issue. So i removed the equivilent of the fuse box cover (passenger side obviously) and this resolved the issue. so it may be (like me) that the cover is rubbing against the A pillar cover. If so, try inserting some felt etc.... between the a pillar and fuse cover good luck. |
| | #11 |
| Briskodian | Re: Squeeky rattle from passenger side dashboard? does your window squeak when you open and lower it, my drivers one did and after lubing it went away. The squeak would occur after going over bumps.
__________________ 1.9 TDI Elegance - Cappuccino Beige Plenty enough power and torque for the economy offered |
| | #12 |
| Re: Squeeky rattle from passenger side dashboard? Ok, the cause for the squeek is found. It's actually coming from the door card around the tweeter area, because if you gently press the tweeter grille the squeeks stop. So I'll have to start dismantle it and look for a ways to reinforce it so that it doesn't squeek anymore. |
| | #13 |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 11
| Re: Squeeky rattle from passenger side dashboard? i had this on mine, take off the cover at the side and reclip it into place, if this doesnt work a good expertly placed whack solved it for me. |
| | #14 | |
__________________ GAFF ![]() Briskoda Ireland Events, Meets & Pictures.....Race Blue Octavia MkII vRS.....Old Octavia MkI vRS | |
| | #15 |
| Re: Squeeky rattle from passenger side dashboard? I know thanks, I've already taken everything apart once, when I installed the door handle illumination leds. Maybe something didn't go properly in it's place and that's causing the extra squeeks and rattles ? ![]() |
| | #16 |
| Re: Squeeky rattle from passenger side dashboard? Alrighty then, problem solved. I re-adjusted the door locks and now everything is fine. The doors close more sturdy as an added bonus Sounds more like a safe closing now ![]() Thanks for all the replies. |
| | #17 |
| Re: Squeeky rattle from passenger side dashboard? I thought you said it was the door card? what kinda of adjustment did you make to the lock?
| | #18 | |
You can adjust the door position by adjusting the lock latches on the car body. It has two M8 screws which you unscrew just a little bit so that the latch can be moved. Then just move it a little bit, tighten the screws and test the door closing, if it's ok tighten the screws fully and you're done. Take note that you can adjust the door up/down and in/out position with this latch adjustment. | |
| | #19 |
| Briskodian Join Date: Aug 2006 Location: Liverpool
Members Car: Nothing :-( Thanks: 52
| Re: Squeeky rattle from passenger side dashboard? I've got a dozen sounds like that one ![]() I found the major one was the under seat storage box plastic rubbing against the leather ![]()
__________________ I was just a figment of your imagination! After nearly two years and a hell of a lot of fun, I'm off - all the best to everybody; this is Robbo signing off! |
| | #20 | |
| | #21 |
| Re: Squeeky rattle from passenger side dashboard? Not much, less than 1 cm. Best part really is that now the front doors close much more tighter than before. Actually before, my front doors where not completely in line with the back doors. You could see that the fronts were a little bit more out. Up/down position was fine. Also the latches were not straight, which caused a "clang" sound when closing the drivers door. Now when it's straight, all you can hear is "thump" when the door closes ![]() |
| Rattle!! (Passenger side speaker) | Hitty86 | Fabia I | 31 | Yesterday 14:27 |
| Rattle - Front Passenger Side | MikeLawrinson | Octavia I | 5 | 22-02-2008 14:31 |
| Passenger side rattle | GlacierNR | Fabia I | 9 | 09-02-2007 19:24 |
| Squeeky Rattle in drivers door... help! | baiton20 | Octavia I | 1 | 09-09-2005 19:47 |
| Fabia Classic 1.9SDi: Passenger Side: Side Light Bulb | pyromorph | Maintenance & Performance | 3 | 05-01-2005 14:23 |
