This is a discussion on Starting sometime takes several times within the Octavia II forums, part of the Skoda Model Discussion Area category; Anyone know about or had this? Octy II 2.0 TDI DSG starting from cold (cold but during a warm day ...
| Briskodian | Starting sometime takes several times Anyone know about or had this? Octy II 2.0 TDI DSG starting from cold (cold but during a warm day approx 20 degC). Turn the key, glow-plug light comes on for about 1 sec (seems normal) then try to start, ...it catches for a millisecond then dies. Sometimes it starts on the next go, sometimes after several more try's. There is plenty of fuel in it, battery is excellent and the car is fairly recent (June '06), low mileage (8500 mls). The reason I'm asking as I don't know the car very well yet, (not had it long), and as it's my first Skoda-VAG Tdi I'm unfamiliar with them. What I have done though is to run a VAG-COM fault code check and found nothing. (No, I haven't been indescriminately playing with the VAG-COM programming!! Thanks. |
| Briskodian Join Date: Jan 2003 Location: Winchester
| Re: Starting sometime takes several times Its still under Skoda warranty so take it to the dealers. It could be a multitude of things, electrical, fuel leak etc but why worry when they should sort it FOC
__________________ Speed is an addiction for which thankfully there is no cure |
| Re: Starting sometime takes several times Could be a diesel lift pump. Needs checking out. |
