This is a discussion on steering rack noise within the Octavia II forums, part of the Skoda Model Discussion Area category; my 57 plate vRS' steering rack creaks quite often on full lock? is this normal for a electro-mechanical steering rack? ...
| Briskodian Join Date: Mar 2008 Location: Sheffield
Members Car: Octavia vRS TFSI 57 Plate Thanks: 16
| steering rack noise my 57 plate vRS' steering rack creaks quite often on full lock? is this normal for a electro-mechanical steering rack? first time i've owned a car with it, im used to hydraulic and normally getting a woosh from the pressure release valve Cheers, Dan
__________________ 57 Mk2 2.0TFSI vRS Estate in Race Blue, Code Red Stage 1 Remap, Code Red Intake, Code Red Engine Cover and Forge Blowoff Spacer |
| Briskodian Join Date: May 2005 Location: Southampton, England
Members Car: Skoda Fabia VRS and Skoda Octavia II 1.9 Tdi Thanks: 9
| Re: steering rack noise Holding any P/S fully over for any length of time is supposed to do damage isn't it? At least that is what I've always seen in numerous owners' handbooks! |
| Briskodian Join Date: Jun 2007 Location: South/Middle/then Up a bit
Members Car: Scout TDI Thanks: 9
| Re: steering rack noise Not so much on full-lock but mine creaks as I turn left at low speed, it also only seems to be there when the air temp is cold? Really strange problem, sounds like its generating from a steering servo or something, anyway getting it checked out this week. W.
__________________ Think_Outside_The_Box |
| Re: steering rack noise hmm think i'll mention it next time its at the stealers
Members Car: Octavia II vRS Thanks: 29
| Re: steering rack noise AFAIK it was a fault with them and they were being replaced under warranty. It was on a 2006 garage car I drove, the car was only a couple of days old too.
__________________ GAFF ![]() Briskoda Ireland Events, Meets & Pictures.....Race Blue Octavia MkII vRS.....Old Octavia MkI vRS |
| | #6 | |
| Re: steering rack noise Quote:
__________________ Think_Outside_The_Box | |
| Re: steering rack noise mines a 57 plate, then again, could have been sat about a year first before it was registered for all i know
| Re: steering rack noise The dealer can read a number off the rack (MBV 80 iirc) this will tell them if its in the effected range of steering racks. |
| The Following User Says Thank You to Lummox For This Useful Post: | wilkopilko (29-04-2008) |
| | #9 | |
I've been reading a little about this from previous posts & just wanted to know if it is this 'common' steering rack issue that also effects Golf mk5/Leon etc... is it a big job? What is involved - the whole steering rack replaced or the servo/motor? Just to be more precise - the noise can only be described as a 'creaking' sound & only present when actually turning the steering wheel left, the noise stops when you stop turning the wheel so is also NOT present when on full left lock. The noise also seems to be coming from behind the glove box area & sounds like an electric motor/mechanical sound (hard to describe). I can also confirm that this is only audible when it is cold outside (below 10deg). I just know that when it goes in again this week, the dealer will not be able to pick it up because the weather is getting warmer! Thanks, W.
| Steering Rack | bassman | Octavia I | 4 | 24-03-2007 21:13 |
| Steering rack... | Liverpool-Lad | Octavia I | 6 | 19-03-2007 20:10 |
| Who has had a new steering rack? | flynntech | Octavia II | 11 | 09-01-2007 15:41 |
| Quicker Steering Rack? | redbaron | Maintenance & Performance | 2 | 09-07-2003 15:49 |
