This is a discussion on Stream MP3 Line In / Aux Adapter within the Octavia II forums, part of the Skoda Model Discussion Area category; Evening, Just had a quick look on eBay for a Line In / MP3 adapter to fit a Stream MP3... ...
| Briskodian | Stream MP3 Line In / Aux Adapter Evening, Just had a quick look on eBay for a Line In / MP3 adapter to fit a Stream MP3... Some may remember I had a rather unsuccessful attempt at this earlier in the year but I though it was time to give I had another go since I now have another stereo - a Stream MP3. Can anybody recommend me one which will give me the standard set of phono / 3.5mm jack connection please? The ones I've found just have some kind of in-line gubbins - the one I had before was a small box with some electronics to fool it into thinking there was a changer attached...
__________________ Regards, Lee |
| Briskodian | Re: Stream MP3 Line In / Aux Adapter No need for any electrical magic if you have a stream mp3 - if has dedicated pins for AUX input on the back. There's at least a couple of posts covering this in the first few pages of threads at the moment |
| | #3 | |
| Briskodian | Re: Stream MP3 Line In / Aux Adapter Quote:
So would this work?
__________________ Regards, Lee | |
| Briskodian Join Date: Aug 2005 Location: Back in the Green
Members Car: 2 Octavia II's, an L&K combi and a vRS hatch. Thanks: 48
| Re: Stream MP3 Line In / Aux Adapter I don't think that connector will work, that is for a Mk1 Octavia by the looks of it. The adaptor you need is rectangular. Have a look at Stu's site and you'll see the back of the Stream MP3 head unit at the bottom of the page. As for part numbers and the like I don't have ETKA so I can't help you there i'm afraid. EDIT: just had another look and it WONT work as the Stream MP3 uses a Quadlock connector. I've attached a pic of the Audience MP3 connections as the two units are more or less identical in that department and you can see the tiny pins at the top are where the AUX connector and CD changer connect.
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() Last edited by dstev2000; 29-09-2007 at 20:08. Reason: Added pic |
| Briskodian | Re: Stream MP3 Line In / Aux Adapter Hi all, Sorry to go back to this again - I've had a look at eBay but cannot seem to find the correct adapter / cable. Basically I have a Stream MP3 with (I believe) quad lock connections. I need a quadlock connector to 3.5mm jack plug in order to connect an MP3 player. Can somebody here have a quick look on eBay and find me the correct part I need please? As I say - I've looked already but can't find the correct one for my needs...
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 11
| Re: Stream MP3 Line In / Aux Adapter ive done a write up on here somewhere on how to do it etc, cant find it at the mo, but it was done in the last month. |
| King Rat Join Date: Jan 2006 Location: West Yorkshire
Members Car: MK11 Octavia vRS Thanks: 169
__________________ Current car: Black MKII Octavia vRS Combi Previous: Black MKI Octavia vRS Combi Black Fabia Elegance 100 BHP |
| Re: Stream MP3 Line In / Aux Adapter thats the one |
| Briskodian | Re: Stream MP3 Line In / Aux Adapter Ahh cool - a DIY jobbie! COuple of questions - what's special about the VW lead? Is it just the pin connectors on the end where you plug into the quadlock? Or something else? What do you mean by: "Once done put the bllack block back into the blue. tape the wires so they dont show any bare bits and fuse and tape to the wiriing loom so it is safe." Fuse????
| | #10 | |
tape the wires up so no bare wires are showing so it doesnt fuse (short circuit) and cause it to cause a fire or blue fuses or anything else that can happen when bare wires touch. | |
| | #11 |
| Briskodian | Re: Stream MP3 Line In / Aux Adapter If you butcher your wiring loom/connectors and a problem did arise with the electrics of the vehicle, would Skoda turn round and say 'sorry warranty void'?
__________________ 1.9 TDI Elegance - Cappuccino Beige Plenty enough power and torque for the economy offered |
| | #12 | |
Do you really need the VW wire - surely all you are doing here is connecting some wire to the AUX pins?
| | #13 |
| Briskodian | Re: Stream MP3 Line In / Aux Adapter See my above reply!!
| | #14 |
| Re: Stream MP3 Line In / Aux Adapter You need 2x 000979010 then cut in the middle so you can have 3 pins (with wires) to attach the mp3 lead to as there are no pins in the block you need to add them. |
| | #15 |
| Briskodian | Re: Stream MP3 Line In / Aux Adapter What I am looking at exactly? The part about masking the wires up?
| | #16 | |
Is that part number the same for Skoda? I've had a search around the web and it seams to be a generic part number for a number of manufacturers...
| When did the Aux socket and MP3 stream come in? | Guinness | Octavia II | 48 | 26-09-2007 22:16 |
| stream mp3 + aux + zen vision:m | encephalopathy | ICE, Security and Insurance | 1 | 25-07-2007 20:26 |
| Re can a Stream (Mp3) support a line out | randomone | Octavia II | 4 | 30-06-2007 17:13 |
| Replacing the original Stream Radio with new Stream MP3 | Fleischen | Octavia II | 9 | 04-02-2007 02:40 |
| Stream MP3 / Aux input | yashicamat | Octavia II | 15 | 23-09-2006 00:39 |
