This is a discussion on Stream MP3 playback within the Octavia II forums, part of the Skoda Model Discussion Area category; I'm struggling (failing!) to get my Stream radio to playback all the MP3 tracks on a CD containing multiple folders. ...
| Briskodian Join Date: Jul 2007 Location: Leeds
Members Car: Octavia vRS TDI Thanks: 1
| Stream MP3 playback I'm struggling (failing!) to get my Stream radio to playback all the MP3 tracks on a CD containing multiple folders. As a simple example, say the CD contains: /track1.mp3 /track2.mp3 /folderA/track3.mp3 /folderA/track4.mp3 /folderB/track5.mp3 /folderB/track6.mp3 If I set mix to 'folder' and repeat to 'folder' it only plays the tracks in the current folder where I'd expected it to play all 6 tracks in random order. Am I misreading the manual? |
| Re: Stream MP3 playback The settings you have will result in random play in the current folder only.
| Re: Stream MP3 playback just read the manual, and mix folder is what you want, you cant have repeat with mix across multiple folders. for repeat folder the manual says: if mp3 disc is inserted the tracks in the folder active when the function is activated will be played repeatedly.
| Re: Stream MP3 playback Ah. OK. So if I set mix to 'folder' and repeat to 'off' then it should play all the tracks in all the folders in random order? |
| Re: Stream MP3 playback Yes, I believe so. You need mix set to folder.
