This is a discussion on Top speed??? within the Octavia II forums, part of the Skoda Model Discussion Area category; How is this worked out? the car has done 5k now and after running it at around 100 for a ...
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 11
| Top speed??? How is this worked out? the car has done 5k now and after running it at around 100 for a fair time on a long private road , i got over taken by a vxr who at this point became my "pull out the unwanted attention car" and decided to give it a bit of a heavier foot but found i could only get the speedo up to just short of 130 and sat nav of 121 on flat straight ground, no wind or anything to slow me down. Book speed is iirc 134 or 136 is this speedo speed (which we all know to be out around 5%) or calibrated speed (which would indicate a speed of about 140.) |
| Briskodian | Re: Top speed??? the saxo will have a better weight to power ratio, perhaps you needed to drop a gear to get the revs up, to produce the torque required to accelerate past the mentioned speed?
__________________ 1.9 TDI Elegance - Cappuccino Beige Plenty enough power and torque for the economy offered |
| Briskodian Join Date: Mar 2007 Location: Tameside
Members Car: Mk1 Octavia VRS (Standard) Thanks: 4
| Re: Top speed??? You say that you have only done 5,000 miles? If that is the case you have got a while yet before you see your maximum performance. If you intend to drive the car quickly it is important that you start to use the full rev range. obviously don't redline it every where you go but steadily increase the amount of revs you use and on occasion take it just short of the redline i.e when going down a sliproad. only do this once the engine is fully warm. It can take upto 30,000 miles to get the most from an engine. I think that this is more critical in a car like yours which is normally aspirated, turbo engines are forced to perform but the same advice still applys (The above advice is given based upon my own experience others may disagree) Hope this helps! |
| rider of sharks Join Date: Apr 2005 Location: Cumbria
Members Car: Fabia vRS Thanks: 245
| Re: Top speed??? saxo? vxr would be a very fast vauxhall ![]() and it would be calibrated speed... a speedo reading of about 140 sounds right..... maybe give it a bit more time to run in? I know the diesels are happier at about 10k on.... not sure how long your engine may take to find it's "sweet spot"...... I would think it would improve though! edit: above beat me to it! lol...
__________________ Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red.... ![]() Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!) |
| Briskodian Join Date: Jun 2005 Location: south east
Members Car: 2005 2.0FSI hatch elegance Thanks: 9
| Re: Top speed??? I've got the same engine in an Elegance, (gets much better with passing miles by the way) but I suspect it is faster in fifth than top. Mine hasn't got to 19000 miles yet, and I'm sure it is much better now than at 5 to 10K. |
| Re: Top speed??? cheers, it was a astra vxr (like one i looked at before getting the skoda). I had gone up the rev range changing at around 5.5k as it feels pushed at that range even through the power seems to be felt at around 4.5k rpm. 6th gear seems to be cruising gear and not much use in heavy foot situations So basically the car is still running in (in a way) and therefore need to train it to get the full potential ![]() |
| | #7 | |
| Briskodian | Re: Top speed??? Quote:
__________________ 1.9 TDI Elegance - Cappuccino Beige Plenty enough power and torque for the economy offered | |
| Re: Top speed??? it also got around 144bhp on the RR a couple of months ago at around 2k miles. |
| Cuthbert Dibble Join Date: Apr 2006 Location: Watching Tom peeping at Lady Godiva.
Members Car: Octavia Elegance 2.0 Tdi Thanks: 231
| Re: Top speed??? I've got mine to 72 mph with a good wind behind me.
__________________ ![]() I drink, therefore I spam. |
| | #10 |
| Briskodian | Re: Top speed??? I heard they were good for about 150 on an airfield etc, what mods have you done to reduce the performance like this? ![]()
| | #11 |
| Re: Top speed??? Well if you are getting a power output as good as that then you may be correct in suggesting that 6th is a cruising gear (I wouldn't know as I have never driven your model) Things like open windows, roof rails, mudflaps effect top speed. (also turn the aircon off) But to be fair there arent many cars that will live with an astra VXR in a straight line anyway. |
| | #12 |
| Re: Top speed??? Flat tyres, remapped airbag. You name it.
| | #13 | |
Members Car: Fiat Panda Thanks: 15
![]() Chris
| | #14 |
| Re: Top speed??? Yes I did think that, but its not often you have someone brave enough to zoom past you and become your plod detector must also admit i wasnt planning on going any faster till i realised what an oportunity it was having someone ahead clearing the traffic and becoming cop bait for ya :lol |
| | #15 |
| Briskodian | Re: Top speed??? What about if you were to fold down the rear seats ![]()
| | #16 |
| Re: Top speed??? |
| | #17 |
| Briskodian Join Date: Feb 2007 Location: Blandford, Dorset
Members Car: 2007 Octavia vRS Thanks: 26
| Re: Top speed??? You tried against/to keep with an Astra VXR, in a TDi Octavia?! Why? I mean surely the minimum of 100bhp gap and a bit of Torque (if it was standard... ) would have put you off?
__________________ MY07 Octavia vRS TDi Hatch - Black Magic - Replacement Engine, Replacement Gearbox, Replacement DPF - Colour Coded Grille Surround, De-Tangoed F&R Indicators, 'vRS' Etched Tax Disc Holder, 2nd Rear Fog, Anti-Hijack, Leaving/Coming Home Lights, Michelin PS2 Tyres - RR Proven 177.9 bhp / 289 lb/ft www.vauxhallownersnetwork.co.uk - South Central Regional Organiser www.freewebs.com/holebrookfarmlivery/index.htm - Horse Livery & Grazing in North Dorset |
| | #18 |
| Re: Top speed??? i wasnt trying or racing, it just became a quicker journey with the vxr numb nut booting it up behind a group of cars, braking, and then moving them out the way for when i came lesuirely by :lol |
| | #19 | |
Fairy Muff then
__________________ MY07 Octavia vRS TDi Hatch - Black Magic - Replacement Engine, Replacement Gearbox, Replacement DPF - Colour Coded Grille Surround, De-Tangoed F&R Indicators, 'vRS' Etched Tax Disc Holder, 2nd Rear Fog, Anti-Hijack, Leaving/Coming Home Lights, Michelin PS2 Tyres - RR Proven 177.9 bhp / 289 lb/ft www.vauxhallownersnetwork.co.uk - South Central Regional Organiser www.freewebs.com/holebrookfarmlivery/index.htm - Horse Livery & Grazing in North Dorset | |
| | #20 |
| www.oscarli.com Join Date: May 2005 Location: Blackpool.
Members Car: Skoda Fabia vRS Images: 1 Thanks: 91
| Re: Top speed??? I drove a new octy vrs derv, on my private 11 mile road, and it wouldnt pass 130. I was quite shocked, as my petrol equivalent did an indicated 150 straight out the box.
__________________ Official 0 to 60 mph - 5.85 seconds. Standing 1/4 mile - 14.3 seconds. 251.5 BHP and 400 lbs/ft of torque. Oh - and 55 mpg on a run ![]() ![]() My car is for SALE!! ![]() |
| | #21 |
| Nuts Join Date: Nov 2006 Location: Greater Manchester
Members Car: Fabia vRS Thanks: 152
| Re: Top speed??? All about gearing and power to weight ratio - ditch some weight, get rid of fat b*gger behind wheel ![]()
__________________ "Stupidity, if left untreated, is self-correcting." - Heinlein |
| | #22 |
| Re: Top speed??? no no no a. i know who would have won, b: racing on a public highway is illegal and attracts more punishment than speeding. c: autobanns are hard to come by in the uk thus the long drive ![]() |
| | #23 | |
Weight effects acceleration, handling and braking and going uphill also. Take a car with a top speed of 120 mph, fill it full of people, it will still do 120 mph just it will take longer to get there. | |
