This is a discussion on What Spark plugs and cables you recommend to achieve the best performance within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi guys, Would appreciate if you can advise me what's most recomended for Octavia II - Spark plugs - Plug ...
| Briskodian | What Spark plugs and cables you recommend to achieve the best performance Hi guys, Would appreciate if you can advise me what's most recomended for Octavia II - Spark plugs - Plug cables Cheers! |
| Briskodian | Re: What Spark plugs and cables you recommend to achieve the best performance The ones it comes with I would suggest. IIRC The 1.8T spark plugs from the dealer were very good so I have no reason to believe that those from the 2.0T will be any different in their quality.
| Briskodian | Re: What Spark plugs and cables you recommend to achieve the best performance 2.0T or 1.8T for that matter does not use plug leads. They ahve seperate coil packs and no distributor. |
| Briskodian | Re: What Spark plugs and cables you recommend to achieve the best performance How about tyres... what are you having? |
| Briskodian | Re: What Spark plugs and cables you recommend to achieve the best performance There is a very good search tool on this forum. You'll find it in the tool bar at the top of each page ![]() |
