Why Brake Fluid Change?
This is a discussion on Why Brake Fluid Change? within the Octavia II forums, part of the Skoda Model Discussion Area category; Just out of interest. For over 40 years I ran company cars (Fords, Volvo's BMW) all serviced at main dealers. ...
Old 22-07-2008, 11:10   #1
Default Why Brake Fluid Change?
For over 40 years I ran company cars (Fords, Volvo's BMW) all serviced at main dealers. Some were quite old (for company cars) when they were part exchanged. Never had a brake fluid change. Why Skoda's?
jos22 is offline
Old 22-07-2008, 11:18   #2
Default Re: Why Brake Fluid Change?
Never had the brake fluid changed? Main delaers???????? Cowboys, you mean?
Brake fluid MUST be changed on all vehicles, not just Skodas, it will be shown in the service manual and is because brake fluid is hygroscopic, that is it absorbs moisture from the air. Normal change times are 2 or 3 years.
Water in brake fluid makes for a reduction in its boiling point and allows corrosion of ferrous parts. Lower boiling point means that pockets of gas are more likleyt o form and gas is compressible, where liquid is not, so gas bubbles mean that the pressure in the system is taken up by the gases and drops - reduced brake pressure means redcued braking, or total loss.
Any dealer who does not include brake fluid changing in their normal serviceing is severely (even criminally) negligent, no matter the manufacturer.
fireftrm is offline
The Following 2 Users Say Thank You to fireftrm For This Useful Post:
Fabia 12v (22-07-2008), jos22 (22-07-2008)
Old 22-07-2008, 11:21   #3
Get out the way
Taxi 219's Avatar
And putting the driver in danger too.
Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged
Previous: 06 Octavia Mk1 1.9TDi Classic with + pack
Sadly missed: 97 Nissan Primera 2.0TDi SLX
Taxi 219 is online now
The Following User Says Thank You to Taxi 219 For This Useful Post:
jos22 (22-07-2008)
Old 22-07-2008, 11:24   #4
symonevans's Avatar
yup every 2 years
symonevans is offline
The Following User Says Thank You to symonevans For This Useful Post:
jos22 (22-07-2008)
Old 22-07-2008, 12:04   #5
Thank you all for your replies.
The 2-3 year change could have excluded the Fords, not the Volvo's or BMW's.
jos22 is offline
Old 22-07-2008, 14:26   #6
No Fords definitley have brake fluid changes in their service schedules, at 24 months I believe. As such the changing of brake fluid is a normal part of set interval servicing, so may never have shown up as additional work, just the fluid on the lubrication and fluids section of any invoices. Menu servicing (the way most main dealers do it) include all the work set for that interval.
fireftrm is offline
Old 22-07-2008, 14:35   #7
Why So Serious
fatty5000's Avatar
I had my fluid changed at the weekend.
The difference is like night and day.
Well worth doing.
fatty5000 is online now
Old 22-07-2008, 15:25   #8
FocusZtec's Avatar
Owned Fords most of my life and its every 2 years for a brake fluid change iirc.
Skoda seems inline with most. To be honest, if there was ever a part of the car I'd want to over service and make sure were 100% - its the brakes!
Lee
http://img.photobucket.com/albums/v610/FocusZtec/neiloctypipersignature.jpg
Thanks to JKM:
REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - and enough room for a proper trip to B&Q!!!
FocusZtec is offline
Old 22-07-2008, 17:50   #9
Hairy Yeti
Lummox's Avatar
A dealer can recommend it is done but its not part of the regular service schedule it is an additional item and thus has a charge with it, this means some people dont bother havng it done.
Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is offline
Old 22-07-2008, 19:18   #10
jamesmckelvie's Avatar
you could do it yourself, its very easy
1.9 TDI Elegance - Cappuccino Beige
Plenty enough power and torque for the economy offered
jamesmckelvie is offline
Old 22-07-2008, 21:09   #11
Why So Serious
fatty5000's Avatar
Unless you balls it up then it's quite difficult to correct iirc
Old 22-07-2008, 21:49   #12
About 10 years ago I had (what seemed like) total break loss on the first press of the pedal when approaching a round about....scary as hell. Second press the brakes started to work and third press I stopped the car. Called the AA and they said it was boiling brake fluid. Got it changed the next day and all was fine. Definitely worth doing!
stacon is offline
Old 23-07-2008, 18:43   #13
slider's Avatar
Todays BMW certainly have regular brake fluid changes.
Could it be that it was done as part of your servicing but simply not itemised?
The man with no sig thingy
BMW 118d M Sport
Past cars - OctaviaII 1.9TDI DSG, OctaviaI 1.9 TDi, Focus TD Est, Rover 418 TD, Montego TD, Cavalier D, Astra 1.3, Escort Mexico Mk1 (still to be beaten for fun), Viva 1.3, Simca 1100
slider is offline
Old 23-07-2008, 18:52   #14
Being an ex-fleet driver, they do the most minimal servicing they can get away with. My Clio had original brake discs, original brake fluid and totally shot dampers at 100k. Yep, 100k from the discs. The were the thickness of 10p pieces.
Vauxhall Astra Sporthatch, 1.9CDTi-150 remapped to 200hp/310lb-ft.
Astra owner and driver by night, Octavia driver by day...
_ZS_ is offline
