This is a discussion on Alex's Fabia vRS Estate Project within the Project Journals forums, part of the Skoda Model Discussion Area category; As many of you are aware, I am indeed in the middle of a small project, making 2 cars into ...
| Old Skool Fan Join Date: Jan 2004 Location: Bucks
Members Car: Skoda Fabia vRS Thanks: 0
| Alex's Fabia vRS Estate Project As many of you are aware, I am indeed in the middle of a small project, making 2 cars into 1! A 2004 (54) Fabia vRS and a 2002 (02) Fabia Comfort Estate. Although this seems a relatively simple project, it involves a lot of swapping of parts and plenty of space is needed to store all the parts, its amazing how much stuff there is in 2 cars! I currently have both cars stripped to bare shells, with doors on. No wiring, pipework, engines, trim etc. The vRS engine is undergoing some surgery: New cambelt kit, waterpump, clutch, different turbo, cleaned and honed manifolds, modified egr assembly, water/methanol injection....etc Along side the cars in the garage is a box of other goodies to fit to the estate: Coilovers, 312mm grooved brakes, uprated rear brakes, Milltek exhaust (will be modified to fit estate), Black Headlights, Xenons, 8x17" wheels..... etc On the way from the Czech Republic is a vRS rear bumper to fit the estate, a large rear boot spoiler, modified dash parts and few other nice bits, I also have a vRS front bumper and a few other bits to put into paint at the same time. Should be a much more practical car when finished with some nice parts and good spec: Xenons, Cruise, Traction Control, Sat Nav etc Hope to have it all finished in about 2-3 weeks, as i'm only spending a few hours a week doing it, but as those of you who know me, you will understand that things have to be just right, no cutting corners etc! Guess this comes from working in F1?? Alex |
| The Following User Says Thank You to ninja_alex For This Useful Post: | Colm Cushen (15-10-2008) |
| .:Robbo:. Join Date: Sep 2006 Location: Swindon or Bournemouth
Members Car: A Clio 1.2 16v Thanks: 215
| Re: Alex's Fabia vRS Estate Project Can't wait to see this - Goodluck Alex.
__________________ Current: Renault Clio 1.2 16v Dynamic Sold: Honda Civic Type R Skoda Fabia vRS |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 75
| Re: Alex's Fabia vRS Estate Project Please tell me how you're doing this? Using last year's F1 season goodies? ![]()
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| go green Join Date: Jan 2005 Location: Rochester, Kent
Members Car: Roomy 3 & Fabia Thanks: 167
| Re: Alex's Fabia vRS Estate Project Can't wait to see this. also the one that Lummox is "making" |
| Re: Alex's Fabia vRS Estate Project Going to be interesting with two being built around the same time. |
| Re: Alex's Fabia vRS Estate Project How you getting on Ross, whats your timescale? Alex |
| Re: Alex's Fabia vRS Estate Project A few photos I have: Engine bay on he estate, stripped, cleaned and ready to take the vRS underbonnet loom: And the Donor vRS minus its front end: |
| Re: Alex's Fabia vRS Estate Project Timescale will probably be a bit longer as I have to strip the car down further than that, also Wiebos estate wont be ready to build until December when he is out of the country. Nice to know someone else is doing it aswell, be interesting to see how they turn out compared to each other. are you fitting OE Xenons or an aftermarket kit? |
| | #10 |
| Re: Alex's Fabia vRS Estate Project I have started putting it back together in the photo, now has new ABS unt fitted, brake pipes, gear linkages, wiring harness fitted etc I am fitting aftermarket xenons, have them in my current Fabia and personally, i think they are better than the OE units Alex |
| | #11 |
| Re: Alex's Fabia vRS Estate Project Excellent stuff, you got ASR or ESP? |
| | #12 |
| Briskodian Join Date: Jul 2006 Location: South Birmingham
Members Car: Red Octavia vRS 1.8T (20v) Thanks: 46
| Re: Alex's Fabia vRS Estate Project Looking forward to it
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() |
| | #13 |
| Re: Alex's Fabia vRS Estate Project Last night:
Hopefully get the car wiring harness and dash section into the car this weekend, providing I can get the pedal swapped OK, finish the brake lines and then hopefully get the engine and subframe bolted back in too. All systems go! Alex |
| | #14 |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 200
| Good luck Alex Should be interesting when all is carefully put together ![]() Bas
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| | #15 |
| RXStu Join Date: Oct 2006 Location: Uxbridge, Middlesex
Members Car: Grey RX8 231 Thanks: 0
| Re: Alex's Fabia vRS Estate Project mental! Fair play to you that is some hard core mechanical knowledge there. Looking forward to seeing the end result!
__________________ 1st propper car - Fabia VRS 170BHP + other mods. 2nd propper car - Mazda 3 MPS aero 260BHP + other mods Current propepr car - Mazda RX8 231 230BHP + other mods Love modding |
| | #16 |
| Re: Alex's Fabia vRS Estate Project [yawn] Umm, I forgot to say I copywrited the vRS conversion back in 2005 when I did mine, so I'll be chasing you for royalties, Alex! and Wiebo! ![]() Actually, just info on the rear brakes plans would be enough. ![]()
| | #17 |
| Om nom nom nom Join Date: Feb 2003 Location: Manchester
Members Car: A White Car Thanks: 79
| Re: Alex's Fabia vRS Estate Project ECS do rear brake upgrade kits that use the standard calipers |
| | #18 |
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 46
| Re: Alex's Fabia vRS Estate Project Nice job ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
| | #19 |
| Re: Alex's Fabia vRS Estate Project Dashboard and car wiring harness now installed, as expected the rear lighting loom is too short and needs extending. Engine now finished ready to fit, water injection fitted to manifolds etc. Will post some more pictures later. Hope to get the engine in today and maybe the coilovers fitted Alex |
| | #20 | |
| Re: Alex's Fabia vRS Estate Project Quote:
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! | |
| | #21 | |
Members Car: '97R BMW 328i Saloon Thanks: 679
![]() And Jason, you didn't do a vRS conversion ![]() Good work Alex, should be a nice car when done!!
__________________ 97/R BMW 328i in Boston Green. ![]() | |
| | #22 |
| Re: Alex's Fabia vRS Estate Project Was the first PD130 into a non vRS fabia to my knowledge. ![]() PS: Alex - If you read this - got my bumper fine ta, and it's fitted. Good colour match too which was pleasing
| | #23 |
| Re: Alex's Fabia vRS Estate Project Good progress made today, engine in, radiators mounted, bumper bar fitted. Then got all 4 hubs, coilovers and brakes fitted. nearly driveable! Just the interior to sort now, not sure what seats i'm putting in it at the moment.... Looking into some recaros or TT seats Pics to follow Alex |
| | #24 |
| Re: Alex's Fabia vRS Estate Project Good progress indeed mate, well done. |
| | #25 |
| 207/340 Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 457
| Re: Alex's Fabia vRS Estate Project Good luck with it Alex. Looking forward to seeing the finished product Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
