Coming soon, the greatest Favorit project ever! (Probably)
This is a discussion on Coming soon, the greatest Favorit project ever! (Probably) within the Project Journals forums, part of the Skoda Model Discussion Area category; Coming this Autumn to a project journal near you.... Probably the most outrageous Favorit conversion yet.... The Electric Favorit! Henceforce ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Project Journals
Old 30-05-2008, 14:18   #1
Default Coming soon, the greatest Favorit project ever! (Probably)
The Electric Favorit! Henceforce to be known as "Project Favelec"!
Some taster pictures below
favguy is offline
Old 30-05-2008, 14:23   #2
Default Re: Coming soon, the greatest Favorit project ever! (Probably)
Revised instrumentation, including main system current use, voltage & auxillery system voltage. Also note lack of petrol engined fuel and temperature guages
Master electrical system shut off in place of previous (useless & faulty) headlamp dip system.
Yes it's the FavElec!
Unleaded sir?
No thankyou, I prefer 230 volts !!!
Taster specifications:
(subject to updating)
Base Vehicle: 1995 Favorit GLXIe Flairline, 20,000 miles from new, restored to as new condition.
Electrical System:
144Volt Direct Current system, power source 18 x 8V 170Ah or 190Ah, "Trojan" lead acid traction batteries in series pack configuration.
Voltage and current control via
Curtis controller 1231C-8601, supplying an FB1-4001A Advanced DC Series Wound Motor rated at 30HP (equates to a petrol engine of approx 90BHP)
Transmission will remain standard but become semi automatic, or "clutchless" in the new drive system
Approximate calculated performance specs:
0 to 60mph in 12 seconds
Top speed of 85+mph
Constant crusing speed capability of 70mph
Maximum range of 60miles at cruising speed
Full recharge time from any 230v wall socket from full discharge, approx. 6 hours.
Running costs approx. equivalent to 150mpg on a petrol driven equivalent, (& no car tax!)
Local emmissions: ZERO!
Emmissions at power station source to provide charge current, approx 25% of equivalent petrol driven Co2 emmissions assuming most dirty production, ie. coal. Nuclear would be virtually ZERO!
Any questions, feel free to ask me
favguy is offline
Old 30-05-2008, 14:47   #3
Briskodiodion
TeflonTom's Avatar
cool!
TeflonTom is offline
Old 30-05-2008, 14:58   #4
Not a lot of people know this, but Skoda actually built and sold an electric Favorit, the Favorit Electra in the early nineties...
favguy is offline
Old 30-05-2008, 15:11   #5
tdirob's Avatar
I dare you to lick the batteries....
On a more serious note, how much is it going to cost, and where has the electric system come from??
Golf GT TDI - Standard (at the minute)
tdirob is offline
Old 30-05-2008, 15:17   #6
Total estimated cost is £6,000, all the main kit is coming in from California Batteries are also from US, but can be sourced here from golf cart supply specialists.
You can lick the 144v supply if you'd like, would you also like a wet sponge on your head so you don't suffer too much? LOL
PS, and before anyone comments, as this much kit is going on a lovely Favvy with a market value of all of about £300, it will be insured with a specialist kit car insurer with an agreed value to cover the full build cost
favguy is offline
Old 30-05-2008, 16:18   #7
tdirob's Avatar
Chicken
Looks like it will be a good project though. Are you doing all the work yourself??
tdirob is offline
Old 30-05-2008, 19:17   #8
Nelly the Felly
philje123's Avatar
This is so cool... always thought about doing something like this to a car!!
Keep us updated please.... very interested to see how things comes along!
Phil
96 Felicia Laurin & Klement 1.3 spi Hatchback (Now with Auto Headlights)
-New timing chain
-MOT passed with flying colours 10/2007
-71,000 miles and counting!!
philje123 is offline
Old 31-05-2008, 00:22   #9
Yes, I'm planning to do all the work myself, fortunately I studied Electrical Engineering so am ok with it all, although to be honest, it's not that difficult and there are loads of US forums to get up to speed on the topic
I'll do you all a full photo build log as I progress.
favguy is offline
Old 06-06-2008, 17:09   #10
is hating life!
youngsyd's Avatar
Cant wait to see it mate!
The bonnet ok?
Id rather be a nobody than an overated someone...
youngsyd is offline
Old 06-06-2008, 17:10   #11
is hating life!
youngsyd's Avatar
Have you worked out how much it would cost to charge up?
youngsyd is offline
Old 08-06-2008, 15:02   #12
Hi Steve,
Yes the bonnets the right colour, and I've polished it so both sides are shiny now! I've got to seam seal and paint the inside outer edges yet to match, and it won't get fitted until the engines taken out and the motor and all the electric kit has been installed in the engine compartment.
When it's finished I'll bring it to the local Skoda meet!
I can't tell you what charging cost will be yet, until I've checked what I'm paying per Kwh for my electricity or tried the charger on the battery pack (which I don't have yet!) but I expect it to cost around £2 per charge, which should give a range of between 60-80 miles depending on final weight, efficiency & driving style.
*UPDATE* 14/07/2008, It will only cost around 55p per charge when I get on the right nighttime tariff
Regards
Paul
favguy is offline
Old 08-06-2008, 15:31   #13
Mongreller
devonutopia's Avatar
cool project. but with some of my journies, unless it were capable of 400+ miles on one charge, or there were really really regular places you can charge up at on the way, it would not be feasible for me.
Have you worked out how long it will take to recoup the £6000? For me in my mental maths, I would imagine in fuel terms alone, it's 300 miles for £10 (say) compared to 300 miles costing £35 in unleaded. £25 per 300 miles recouped, £6k back in 72,000 miles. Then there's the £200 (is it usually?) road fund license per annum. What wear and tear like on electric motors? I imagine reliability is good over combustion engines in general?
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 08-06-2008, 16:54   #14
.:Robbo:.
Robshaw's Avatar
Smart A$$ .
I like the idea of this - to be honest I would have to see how reliable it was before doing all that to my car.
Current:
Clio 1.2 16v Dynamic
Sold:
Skoda Fabia vRS
Honda Civic Type R
Robshaw is offline
Old 08-06-2008, 17:10   #15
Mongreller
Originally Posted by Robshaw View Post
Smart A$$ .
I did do the 72,000 miles bit on a calculator though.
Old 08-06-2008, 20:43   #16
go green
mdk1's Avatar
Will like to see this when its finished.
Good luck with the build.
Mike.
Mine Skoda Roomster 3 TDI in matallic Anthracite Grey MK**LJK
Swmbo's Skoda Fabia 2.0I Elegance in Dark matallic Blue MK**LJK
mdk1 is offline
Old 09-06-2008, 14:26   #17
Devonutopia,
Regarding the range, you are of course correct, if I need to do long journeys I'll use my other car (which is Petrol/LPG powered!) My normal daily car use almost never exceeds around 50 miles max so it'll be fine 90% of the time.
In any case, when the original Lead Acid battery pack dies after around 4 to 5 years of use, I intend to upgrade to Lithium Iron technology, this will give a range of around 150 miles due to much higher capacity and approx. 300kg weight saving!, these packs are prohibitively expensive now, but like any new tech. in 5 years should be affordable, they also have an expected life of 100,000 miles plus.
As to cost efficiency of the project, well in reality it's just not cost effective, especially compared to running on LPG as I do now, the break even point is probably a decade away, this will lessen when petrol gets to around £3 a litre in about 3 to 4 years, but it's still not going to save me money any time soon...
Motors last at least 1,000,000 miles (no kidding!) with brush changes every 80,000 or so, takes 15 minutes and costs a tenner or so! The costly bit is the battery pack. but remember, you never need to change oil, oil filter, air filter, plugs, leads, cam belt/chain, exhaust, clutch etc..
The reason for the project is just to do it, for the pleasure and the hell of it and to prove I can, I like engineering challenges and taking one thing and re-engineering it into something else, I suppose I'm just very eccentric, after all I think favorit's are great
Robshaw,
Reliability depends on how well engineered the conversion is, there is no universal kit for this kind of thing!, beyond choosing well matched and reliable drive system and safety components, which is quite easy due to the experience of 100's of americans who've been doing this for the last 20 years and online forums, it's all prototype work, really shouldn't be taken on by anyone who doesn't have the necessary experience in electrical and mechanical engineering along with good metalworking skills, (especially the electrical side, 144v high current DC can literally fry you (electric chairs use high current DC!) or shorting out the batteries can cause a big explosion!)
Most importantly, you need a huge amount of patience! Only time will tell if my effort is reliable...
For anyone who's interested, look up DIY Electric Car Forums - Electric Vehicle Build and Conversion Community
favguy is offline
Old 11-06-2008, 21:03   #18
I was way out on the charge cost by the way, if I switch to an economy night time tariff, it's about 55p per charge
favguy is offline
Old 11-06-2008, 21:36   #19
tdirob's Avatar
how heavy are the batteries?
tdirob is offline
Old 12-06-2008, 11:04   #20
BRISKODA Staff
Looks mighty interesting project.
I can testify to the power of traction battery packs when shorted (by accident) I completely fried the tendons in a finger over 40 years ago.
I assume this controller is a dc chopper type device driving the motor in a pulse width / speed manner. The ones i worked on used SCR's that occasionally 'fired through' with either hilarious results or more often disasterous collisions with buildings and people!
Good luck with it all
JohnD is offline
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94
