This is a discussion on Project Q-Felicia within the Project Journals forums, part of the Skoda Model Discussion Area category; i think i may need my head testing for even contemplating such a rediculous 'money pit' project but............... who out ...
Members Car: Fabia 2.0/Felicia Thanks: 48
| Project Q-Felicia i think i may need my head testing for even contemplating such a rediculous 'money pit' project but............... ![]() who out there know's what this is for eh?? ![]() Last edited by TeflonTom; 31-03-2007 at 18:54. Reason: new title |
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 46
| Re: OMG! It Begins! hehehe - I have this feeling you're right somehow there - should be very interesting I'd imagine though ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 75
| Re: OMG! It Begins! throttle bodies? ![]()
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| Re: OMG! It Begins! |
Members Car: 4x4 turbo estate Thanks: 17
| Re: OMG! It Begins! was just about to suggest throttle bodies, darn it. go for big lairy bike carbs ![]()
| not a bird!!! Join Date: Sep 2006 Location: pixi said not to fill my box
Members Car: 1.6l felicia 1998 Thanks: 1
| Re: OMG! It Begins! i've been a busy boy this week(apart from being at work )here's the loom, it's basically a cut 'n' shut on the oe loom, with certain sensors re-located to different positions, and a couple of sensors removed completely. this was a painstaking job which requires a fair bit of skill (and head scratching ) plus access to wiring diagrams etc![]() A: 36pin Main ECU plug from emerald m3dk B: Link to dashboard loom/fusebox C: Ignition Amplifier/Coil D: Coolant Sensor E: Lambda Probe Connection F: Hall Sensor G: Injector 4 H: Injector 3 I: Injector 2 J: Injector 1 K: 3x bare wires for throttle position sensor L: Oil Pressure Switch if anybody else is doing a similar installation and needs a loom made up for the purpose then let me know, if i'm in a good mood i may do it for you (if you join freedom!!!)Last edited by TeflonTom; 20-03-2007 at 23:37. |
| Re: OMG! It Begins! quite a lot of people are 'scared' of fuel injected engines when it comes to modifications and the like, but they are far easier to get right than dirty old carbs, picking the right jet sizes is a fine art best left to people with lots of patience ![]() |
| | #10 |
| Re: OMG! It Begins! hi folks, todays trip to the scrapyard(or 2 ) has been quite fruitfulla neglected looking 1000cc mk4 polo has given up it's fuel rail in the name of motorsport and it was only a tenner![]() it took me ages to clean it thouroughly but it's come up like new now.... believe it or not these cost about £180 new, which imho is disgusting for a piece of plastic |
| | #11 |
| Briskodian Join Date: Jul 2006 Location: Glasgow
Members Car: Totally Stock:-) Thanks: 6
| Re: OMG! It Begins! Excellent work sir! that'll give a lovely roar, and a well set up management system will get you the best from it. As for the loom-looks almose OE! Any plans for TB's on Woodie will have to wait until I get the join between downpipe and the rest of the exhaust re joined ![]() |
| | #12 |
| | #13 |
| | #14 |
| Briskodian Join Date: Aug 2006 Location: Wrexham
Members Car: Golf GT TDi Thanks: 25
| Re: OMG! It Begins! For the less technically minded among us... (god I hope I'm not the only one!) what's going on? ![]() Last edited by tdirob; 27-03-2007 at 15:13. |
| | #15 | |
| Re: OMG! It Begins! Quote:
this allows him to control preciely the volume of air each cylinder recieves, ergo making the engine better balanced and more responsive | |
| | #16 |
| Re: OMG! It Begins! ![]() there's two main reasons it produces more power with multiple intakes 1) the fuel air mixture presentation to each cylinder is more equalized, this can be really bad on some plenum fed engines 2)the is less flow restriction Last edited by TeflonTom; 27-03-2007 at 15:26. |
| | #17 |
| | #18 |
| Re: OMG! It Begins! i am going to put trumpets on there but i dont know what length yet, i havn't actually ordered the throttle bodies yet so i'm not sure what length i'm going for yet. i going to aim for around 450mm total intake length(including the trumpet/body/manifold/port) to start with and see how it goes when she's running on the dyno... i may add or take away length from the trumpets to fine tune the torque curve once it's up and running |
| | #19 | |
Thats sounds like a good plan - it also sounds bloody complicated! Goodluck with the work | |
| | #20 |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 200
| Respect Tom
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| | #21 | |
dont worry, Took me a while to comprehend as well!best thing about them is the induction noise! tom may I suggest you make the trumpet mounting "quick release" in some way so you can have trumpets for different requirements? | |
| | #22 |
| Re: OMG! It Begins! yeah i've been thinking about that but it seems a little on the dangerous side to me, you have to remember that amount of vibration these things are subjected to... if one of the fixings came off it would jet sucked into the engine and it would wreck the engine.... i think for now i'll just use M5 cap screws to hold the trumpets on, so all that is needed is an allen key to swap them |
| | #23 | |
sounds like not a bad idea at all! could you not thread the part they mount to so they just screw on? assuming you have a tap and die set big enough ![]() | |
| | #24 |
| Re: OMG! It Begins! is this lot going on a 1.3??? or a 1.6? |
| | #25 |
