This is a discussion on Furby VRS Handling Quirks within the Racing and Advanced Driving Techniques forums, part of the Members Area category; Well it's finally happened... Furby is on it's way out and Octy 2 is on it's way in. As much ...
| Briskodian Join Date: Aug 2006 Location: Liverpool
Members Car: Nothing :-( Thanks: 52
| Furby VRS Handling Quirks Well it's finally happened... Furby is on it's way out and Octy 2 is on it's way in. As much fun as the furby was to drive in terms of acceleration and overtaking, I feel (a personal opinion) that the handling really let her down; she rolls like a bus! I drive a completely standard Furby VRS... no mods because I don't want to trash my warranty (I'm no boyscout by the way )Thing I've noticed about driving a turbo diesel car is that the throttle response exiting corners is a lot different from a petrol car... takes a second to pick up which can place you in a couple of dicy positions when it's wet. The only solution I've found is to drop a gear low than required to take the bend... therefore keeping the turbo spooled up and giving you the grunt to safely pull you through the bend on your side of the road. Course I could have just invested in a ARB... ![]() Opinions welcome
__________________ I was just a figment of your imagination! After nearly two years and a hell of a lot of fun, I'm off - all the best to everybody; this is Robbo signing off! |
Members Car: 2004 Fabia vRS TDI PD130 Thanks: 14
| Re: Furby VRS Handling Quirks Rolls like a bus. Yep Wonder if some cupra dampers would help Rear anti roll bar does reduce the roll at low speed but its still there when pressing on. Main advantage with the bar is the handling. Makes the car more neutral (still understeers when pushed beyond the limit) and more adjustable with your right foot.
__________________ John 2004 Skoda Fabia vRS - Xenons - Heated Seats - Cruise Control - Passenger Airbag Deactivation switch - Side Airbags |
| | #3 | |
Members Car: Fiat Panda Thanks: 15
| Re: Furby VRS Handling Quirks Quote:
Chris
Members Car: Octavia TDi110 Thanks: 65
| Re: Furby VRS Handling Quirks /\ and not like anyone ever got caught off-boost in a petrol-engined car? ![]() |
| Re: Furby VRS Handling Quirks Ooooh I didn't think of that... it could have been the "drive-by-wire" issue actually... but I'm still convinced that the delivery in a petrol engine is better. That said... did anybody else have to adjust thier driving style when switching from a petrol to a diesel engine... I've noticed that you have to shift a lot more... and perhaps this problem just comes from me being lazy and staying in the wrong gear for a turn ![]()
| Om nom nom nom Join Date: Feb 2003 Location: Manchester
Members Car: A White Car Thanks: 79
| Re: Furby VRS Handling Quirks i wouldnt say its the power delivery of the engine... its you being in the wrong gear I take Shiftys standpoint on this.. the Octy II vRS may be a quicker car, but its nowhere near as satisfying take it by the scruff of its neck and throw it down some twisties ![]() |
| | #7 | |
__________________ I was just a figment of your imagination! After nearly two years and a hell of a lot of fun, I'm off - all the best to everybody; this is Robbo signing off! | |
| Re: Furby VRS Handling Quirks When you approach the corner, try braking before the corner and select a gear which will allow you to apply the power firmly through the corner (before you start to steer). I'd not noticed a problem with the DBW throttle, but have found that if you squeeze it rather than floor it, it responds better. And yes, petrols are better to drive Just a shame the economy isn't very good ![]() I also hope the Octy II is better to drive that the Golf MkV which is just a bit dull! Chris
| | #9 | |
| | #10 | ||
| rodeo monkey Join Date: Jan 2005 Location: blah, blah, f*****g blah!
Members Car: an old focus Thanks: 13
__________________ Note: This statement was most likely made with a usual dry sense of humor. It was in no way made to offend anyone who may be easily offended. If you find yourself offended by such a statement, you needed more hugs as a child, or more beatings. Whichever you didn't get enough of, you need more of. Probably beatings. Quote:
| | #11 |
| Re: Furby VRS Handling Quirks I've done my fair share of track days and even had a crack at amateur rallying... I do know how to handle a car... I'm not a noob ![]() I think the major problem I had with the handling on the furby was that my previous car was a civic sport... with civic handling... maybe slightly biased (me not the car). Personally in the fabia I've taken to slowing well before the bend... selecting the gear that'll give me the most grunt in case of emergencies and then make the turn... course we are talking a standard car here ![]()
| | #12 |
| Re: Furby VRS Handling Quirks My mother's car is a Sick Brick. Comments about "Civic handling" do nothing to convince me that the poster can drive! ![]() As for claims about "being off boost", as I said earlier, not like anyone ever got caught off boost/cam in a petrol engined car! ![]() |
| | #13 | |
Don't get me wrong... my Fabia has been the best car that I've owned... you have to drive IT rather than let it drive YOU... I just prefer my cars to be tight rather than loose and floppy. If I wasn't a wuss I'd have uprated the handling and that would have saved me 14k for a new Octy from motorpoint ![]()
__________________ I was just a figment of your imagination! After nearly two years and a hell of a lot of fun, I'm off - all the best to everybody; this is Robbo signing off! Last edited by robb06210; 26-07-2007 at 09:41. | |
| | #14 | |
| | #15 |
| Re: Furby VRS Handling Quirks Right... got you. For a minute there I thought you were stating I couldn't drive I'm not that bad!Still, I see your point about the civic... and like you say, the Fabia gives you lots of hints when turning. Maybe I just never pushed her as much as I thought I could ![]()
| | #16 |
| Briskodian Join Date: Jul 2006 Location: Newport/Preston
Members Car: Skoda Octavia vRS Thanks: 216
| Re: Furby VRS Handling Quirks no problems with DBW throttle here, and mine doesn't "roll like a bus" either? sure it rolls more than some other car's I've had, but it's hardly scary |
| | #17 | |
Chris
| | #18 | |
I wouldn't say the Furby is scary when it rolls... I just don't think it inspires much confidence, which causes people to hold back and not drive to thier full potential.
| | #19 |
| Re: Furby VRS Handling Quirks Personally I don't mind roll, what I mind is a lack of feedback. It's not like race cars, where you can soften off the anti-roll when the going gets slippery. |
| | #20 |
| Briskodian | Re: Furby VRS Handling Quirks "Civic Handling" I have a new 2007 civic sport and it's a total dog! |
| | #21 |
| Re: Furby VRS Handling Quirks I guess it comes down to what you're comparing it to as everything's relative! ![]() Chris
| | #22 |
| Re: Furby VRS Handling Quirks Haven't Fuby's got a knack of ending up on their roof if you push 'em too hard?
| | #23 | |
![]() Chris
| | #24 |
| Briskodian | Re: Furby VRS Handling Quirks Cars wise I have had a few over the last coulpe of years and the best handling was the new ford focus - Lots of sideways fun!!! second best handling was a 51 reg clio dynamic - had brillient brakes and was a lot of fun. Third best was a corolla diesel- bit stodgy but solid and sure footed. The civic understeers too much, feels slow and fat and cumbersome around slow corners, has pee-poor brakes, and lifts its front inside wheels all the time. Its just no fun to throw arround! |
| | #25 |
| Re: Furby VRS Handling Quirks Sideways?! In a Focus? What were you doing in it! ![]() ![]() Chris
