This is a discussion on Trail Braking within the Racing and Advanced Driving Techniques forums, part of the Members Area category; What is trail braking? In essence, it means continuing to brake after having turned in for a corner. The further ...
Members Car: Fiat Panda Thanks: 15
| Trail Braking What is trail braking? In essence, it means continuing to brake after having turned in for a corner. The further you progress into the corner, the more you turn the steering wheel and the more pressure you release from the brake pedal. Typically, the procedure goes like this: -You are hurtling in a straight line toward a corner; -You apply the brakes - fully - while still traveling in a straight line; -At some point, you release a little pressure from the brakes and start to turn in; -As you bend into the corner and approach the throttle application point, you progressively release the rest of the pressure from the brake. What's the point of it? Trail braking helps you rotate the car into a corner by controlling the transfer of weight onto the front tyres, giving them more stick, and thus compensating for any understeering tendency the car would otherwise have. The alternative is: do all of your braking in a straight line, then release the brakes entirely, then turn in. The trouble with this technique is that when you release the brakes, weight - and therefore stick - will be removed from the front tires, just when you need them to be loaded enough to turn the car into the corner. So - unless the car is set up to be driven like this - it will understeer away from the corner. This is typical behavior for 'street' (aka massively understeering) cars that have been adapted for racing. On the other hand, a 'proper' race car will probably oversteer if you don't trail brake. If you turn into a corner with your feet off both brake and throttle, the front tires will have all their traction budget available for turning while the back wheels will be doing some (engine) braking. Net result: oversteer. Application of the brakes settles down the oversteer by substituting a proportionately balanced loss of steering traction (because the brakes are biased towards the front). In fact, you use the brake pressure to control the rate at which the car rotates into the corner. How much trail braking you do at a particular corner - i.e. what percentage of the corner is taken under braking - depends on the angle of the corner. For a 60° corner, you'd typically only trail for a few percent of the corner, for a 90° corner, you'd typically trail brake for maybe 25% of the corner, and for a bigger corner, you could do it for up to 50% of the corner. You are aiming to trail off the brakes until they are released completely at or before the throttle application point (which typically occurs somewhere before the geometric apex). Another way of looking at trail braking is: what you're doing is braking so late for a corner, that you're never going to make it if you carry on in a straight line. In order just to stay on the track, you have to release a little of the pressure on the brake pedal and bend the car into the corner, just to give yourself a little more road - enough extra road to finish the braking. If you find that you've finished braking before the throttle application point in these corners, then you didn't brake late enough. (BTW, if the car won't turn in when you release a little brake pressure, then you probably need to reduce the front brake bias; likewise, if the car swaps ends when you turn in, add some front brake bias).
| Briskodian Join Date: Dec 2004 Location: Calgary, Alberta, Canada.
Members Car: 2005 focus ZTW Thanks: 16
| Re: Trail Braking Good stuff that. my ibeefa responds well to trail braking, a little extra nudge on the steering as you turn in can get the rear a bit skippy, good fun!
__________________ "I don't even know what street Canada is on." Al Capone. |
| Briskodian Join Date: Jul 2007 Location: Winchester
Members Car: Alfa 156 GTA SW Thanks: 0
| Re: Trail Braking I trailbrake (or sometimes just use a lift to help tuck the nose in) habitually on road and track. I find the weight balance of the car front to rear, affected by brakes and throttle, is more important to steering well than what you do with the steering wheel. On track, the benefits of trail braking are huge, unless you drive a really pointy car. If you don't trailbrake, particularly on track, you can reach what I'd call a false limit where you understeer on corner entry, convinced you've reached the limit of the car, when in fact it's a technique problem. I'm always very wary of journalists saying such and such a car understeers or oversteers, these are things the driver does to the car, not the other way around! |
Members Car: '97R BMW 328i Saloon Thanks: 679
| Re: Trail Braking I have done this to great effect when pushing on really hard, and have done for a good year or so now. Its pretty easy to get right, and allows you to carry more speed into the corner, with less tyre squeal to boot!
| Briskodian Join Date: Nov 2006 Location: North West Cumbria
Members Car: VW Corrado Storm Thanks: 6
| Re: Trail Braking I presume this forms part of the basis of left foot braking in rallying, as you "shift" the weight of the car from front to rear, and vice versa. Phil
__________________ My Car - 2.0 TDI Octavia L&K My Toy - 95 Corrado VR6 STORM SWMBO's - 55 Navara |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 11
| Re: Trail Braking does it say anything about it being for a rear wheel drive? |
Members Car: 2004 Fabia vRS TDI PD130 Thanks: 14
| Re: Trail Braking Looks familar. I always braked like this when briskly driving ever since I past my test.
__________________ John 2004 Skoda Fabia vRS - Xenons - Heated Seats - Cruise Control - Passenger Airbag Deactivation switch - Side Airbags |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 75
| Re: Trail Braking Well, to put the other side, I was told I should not be braking to put weight on to the front wheels during the corner, as this is what unweights the back end and causes oversteer / skidding (essentially pushing all weight onto one front tyre) - I guess this is the case with full braking in the bend, but I was told to scrub speed off before the bend, and be just on the gas a bit through the corner. Also, I was told not to take the racing line but to position myself on the left (for a right hander) and by the centre line (for a left hander) to increase vision for myself and oncoming cars.
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
Members Car: Octavia TDi110 Thanks: 65
| Re: Trail Braking Works beautifully with Skodas, cos you get the weight transfer done before turning. |
| | #10 | |
| Re: Trail Braking Quote:
__________________ John 2004 Skoda Fabia vRS - Xenons - Heated Seats - Cruise Control - Passenger Airbag Deactivation switch - Side Airbags | |
| | #11 |
| Re: Trail Braking I agree with your approach, Jase and trail braking is not really a technique I've found a need for in road driving, although if you're comfortable LFB, it can be used to good effect in an auto where you can trail brake and feed power to keep the car perfectly balanced. Should be applicable to all drives of car though as it's just a technique to shift weight over the front wheels, much like applying power is a way of shifting weight over the rear wheels. Chris
| | #12 |
| Briskodian Join Date: Mar 2003 Location: Somewhere in Herts
Members Car: Hyundai Coupe V6 Thanks: 0
| Re: Trail Braking I've been trail-braking while pushing on or on track days for quite a while now. Was a technique I picked up back in my karting days and it's just stuck with the car too. Have always prefered driving with a light tail end when pushing on or racing. Is easier to carry on driving fast with a bit of oversteer than understeer. One of the people I've seen racing recently who uses it to good effect is Lewis Hamilton, especially at Monaco. Reminds me of my style when karting.
__________________ Graeme Ex Skoda owner twice over. |
| | #13 |
| Re: Trail Braking he is an ex karter too. |
| | #14 | |
| rodeo monkey Join Date: Jan 2005 Location: blah, blah, f*****g blah!
Members Car: an old focus Thanks: 13
| Re: Trail Braking aren't they (almost) all ex-karters? ![]()
__________________ Note: This statement was most likely made with a usual dry sense of humor. It was in no way made to offend anyone who may be easily offended. If you find yourself offended by such a statement, you needed more hugs as a child, or more beatings. Whichever you didn't get enough of, you need more of. Probably beatings. Quote:
| | #15 |
| Re: Trail Braking I'm pretty sure most of them start in karts before moving through the bigger and badder cars up to F1.... I was under the impression that Lewis was one of the few drivers who didn't use trail braking to unsettle the car and braked before the corner to drive round it on the throttle to maintain grip and minimise steering input.... Chris
