This is a discussion on Police Testing Reports within the Reference Materials forums, part of the Skoda Model Discussion Area category; This was on Skoda UK. Thought it might be of interest, if not already spotted. P....
| Briskodian Join Date: Dec 2002 Location: Norwich
__________________ 2005 Fabia VRS - Lemon Yellow - JabbaSport Custom Remap, JabbaSport ARB, Sachs Uprated Organic Clutch, Eibach Pro Dampers and Lowering Springs, PD160 Air Intake and Green Stuff Filter, Forge FMIC, Front Strut Brace, 312mm brakes, Renault Aero Wipers, Cupholder. 2004 Fabia 1.4 16v Elegance - grey - standard, except for the addition of a cup holder and some mudflaps...oh, and some 15 inch alloys. |
| Briskodian Join Date: Mar 2007 Location: Tameside
| Very interesting! I fancied a 1.8 tsi but after reading that report I would say that the vRS diesel is the daddy? |
| The 312mm brake set up on the VRS is IMHO much better than the 288 setup ![]()
| Briskodian Join Date: Sep 2004
| Now that's what you call a test drive!!! Those guys could clearly get jobs mini-cabbing once they've left the police! |
| Briskodian Join Date: Nov 2007
| The 0-60 time of 12.86 seconds for the fabia 1.9tdi was completely inaccurate! This vehicle can do the 0-60 sprint in under 10.5 seconds if driven correctly. They obviously do not know how to drive diesels and must have driven it like a petrol or they drive their cars like grannies!! ![]() Mark |
| | #6 | |
| Briskodian Join Date: Jan 2008 Location: Fife, Scotland
| Quote:
The one they drove may of been a bad un, yours may be a good un. Steve
__________________ Brilliant Silver vRS TDi Hatch,Maxidot,Light Assist,Cruise,Park Assist, Jumbo Pack,OEM Bluetooth Kit, Vag-Com Micro-Can. | |
| Totally valid point Steve, it is very true there are differences between the same engines, due to the reasons you stated. Though, you must admit that it is quite a large difference, i.e. more than two seconds! Not only that but most pd105 vw engines do generally read between 100bhp and 115bhp on a rolling road and therefore all 0-60s should be at least below 11.5 seconds! It is the case that many people do drive diesels poorly, as you will no doubt know, you should change gear while still in the torque band to maximise acceleration. It is conceivable that the police testers are unaware of this!!! |
| | #8 | |
| I feel the need Join Date: Jul 2003 Location: Manchester
| Quote:
ALSO The vehicles will not have been "red lined" in the 0 - 60
__________________ Race Blue Octavia VRS, dual zone climate jumbo airbox, maxidot display, auto dipping rear view mirror/rain sensor, Light Assist, Reversing Sensors, Sat Nav, fatory fit Bluetooth mobile phone kit (Thanks Stu) | |
| | #9 | |
| Quote:
![]() Chris
| | #10 | |
| Quote:
Chris
| | #11 |
| I disagree about the 4k thing Chris. The old 110 was before that as is the 1.4tdi. You can happily go there in a PD140/PD170 but I can't say i really feel the need.
| | #12 |
| Ah I missed out the word "modern" from my post. The 1.4 TDI I drove pulled nicely to 4k rpm. ![]() Whether *you* feel the need is largely irrelevant If you want to maximise acceleration you need to use the full power band ![]() Chris
| | #13 |
| To maximise the acc in a pump duse unit diesel it is best to change gear within the torque band, aiming to start at the base of the torque band in the next up shift. Therefore there is no need to rev above 3500 when trying to accelerate rapidly!! |
| | #14 | |
| Quote:
Chris
| | #15 |
| Because the torque comes early in a diesel engine, the pulling power significantly reduces after about 3500rpm meaning that the power gained from there on is less efficient than the power that could be available in the next gear, at the beginning of the torque band. This of course does not mean speed will not increase in the latter revs, it will of course, but it will not get there as quickly as if one had changed gear a bit earlier. Saying this though it is important to hit 4.5k rpm on a regular basis through the gears as this helps to free up the engine and clean out the injector assembly promoting a more efficient engine. Just my thoughts though! ![]() |
| | #16 |
| Briskodian Join Date: Dec 2006 Location: Ashford, Kent
| It is fair to say that that report makes the decision of my force to change from Mk1 vRS Estates to 2.0FSI 4x4 to 2.0TDI 4x4 quite strange. But hey, who am I to comment, I just work in them every day... I'm sure an engineer is far better placed to say what operational police officers need than an operational police officer...
__________________ twolitretwentyvalveturbooctaviavRS - 2007 Skoda Octavia vRS Previous VAG: 2001 VW Polo GTi, 1995 Audi Coupe S2 ![]() |
| | #17 | |
| Quote:
This thread probably explains it better, but the torque curves seem to have been removed: http://briskoda.net/forums/fabia/fab...ormance/29215/ This plot is also interesting... http://www.superchips.co.uk/curves/vagpd130.pdf Chris
| | #18 | |
| rider of sharks Join Date: Apr 2005 Location: Cumbria
| Quote:
situation A-road overtaking... my RR graph shows I have over 150bhp between 2.5k and 4.5k, so in my mind, this should mean the overtake can be done in 3rd OR 4th, as its in that constant high power band in either gear , at typical a road overtake speeds.... HOWEVER, there is deffinatly more acceleration to be had when using 3rd, and revving to 4.5k, than there is in using 4th (even though its still in the high power band in 4th) and its all down to the gearing, and what is actually being given at the wheels, rather than at the flywheel......
__________________ Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red.... ![]() Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!) | |
| | #19 |
| Briskodian Join Date: Mar 2008
| I wonder if it is possible to find the complete 'library' of test reports for all cars evaluated by the police? |
| | #20 | |
| Briskodian Join Date: Feb 2008 Location: Herts
| Quote:
since then I have a new found faith in the guys, its still them and me though, but those two coppers who ever you were HATS OF TO YOU
__________________ Did I ever tell you the story about when i met Jesus, what a player, he kept getting me drunk, all I wanted was some water | |
