This is a discussion on Battery Disconnection and Re-Map within the Revo Technik forums, part of the BRISKODA Partners category; Hi, I'm getting my cambelt and additional gubbins done at the end of the month and just wondering if Skoda ...
| Briskodian Join Date: Aug 2006 Location: Alnwick, Northumberland
Members Car: Skoda Octavia vRS WRC No 068 Thanks: 9
| Hi, I'm getting my cambelt and additional gubbins done at the end of the month and just wondering if Skoda disconnecting the battery will cause any issues with the Re-Map settings ? Should i just make sure that they know its been re-mapped so as not to play with the settings when putting it all back together Thanks in advance Ross |
| Briskodian Join Date: Oct 2007 Location: Kilkenny, Ireland
Members Car: Fabia vRS Thanks: 37
| Re: Battery Disconnection and Re-Map Disconnecting the battery should have no effect on the re-map in your car as the map is written to non-volatile memory, NV-RAM, in the ECU, a bit like the SD-card in your camera or mobile phone or a USB memory-key on your computer. These flash-memory devices do not need electricity to maintain the integrity of the data written to them. Anyone doing the work you describe would have no need to know the car is re-mapped or any good reason (or even facilities) that I can think of to mess with the map. When they connect their diagnostic equipment to the car, the re-map won't even be detectable, AFAIK. If this is a Skoda franchised work-shop I would hesitate to tell them about the re-map, as it may give them an easy out in the case of problems.
__________________ SKN Stage 1 Remap, 175 / 325, KW V1's, 17" Audi TT Comps & Toyo Proxes, JabbaSport RARB, Cage Mod, Pikey Arch Vent Mod, PD160, K&N Panel Filter, Milltek turbo-back exhaust, 312 mm brakes, Mintex X1's, Osram Night Breakers, Seat Surgeons Leather, Bosch Aero Wipers, brisky sticker & number plate surrounds, 'Ring sticker, SRE Organic Clutch, Sachs DMF, release bearing, cam-belt, tensioner & idler, water-pump, G12+, aux belt & tensioner, engine mount bolts. Turbo Dynamics PD150 Hybrid, Forge FMIC, Allard Race Pipe, CCV catch Can |
| Re: Battery Disconnection and Re-Map Excellent, Thanks for the info. Iwill forget about it and not worry then ![]() Cheers Ross WRC_068 |
| Briskodian | Re: Battery Disconnection and Re-Map Hi Ross, Yea you should have no problems there ![]() |
| re map | amber RS | Octavia II | 8 | 18-08-2008 14:31 |
| Bluetooth connection-disconnection when engine off | ronaldb | Octavia II | 5 | 02-02-2008 15:16 |
| End of Contract Broadband Disconnection Charges | daiking | The Tech Shed | 18 | 16-05-2007 17:23 |
| re-map? | c.swales | Octavia I | 1 | 07-11-2006 12:35 |
| Too soon to re map?? | Charliecat | INTRODUCE YOURSELF! First time visitors, say hello here. | 5 | 06-09-2004 19:43 |
