Lower top speed after remap
This is a discussion on Lower top speed after remap within the Revo Technik forums, part of the BRISKODA Partners category; Before the remap my Fabia vRS could reach ~130mph. (slowly but it got there) The car was remapped a few ...
Go Back   BRISKODA - The Skoda Forums > BRISKODA Partners > Revo Technik
LinkBack Thread Tools Display Modes
Old 23-08-2006, 17:46   #1
Question Lower top speed after remap
The car was remapped a few weeks ago and obviously I had to see whether the top speed had changed Ive tried twice and both times the car got to 125mph and the turbo turned itself off...im guessing to protect the engine. It does this also when I rev too high in 3rd and 4th sometimes. Its still accelerating when it happens so there is more to go.
I rarely do these speeds but its a bit annoying having a car with more power and torque and a lower top speed Other remapped Fabias dont 'overboost' and cut off the turbo like this.
Whats going on Revo?
Dave_Fox is offline
Old 23-08-2006, 19:25   #2
Irf
Irf's Avatar
Default Re: Lower top speed after remap
I've had my car Revo'd and it has a higher top speed. Indicated on speedo is 142mph. Sounds like you have a problem somewhere, one of the techs on here will know more.
Do you have any other mods on the car?
FURBY VRS: cruise, xenons, ESP, heated seats, Revo, Eibachs, Koni FSDs, PD160 pipe, Jabba rear arb, Allard EGR pipe, EGR totally removed, Powertec induction kit, Milltek full system, Garrett GT17, Forge FMIC, 17" Octy wheels, debadged, side strips removed, Seat Cupra splitter...
ICE: Alpine 9835, Alpine changer, Alpine X-Type sub, Alpine MRDM1000 & MRFV340 amps, Alpine Remote Amp Controller, Boston Acoustics Pro60....
NEXT: brakes, engine mount, re-remap & clutch
Irf is offline
Old 23-08-2006, 20:04   #3
BRISKODA Staff
SkodiRS's Avatar
Was it an acutal REVO remap or just the trial code?
If trial code it reverts to a REVO verison of the OEM code and is apparently down on power.
Adrian.
SkodiRS is offline
Old 23-08-2006, 21:16   #4
You cant get the trial remap on the TDI.
I have a BF turbo back exhaust, bigger air intake and K&N panel...
Dave_Fox is offline
Old 23-08-2006, 22:20   #5
Irf
Irf's Avatar
I've read on here somewhere that a full system can affect the turbo as the gasses are released quicker. This makes the ecu go into limp mode at higher revs. You may have a similar problem? Maybe your Revo dealer can tweak the map at the higher revs?
Irf is offline
Old 23-08-2006, 22:27   #6
Oh right lol!
So the exhaust I bought after being told would enhance the remap may actually be causing problems...
Cheers for the advice. I'll pop in soon and ask some questions.
Dave_Fox is offline
Old 24-08-2006, 00:39   #7
Permanently banned
Snoopie's Avatar
Too much boost, sounds like you're car went into Limp Mode to preserve the turbo and engine. Next jobby, is an FMIC too hold the boost! Thats the only way i can think off, otherwise i'm not sure if you're boost could be turned down, but THEN, you'd miss the power!
Snoopie is offline
Old 24-08-2006, 09:00   #8
faboka vrs's Avatar
Over on TDIclub they say a "perfromance" exhaust systems can make the turbo's spin up too quickly resulting in a boost spike. Also heard the same over on SCN with CC. After having an exhaust fitted it began to go into limp mode. I trip back to CC sorted it.
John
Take away the poor damping, inadequate bushes, heavy diesel lump and spongy brakes its not a bad warm hatch
faboka vrs is offline
Old 24-08-2006, 11:10   #9
UberMod™
Neo_VR's Avatar
Plus your car will suffer without a FMIC on a top speed run... ive lost about 15mph top end since i got rid of my fmic
ColGod the UberMod
VXR, Gti, ST, Type-R, vRS, Cupra, Shifty... An MPS fears not these things...
Neo_VR is offline
Old 24-08-2006, 12:03   #10
Permanently banned
Snoopie's Avatar
Saying that, i've seen a gain?
Snoopie is offline
Old 24-08-2006, 15:04   #11
Site Sponsor
Only the case if the adaptation is low, ie: it's had to pull back to compensate for excessively high intake temps, poor quality fuel, etc. Not that it's at all relevent to this thread as we don't offer trial software for diesel applications.
In regards to the lower top end power it sounds as though you're in need of a FMIC!
RevoKev is offline
Old 24-08-2006, 17:25   #12
Ok But I dont wanna spend £££ buying one...
Edit* - It doesnt have low top end power, it gets to a certain speed (125mph) and the turbo cuts out completely. I have to restart the engine to get it back! So would a FMIC stop this?
Dave_Fox is offline
Old 26-08-2006, 17:01   #13
Dave_Fox is offline
Old 27-08-2006, 00:14   #14
Permanently banned
Snoopie's Avatar
Indeed it would! Not only that, but you'd feel the powers completely across the rev-range.
Also, be careful when re-starting the engine, as... The turbo is still .. boiling hot (as it is all of the time) .. Give it time to cool down before booting it again.
Snoopie is offline
Old 27-08-2006, 19:10   #15
Hmmm. Im done spending money on it though so a FMIC isn't gonna happen!
Can the map be tweaked?
Dave_Fox is offline
Old 27-08-2006, 19:23   #16
Permanently banned
Snoopie's Avatar
I presume so, but it will only lower the power, and you'll miss it then. I said at first, i wouldn't ever get a FMIC... Then i did
Snoopie is offline
Old 27-08-2006, 19:47   #17
Harry_vRS's Avatar
Sounds fimiliar
| Silver Octavia v/RS Mk2 | 18" Alloys | Dual Zone Climatronic | Xenons |
| 273bhp 335lbft |
Harry_vRS is offline
Old 27-08-2006, 20:06   #18
Permanently banned
Snoopie's Avatar
Yeah, sorry about that
Snoopie is offline
Old 27-08-2006, 21:51   #19
Irf
Irf's Avatar
Instead of a FMIC, why not try the pikey mod where you put a vent behind the intercooler in arch? That's what Im going to do next.
Irf is offline
Old 27-08-2006, 22:06   #20
Permanently banned
Snoopie's Avatar
To be honest, it's not really going to have much of an affect, The air is still finding it difficult to get to the SMIC.
Snoopie is offline
