Octavia vRS - Standard Vs Revo Trial - Comparison
This is a discussion on Octavia vRS - Standard Vs Revo Trial - Comparison within the Revo Technik forums, part of the BRISKODA Partners category; I thought Id move this over here as I found the results pretty interesting. The subject was an 03 Octy ...
Go Back   BRISKODA - The Skoda Forums > BRISKODA Partners > Revo Technik
Old 14-07-2005, 09:08   #1
I thought Id move this over here as I found the results pretty interesting. The subject was an 03 Octy vRS which was otherwise stock.
Standard figures were:180.1 Hp @ 5840 RPM & 187 ft/lb @ 2320 RPM
Revo Trial figures were: 187.2 Hp @ 4720 RPM & 231.4 ft/lb @ 3560 RPM
I was suprised that there was just a 7 BHP increase but even more suprised at the 44 ft/lb of torque! The car drove way better and you can see from the Block 115 (boost) graph the increase in boost.
Couple of questions, what are the safe limits for boost before overboost protection comes in, I dont want to be that near to them because these tests were done on a fairly warm day and come the cold weather itll be overboosting all the time.
Also, does anyone have any thoughts on the A/F Ratio graph? It seems fairly safe to me but I dont know the specifics of the Skoda engine.
Thanks for any advice, the following graphs were taken with VAG-COM.
Block 120 Torque/BHP:
Block 115 - Boost:
Block 002 - A/F Ratio
I was very impressed by the Revo trial, like I say I was expecting nearer the 207 Bhp Revo quote on the website but the car was vastly more responsive and quicker in every gear.
Thanks for any advice, all comments welcomed
Rgds Rich
Ninj is offline
Old 14-07-2005, 09:35   #2
Escorted Estate
Just proves that the torque makes it a lot more driveable
The bhp doesnt go up all that much as the max torque at higher revs is fairly similar, and the bhp is revs * torque (divided/multiplied by some other junk but hey )
Should be a lot easier on motorway cruising, less need to change gears if you're not in need for max performance
I seem to remember that the 'real' Revo is slightly more tuned than the trial version, but it's worth confirming it with them
You gonna get it REVOd then, after having driven with the trial ?
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
Old 14-07-2005, 09:36   #3
Intereting stuff. I am supprised by how messy it looks. I expected it to be very smooth. It sounds like you have a lot of torque, not sure why you wouldn't have more power though...........
If it drives perfect, i can't see it causing a problem though.
As you can see, custom code is A LOT smoother, but a remapped Octy will gain more torque than power:
Currently sporting a Alfa 156 JTDm Lusso.
Originally Posted by PVO_Dave of VXON View Post
Being an enthusiast doesn't mean you have to be marque blinkered!
Andy vRS is offline
Old 14-07-2005, 09:45   #4
Bear in mind, this is a VAG-COM power curve so it will always be more spikey than a Rolling Road curve.
I also heard that the proper Revo software is more aggresive than than the trial, Id still be suprised if it made 20BHP more than the trial to bring it line with the quotes on the website, but hey, I was suitably impressed and JBS and Jabba are just oo much of a drive, warranty issues withstanding.
Does anyone have any input on the boost/AFR curves?
Also, Block 002, what sort of Air Mass should I be expecting, its pulling 151.7 g/s @ 6280 RPM standard and 159.7 g/s @ 5680 RPM Revo.
Rgds
Rich
Ninj is offline
Old 14-07-2005, 10:16   #5
Mil
Mil's Avatar
Because increasing torque does not always mean increasing power...in fact, sometimes, by increasing torque you make a sacrifice for less power.
Milton Kyvernitis
Private Government
Mil is offline
Old 14-07-2005, 11:18   #6
Yeh, without a doubt. Im away for the next few weeks unfortunately but Im just toying with two options:
a) Go for the 3 Bar map
b) Fit a 4 Bar FPR and go straight for the 4 Bar map
Rgds
Rich
Ninj is offline
Old 14-07-2005, 11:22   #7
4 bar.
Rich.
Skoda Octavia RS
rich1068 is offline
Old 14-07-2005, 11:24   #8
I've heard Kev say that the 4 bar software is an older line now and the regular map offers similar gains. Surely though, you must be better off with a 4 bar FPR even with the regular map?
Thanks
Rich
Ninj is offline
Old 14-07-2005, 11:32   #9
TBH I'm a bit out of touch with the next generation Revo products. When I had mine the choice was straightforward 3 or 4 bar plus whatever SPS you fancied.
Rich.
Skoda Octavia RS
Last edited by rich1068; 14-07-2005 at 11:32. Reason: Mentioning other tuners in Revo's section. Sorry.
rich1068 is offline
Old 14-07-2005, 11:33   #10
Im sure someone from Revo will be along soon to comment.
Custom Code at JBS is just too much of a journey unfortunately
Rgds
Rich
Ninj is offline
Old 14-07-2005, 17:16   #11
Site Sponsor
Hey mate, bear in mind the calculations VAG COM uses to get to the BHP go out the window once software is installed.. thus you don't really get acurate figures from it.
Full software is slightly better all round, plus the added switchability allows you to alter certain parameters.
In regards to options, we don't do 4bar only specific software anymore.. regular software will give you similar driving results to the old software now.. new tricks can be learn't everyday! The stage 2 software that requires a 4bar FPR is also built for cars with uprated DP's, Exhausts, intakes. So is even more 'aggressive'
Hope this helps!
RevoKev is offline
Old 14-07-2005, 17:47   #12
Hi Kev, thanks for the reply.
So can I assume that there would be no point in running a 4 bar FPR unless I have effectively stage 2 mods?
As far as VAG-COM goes, I thought that seeing as block 120 was measuring ASR Torque and the figures from the spreadsheet are just a calculation of this, it should still provide equally as accurate figures to standard. The block 002 MAF and 115 Boost should also read accurately because they are just measuring the amount of air the MAF is flowing and boost vs ambient.
Any idea if 159.7 g/s is good MAF flow?
Thanks again
Rgds
Rich
Ninj is offline
Old 15-07-2005, 13:10   #13
primey's Avatar
How much is the upgrade to Stage 2 software if you are already running a 4 bar old program?
Paul
My Car - Nightfire Blue Superb - 2.5 V6 TDi - Dark Leather Interior - Xenons - Serious Pimp Tints - Sat Nav - Detchable Towbar - Green Cotton Panel Filter - MINTEX Xtreme Performance Brake Pads - Chrome Wing Mirrors - 18" New RS4 Rims - Neuspeed Lower Rear ARB - Pipewerx Custom Stainless Exhaust with 200cel Cat - Custom Code PHASE II Remap - Huge Smile - Can my bank account keep up? ...
primey is offline
Old 15-07-2005, 14:02   #14
Briskoda Staff
VRStu's Avatar
From what I have been reading about using VAG-COM to measure power it seems that measurments on mapped cars are unrelaible as stated by Kev.
Stu
VRStu is offline
Old 17-07-2005, 09:22   #15
Yeh, I've heard it said but nobody seems to be able to say why. Which blocks are affected?
Furthermore, it seems strange that Revo should recommend VAG-COMs use in their SPS3 Tuning Guide for Revod cars, if its so inaccurate.
Ninj is offline
Old 01-08-2005, 14:16   #16
Site Sponsor
It's not inaccurate at monitoring engine sensors, but the calculation is based on airflow and doesn't take into account the likes of more advanced timing.
Upgrade to Stg2 would only cost the difference.. ie: Ł50 + vat!
RevoKev is offline
Similar Threads
New Octavia In Detail ColinD General Car Chat 0 22-04-2004 12:18
National Briskoda Trackday delcac Shows 410 12-03-2004 15:21
Octavia Modifications Real Skoda Maintenance & Performance 0 24-10-2003 10:29
