39,457 Members 1,489,953 Posts
Replacement SPS 3 - Different??
This is a discussion on Replacement SPS 3 - Different?? within the Revo Technik forums, part of the BRISKODA Partners category; My first SPS 3 didn't work so it was sent back to Revo for a replacement one to be sent ...
Go Back   BRISKODA - The Skoda Forums > BRISKODA Partners > Revo Technik
Old 15-01-2008, 00:53   #1
Members Car: Scoda Octavia VRS
My first SPS 3 didn't work so it was sent back to Revo for a replacement one to be sent out. Just received the new one and it appears that the position mode 3 and 4 are different than the other unit. This one has low boost at position 3 and high boost at position 4, the old unit had Boost at position 3 and fuel adjustment on position 4??
MaceyVRS is offline
Old 17-01-2008, 00:02   #2
Re: Replacement SPS 3 - Different??
Can nobody answer this for me????
MaceyVRS is offline
Old 17-01-2008, 11:54   #3
Site Sponsor
Members Car:
Sounds as though you've been sent an earlier version of the SPS3 that has a split boost range (they cover the same range as the one with a single boost range but have twice as many increments).
We stopped making SPS3's well over a year ago and offer a 12month warranty on them, I've just checked and as we had a 'new old' one lying about that we replaced yours with out of good will. Unless you're using it in an R32 where you have fuel adjustment then there's no effect on the functionality of it!
Boost adjustments:
Low boost 9 = Boost 6
High boost 9 = Boost 9
there are just a few more settings inbetween.
RevoKev is offline
Old 17-01-2008, 15:59   #4
Originally Posted by RevoKev View Post
Boost adjustments:
Sorry don't quite understand this bit?? So if I select Boost 9 on low boost setting will that actually give me setting 6??
What is the range on the high boost??
MaceyVRS is offline
Old 17-01-2008, 16:06   #5
Site Sponsor
Members Car:
That's right, we talk about the boost range as '0-9' however the switch you have splits that range into low and high boost. It doesn't span a wider range, it just has more settings inbetween the maximum and minimum. Low boost 0 - High boost 9 is a continuous scale. So...
...if you look at Revo's boost range as 0-9 (6 being default).
Low boost 0-9 is equivalent to boost 0-6
High boost 0-9 is equivalent to boost 7-9 (spans less!)
Meaning you've now got more fine tuning adjustment.
Does that make sense?
RevoKev is offline
The Following User Says Thank You to RevoKev For This Useful Post:
MaceyVRS (17-01-2008)
Old 17-01-2008, 16:32   #6
Yeah, I think so now?!?!? What would you recommend for everyday use?
MaceyVRS is offline
Similar Threads
SPS 2 Battery ? JamesGarner Revo Technik 1 27-11-2006 17:34
