This is a discussion on Revo questions within the Revo Technik forums, part of the BRISKODA Partners category; I'd be grateful if any of the Revo guys could answer these (probably dumb) questions; 1. If I get the ...
| Briskodian Join Date: Nov 2002 Location: Belfast
Members Car: Rally Red vRS Thanks: 0
| Revo questions I'd be grateful if any of the Revo guys could answer these (probably dumb) questions; 1. If I get the full version of Revo software loaded onto the ECU can I use an SPS device to change that code (eg if I bought an SPS device off someone) or do I need a specific version of the code for each SPS (1,2 or 3) configuration? 2. I can't get Optimax or 98 RON fuel in N.I. but I can get BP Ultimate (97 RON); can I use the 98 RON setting on an SPS device (if I had one) with BP Ultimate or would this cause problems?
__________________ Rik Mercurial Ambivert |
| Briskodian | I don't know if this helps but see the post about the JBS Rolling Road day. James is a Revo agent and there's a phone number. Pick their brains without actually mentioning that you're 'overseas.' You may have to be a bit cagey with the first point though.
__________________ Rich. Skoda Octavia RS |
| Om nom nom nom Join Date: Feb 2003 Location: Manchester
Members Car: A White Car Thanks: 79
| IIRC if you had the SPS 3 you could ajust the settings specifically for ultimate.. people are beginning to prefer ultimate to optimax, as its more consistant.. heard several reports of optimax fuel "going off" and loosing its octane rating |
| Site Sponsor | Hi Rik, once you have software installed to your ECU you can use any switch that the software supports (nb. Diesel software only supports SPS1). So yes you could buy a 2nd hand switch, I've seen numerous SPS's on forums so you should be able to save yourself some money. I've monitored my own 1.8T with both Optimax and Ultimate, and yes you will have no problems with running the 98ron setting with Ultimate. I've also noticed that Optimax can 'go off' although 98% of the time (if you fill up at a larger garage where it's regularly changed) it is more efficient than Ultimate. |
| Thanks for the replies guys. My warranty expires next Feb'; I don't know if I can wait that long now. ![]()
| Is Jabba or Revo better for a Fabia vRS? | tfboy | Maintenance & Performance | 22 | 05-10-2003 23:03 |
| Invitation To Revo Open Day | RevoKev | Shows | 27 | 18-07-2003 21:10 |
| Revo Tuning | FightingDiva | Maintenance & Performance | 4 | 15-06-2003 10:30 |
| REVO info | SkodiRS | General Car Chat | 2 | 17-02-2003 18:58 |
