This is a discussion on Revo stage2 and forge spacer within the Revo Technik forums, part of the BRISKODA Partners category; I upgrade my revo stage 1 to 2, since then i was using the forge Switchable Blow Off spacer without ...
| Briskodian Join Date: Nov 2006 Location: GREECE
| I upgrade my revo stage 1 to 2, since then i was using the forge Switchable Blow Off spacer without problem .It will be problem if i use it in stage2 ? ( from now i have turn it of ) |
| Ex-Moddy Join Date: Jul 2005 Location: Hampshire
| Absolutely fine to use with StageII Welcome to the forum btw
__________________ Black magic Octy II vRS MY2008 with Maxidot ~ Xenons ~ Cruise ~ Light Assist ~ Dual Zone Climate Control ~ Rain Sensing Wipers ~ MFD2 Satellite Navigation ~ VAG Bluetooth Phone Kit ~ Milltek Exhaust with 2.75" Downpipe ~ EVOM Ram Air Intake ~ Nuespeed Shortshifter ~ Eibach Rear ARB ~ Koni FSD Dampers ~ Eibach Springs ~ Forge Front Mounted Twintercooler ~ Nuespeed Hi-Flo Intercooler Pipe ~ Nuespeed Hi-Flo Turbo Outlet Pipe ~ Eurojet PCV Valve ~ Forge DV ~Autotech Hi Volume Fuel Pump ~ Nuespeed Torque Arm Insert ~ NGK Iridium Spark plugs ~ REVO Stage II+ Software ~ Matt Black Viper Stripes! |
