Safe Timing Settings
This is a discussion on Safe Timing Settings within the Revo Technik forums, part of the BRISKODA Partners category; What is the safe maximum to run timing before you potentially cause detontation?. The reason I ask is that when ...
Go Back   BRISKODA - The Skoda Forums > BRISKODA Partners > Revo Technik
Old 18-03-2007, 10:51   #1
Ex-Moddy
Makefish's Avatar
Default Safe Timing Settings
What is the safe maximum to run timing before you potentially cause detontation?. The reason I ask is that when I was with you last month I came away with timing set to 6 but after logging a few runs and discussion with JKM in Portsmouth one of the cylinders was -6 and therefore was recomended to reduce my timing to 5.
Also, would having 'colder' spark plugs than the OEM ones have any bearing on your answers to the above.
Hope this makes sense but I would like to know what I can do safely with my Select Plus.
Black magic Octy II vRS MY2008 with Maxidot ~ Xenons ~ Cruise ~ Light Assist ~ Dual Zone Climate Control ~ Rain Sensing Wipers ~ MFD2 Satellite Navigation ~ VAG Bluetooth Phone Kit ~ Milltek Exhaust with 2.75" Downpipe ~ EVOM Ram Air Intake ~ Nuespeed Shortshifter ~ Eibach Rear ARB ~ Koni FSD Dampers ~ Eibach Springs ~ Forge Front Mounted Twintercooler ~ Nuespeed Hi-Flo Intercooler Pipe ~ Nuespeed Hi-Flo Turbo Outlet Pipe ~ Eurojet PCV Valve ~ Forge DV ~Autotech Hi Volume Fuel Pump ~ Nuespeed Torque Arm Insert ~ NGK Iridium Spark plugs ~ REVO Stage II+ Software ~ Matt Black Viper Stripes!
Makefish is offline
Old 18-03-2007, 10:55   #2
Still a ****
delcac's Avatar
Default Re: Safe Timing Settings
Safe = 0........buuuuut you don't wanna do that.
3 - 4
The Red Devil
delcac is offline
Old 18-03-2007, 10:59   #3
Briskodiodion
TeflonTom's Avatar
i not an expert of the fsi engines, but imo going to a colder plug may cause you ignition problems.... the whole point of fsi is to concentrate the fuel/air mixture into a sweet spot in the centre of the combustion chamber, and a colder plug will have a shorter electrode which may not quite reach the 'sweet spot' properly......
i'm sure sombody who knows more about statified injection will come along and give you the answer you need
vorsprung durch czechnik
TeflonTom is offline
Old 18-03-2007, 14:06   #4
Harry_vRS's Avatar
I take it you've read the PDF that comes with it Steve.
There is a guide in there with what the values you put in mean. IIRC for 98/99RON fuel it says timing in the range of 4-6
I tried running 8-6-9 and it wasn't that good to be honest so I turned it down to 7-4-9 and it ran an awful lot better.
Although since installing my Injen intake I sometimes get a very abrupt "hesitation" around the 4k-5.5k RPM range. I don't know whether this is down to the settings I'm using as when I went back to stock power it stopped doing it.
Think I may have a split DV too. Is this diagnosed as loosing umph further up the rev range? Could do with this Forge solution ASAP.
| Silver Octavia v/RS Mk2 | 18" Alloys | Dual Zone Climatronic | Xenons |
| 273bhp 335lbft |
Access Virus C Synthesizer For Sale Click Here For eBAY Auction
Harry_vRS is offline
Old 18-03-2007, 14:16   #5
splash!!!!
bengie's Avatar
the abrupt cutting back sounds like knock to me where the ecu is pulling back the ignition timing and oost to save damaging the engine.
owner of a skoda octavia 4xvrs3
bengie is offline
Old 18-03-2007, 14:34   #6
Briskoda Staff
VRStu's Avatar
The abrupt stop is probably the infamous cut out. I know there is someone trialing a potential fix, maybe get a review next week.
Stu - Freedom Pimp
Stu's Car - 2007 Octavia vRS, Race Blue, Xenons, Columbus Navigation, Rear Parking Sensors, Maxi Dot, Light Assist, Jumbo Box, 18" Alloys, Stu's Cruise Control & OEM Integrated Bluetooth Telephone.
Something for Weekend - 2002 Lotus Elise RaceTech, Gunmetal, Radio, Carpet Mats.
VRStu is online now
Old 18-03-2007, 14:52   #7
Harry_vRS's Avatar
Not really worth buying another DV from the dealers then is it.
Can't wait for the new Forge product to be released.
| 273bhp 335lbft |
Old 18-03-2007, 16:20   #8
Briskoda Staff
VRStu's Avatar
From what I know the Forge product will require a servicable OEM DV as well so your money wouldn't be wasted. Around £26 IIRC.
Stu - Freedom Pimp
VRStu is online now
Old 18-03-2007, 17:15   #9
Ex-Moddy
Makefish's Avatar
Not totally correct I'm affraid. I think you may have misunderstood me but the Forge solution involves a new valve and control part as two seperate components but I'm not sure if the control part is OEM or not, hopefuly I'll have some more information on this later next week.
Unfortunately that may not be for some time either, an important part of the potential fix is on back order and could take up to two months!.
Makefish is offline
Old 18-03-2007, 18:07   #10
Briskoda Staff
VRStu's Avatar
Ahh, well the way you explained it the OEM DV was still used on the end of the new part.
Stu - Freedom Pimp
VRStu is online now
Old 18-03-2007, 19:16   #11
Ex-Moddy
Makefish's Avatar
Nope, t'other way round
Makefish is offline
Old 19-03-2007, 08:08   #12
Ex-Moddy
Makefish's Avatar
Lady E, much that I find your story interesting I cannot see how it belongs in a serious thread such as this ie. my original question was directed at REVO. I have created a new thread for you and put it here.
Please can we keep on topic.
Makefish is offline
Old 19-03-2007, 10:38   #13
Site Sponsor
Ideally you want to set the timing up to see maximum correctional factors of 3º across all four cylinders. You can run a bit more than this for maximum power, but as you're talking of 'safe' settings look for three's across the range.
http://www.revotechnik.com/products/...uide060406.pdf
You want to ahdere to this regardless of the plugs you're running, some people have got on really well using one heat range lower in their cars. Personnally I've always run the same as stock but with a quality NGK plug.
Bear in mind the hotter the car the more the CFs, so it's always good to monitor CF after the cars warm and has been in use.
Hope this helps.
RevoKev is offline
Old 19-03-2007, 12:36   #14
Geordie Lass
Lady Elanore's Avatar
I posted it up to highlight not only how things have changed when putting advance into a fuel injected engine, but also to highlight the dangers of over advancing. I nearly wrote an engine off because of it. So I figured that while it wasn’t a salient story, it was in keeping with the ethos of the thread, even if not directly giving you the actual numbers you were after. Sorry.
Amanda
Lady Elanore is offline
Old 19-03-2007, 14:32   #15
Briskodiodion
TeflonTom's Avatar
right, i've been reading up a bit on stratified injection..... it seems that it isn't solely the ignition advance angles which need adjusting, it may also be necessary for the injection 'pulse' to be advanced too to get a clean burn....
i'm way in over my head here, i dont really understand this type of injection system properly
