39,476 Members 1,490,473 Posts
Switching maps..?
This is a discussion on Switching maps..? within the Revo Technik forums, part of the BRISKODA Partners category; I've been told that after a remap, it takes a while (hour or so) for the ECU to "re-learn". Firstly, ...
Go Back   BRISKODA - The Skoda Forums > BRISKODA Partners > Revo Technik
Old 14-11-2007, 09:21   #1
Gyp
Gyp's Avatar
Members Car:
Switching maps..?
Firstly, re-learn what? Surely the map instructs the system how to work rather than just making a suggestion? Is it tuning the settings based on fuel etc? Or is it tweaking based on driving style? And is this a one-off or a continuous process?
And secondly, with a switchable map, do the settings re-set and the box re-learn every time the map is switched?
Gyp
03 Octavia 1.9TDi Elegange Estate + cruise, towbar, Parrot and anti-jack
54 Fabia 1.2 12V Classic Hatch + cruise, momo strut brace, sunglass holder, Parrot, mp3 and anti-jack
Gyp is offline
Old 14-11-2007, 10:13   #2
Site Sponsor
Members Car:
Re: Switching maps..?
It's called 'Adaptation'...
...basically the ECU requests the engine to work at a certain level, these levels are only achived if all of the engine sensors are working within their expected tolerances. So for example if the car get's really hot for whatever reason (sat on a rolling road, being absolutley thrashed, too high settings being run) then the ECU will 'correct' it's desired requests and the engine will run at a lower level.
You can feel it to some extent with temperature changes and the car behaving differently. Again with different fuel qualities.
When a car a remapped/programmed the ECU is reset so will take a certain amount of time to 'adapt' exactly as it does in standard mode when the battery is disconnected or it's serviced. So in reality adaptation is a continuous occurence and to some extent a safety parameter within the ECU.
When settings are altered within uprated software the adaptation isn't reset, settings will allow you to make the most of the cars potential and set it up to suit your requirements. A fixed level of software is often detuned or relies very much on the ECU to adapt to do the work and is to some extent as you say 'a suggestion'.
For more specific details of switching and the effects have a look at our switch user guide: http://www.revotechnik.com/products/...uide060406.pdf
RevoKev is offline
The Following User Says Thank You to RevoKev For This Useful Post:
Gyp (14-11-2007)
Old 14-11-2007, 19:28   #3
Gyp
Gyp's Avatar
Members Car:
That's rather useful, thank you very much RevoKev
Gyp
Gyp is offline
Similar Threads
maps pinkskud Maintenance & Performance 6 28-12-2006 01:08
Switching maps dan_ferguson Awesome GTI 2 21-10-2006 20:13
Re-maps Johnwg General Car Chat 2 02-02-2006 09:53
