This is a discussion on any plumbers out there? within the The Roadside Hotel forums, part of the Members Area category; the ballc0ck is ither wrongly adjusted or knackered in our downstairs toilet, i want to fix it but can't see ...
Members Car: 4x4 turbo estate Thanks: 17
| any plumbers out there? the ballc0ck is ither wrongly adjusted or knackered in our downstairs toilet, i want to fix it but can't see how to get the lid off of the cystern ![]() its got a twin button dual flush cystern on it with the buttons being on the topof the cystern, you can't just pull it as it pulls on te mechanism, anybdy know how these lids come off?
| | #2 | |
| Briskodian Join Date: May 2005 Location: Hitchin, Herts
Members Car: Fabia VRS Thanks: 0
| Quote:
| i did try thbut it seemed to turn the buttons too. i'll ty again with a bit more effort thanks
| | #4 | |
| Quote:
| not doubting you but i'm not sure about that s there are two buttons as you can see below, it just doesn't feel right when you twist it as you can the buttons twising within the ring ![]()
| who...? | I've got something like this. Try this... Get a thin screwdriver or simalar, then press down one of the buttons as far as you can. With the screwdriver gently lever the other button upwards. It should have a plastic clip on the end. You the remove the other clip the same way. Under the buttons is a nylon screw. Undo this and lift the assembly out. The top of the loo should then lift off. Refitting is just the reverse, and the bits will only go in one way round. Hope this helps AndyC |
| | #7 | |
| Quote:
| Briskodian Join Date: Jan 2004 Location: Wirral, Merseyside
Members Car: Octavia Estate L&K, DSG. Honda Jazz SE Sport Thanks: 5
| We have exactly the same Roca toilet. If you want a copy of the instructions let me know. Bert |
| right, will go try again ![]()
| | #10 |
| success!!! although i didn't actually do anything inside other than put the thing though the motions so to speak a few times it is now working fine ![]() what was happening was water was constantly trickling from the cystern into the pan so the thing had to keep filling up every 15mins or so which was doing my head in. seems fine now though ![]()
| | #11 | |
| Quote:
| | #12 |
| ![]() i thought was bad enough with my 'going through the motions' line ![]()
| | #13 | |
| Briskodian | Quote:
Threatened it with a Blue Flush block did yer? Mo | |
